Old 03-18-2016, 11:13 PM   #1
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Question Fuel Economy with OFT?
Hey everyone. I'm looking for anecdotes from people regarding fuel consumption with the various base tunes for the Openflash Tablet. (Not including E85, I know that E85 is about 75% as economical as 93.)
Lemme know what your engine mods are with your anecdotes please!
I'm looking at buying an OFT to hold me over until I get flex fuel through ecutek in a year or two. However: I'm going to be doing a LOT of highway miles over the summer and want to know whether or not I'm going to need to flash back to stock tune to save gas. I am on the stock header.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Last edited by Keenercarguy; 03-19-2016 at 09:06 PM. Reason: Correcting iPhone autocorrect-related errors
Keenercarguy is offline   Reply With Quote
Old 03-18-2016, 11:30 PM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
While cruising AVCS, timing, fuel, etc are the same as stock.
At WOT you get more power for less fuel, depending on the car.
Everywhere else in between you get slightly better efficiency.
The Following User Says Thank You to Wayno For This Useful Post:
Keenercarguy (03-18-2016)
Old 03-18-2016, 11:44 PM   #3
ryoma
ryoma's Avatar
MPG will also depend on your driving style and mods you have on your car. after I got my sticky summer tires, I noticed that my MPG dropped from 29 MPG to 27-28 MPG. if you have a real front splitter and rear diffuser (like Velox) you will also gain MPG (Velox has a thread about it).
as for just changing tunes, I didn't really notice any difference from my stage 1 OFT to stage 2 tune (with headers and overpipe installed). I do a mix of freeway and city driving though, and never a full tank purely freeway so I truly don't know what my real freeway MPG is
Old 03-19-2016, 12:55 PM   #4
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
I average 30-32 MPG on a Stage 1 91 octane tune. 90% of my driving is highway going around 70 MPH.
On the stock tune with 100% highway I managed to get 35 MPG.
MT also.
menikmati is offline   Reply With Quote
The Following User Says Thank You to menikmati For This Useful Post:
Keenercarguy (03-19-2016)
Old 03-21-2016, 12:27 AM   #5
Captain
Drives: 15' Raven FR-S
Stock - 28 mpg
Stage 2 UEL 91oct - 26.2 mpg
Captain is offline   Reply With Quote
Old 03-21-2016, 03:23 AM   #6
steve99
Drives: FT86
OFT guys have flex fuel system working thanks to ztan, not sure when it will be released to public ask the oft guys
Keenercarguy (03-21-2016)
Old 03-26-2016, 05:26 PM   #7
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
I am running the following mods:
AEM Intake (not using AEM chip)
Raceseng light weight crank
JDL UEL header
2.5" Spec D exhaust
My MPG is in flux between 32 mpg with some spirited driving during daily driving. to 37 MPG hyper-miling on a stock tune.
Since my OFT, I am 32.8 - 36.7 mpg on avg
Old 03-27-2016, 08:18 PM   #8
Rougenite
Drives: Raven FR-S
I must be doing something wrong. I average 24 and some change. Stock except stage 1.
Rougenite is offline   Reply With Quote
Old 03-28-2016, 03:27 AM   #9
housecat
Computer Scientist
housecat's Avatar
Drives: 2014 BRZ Limited
My Average MPG
All stock: 29.0
OFH + Stg2 UEL 91oct: 28.0
https://docs.google.com/spreadsheets...P78/edit#gid=0
Keep calm and drive safe
housecat is offline   Reply With Quote
Old 05-12-2017, 01:52 PM   #10
Jollyyy
Drives: 2014 FR-S
Mine is about the same. Do you let your car warm up before driving? I think it is still counting the fuel consumed and the 0 miles it went so it drops the average quite a lot .
Plano, TX
2014 FR-S Lightweight pullys/Catback/18 Motegi
Jollyyy is offline   Reply With Quote
Old 05-12-2017, 02:32 PM   #11
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Drive cycle is more important than anything else, likely nothing is wrong with your car, you just sit in traffic or at stop lights/signs more than most people in this thread.
My mileage plummeted not when I changed tires or tuned it, but when I moved, no more freeway cruising meant I went from a ~28 mpg average down to ~24 mpg, but I cut 40 miles off my commute every day.
I just put OFT on my car, but I don't expect that to change that I get 10mpg while tracking or autox-ing or >30 mpg cruise control on down the freeway without traffic.
Yes it does count fuel being used while not moving, so sitting in dead stop traffic you're lowering your average. But sitting in the car letting it warm up for 2 minutes is nothing compared to sitting in 15 mph traffic for an hour or setting cruise control at 65.
If anyone doesn't believe me, reset your average fuel gauge, drive around the block, (<1 mile) then stop and let it idle and watch that number drop like a rock.
ineedyourdiddly
Old 05-12-2017, 04:15 PM   #12
wparsons
wparsons's Avatar
I get in the 6.5-7.0 L/100km range in pure highway driving, 225 AD08R's, K&N panel filter, Perrin 2.5" catted front pipe, 2.5" resonated cat-back and OFT stage 1 93.
Your mileage is going to be more affected by wider/stickier tires than the tune.
flickr
Old 05-13-2017, 01:08 AM   #13
Impureclient
Drives: 2015 FR-S
k&n drop in filter
lightweight pulley set
uel header & OP
oft stg 2
After the uel header and stg 2 tune, no change in mpg here. 100% city driving with very short fast trips under 5 minutes and occasional 15 minutes, I'm at 20-21 mpg. Highway driving I will still easily get into mid thirties.
Old 05-13-2017, 06:08 AM   #14
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I thought I was getting 30 MPG, because I was going with what the display reads. But I started doing the manual calculations every fill up.
70% highway driving. 28 MPG
-Injen intake
-gutted cats, Berk dual exit
-OFT stage 2 93
guybo is offline   Reply With Quote
miles per gallon, mpg, oft, openflash tablet, tune
Why isn't the fuel economy better? White Shadow Scion FR-S / Toyota 86 GT86 General Forum 495 10-28-2019 08:21 AM
First Hwy Run... Fuel Economy Report PNW FRS Scion FR-S / Toyota 86 GT86 General Forum 18 06-10-2013 10:04 PM
Fuel economy ozne99 BRZ First-Gen (2012+) — General Topics 48 12-11-2012 12:55 PM
Optimistic fuel economy? nubbster927 BRZ First-Gen (2012+) — General Topics 15 07-05-2012 08:50 PM
Fuel Economy Lexicon101 Engine, Exhaust, Transmission 38 02-22-2010 03:50 PM
