Old 05-11-2017, 07:14 PM   #253
Gforce
Drives: 2013 Subaru BRZ
That's not unique to this car though, S2000, RX-7, Cayman, Celica, every 2-stroke bike worth mentioning, etc.
It's just odd that so many people who bought this thing and supposedly understood what they were paying tens of thousands of dollars for bitch about it incessantly, and they just ignore the fact that it makes an insane amount of torque below 3.5k rpm for an NA 2.0L 4 banger which is the only reason why it's noticeable imo. Nobody would talk about a dip if it just sucked across the board under 5k rpm.
In fact the torque curves for the BRZ are remarkably similar to those for the Boxster/Cayman flat six. Subaru hired Porsche to assist in the development of the variable cam timing system which is the cause of the dip. In reality, it isn't a dip , just the result of how the two separate torque curves overlap at the cam timing change point.
Truly continuously variable valve timing is the holy grail of internal combustion engine design. Fiat may be closest to achieving this.
Gforce is offline   Reply With Quote
Old 05-11-2017, 07:15 PM   #254
accel
Drives: Bmw
Originally Posted by HKz View Post
lol! were you expecting a touge machine with a 4 cyl accord?
No, but still - that was the first car I autocrossed. The dip annoyed me most in dayly driving, like entering the freeway.
clear lead for 2017's most prolific ft86club troll
accel is offline   Reply With Quote
Old 05-11-2017, 07:17 PM   #255
Gforce
Originally Posted by Da Brz View Post
Insane amounts? I'm not trying to be mean, but what are you comparing it to?
The only other 4cyl I've ever had was my 2012 Mazda 3 and it had about the same amount at 3,500 according to the google search I just did. Of course, google's burned me before, lol.
He's right. Your point depends on the fact that all modern engines use some sort of variable cam timing which results in higher bmep than earlier engine designs with fixed cams could achieve. In reality, these newer engines don't have a torque dip. They have two torque peaks. Of course any forced induction just blows that dip away.
There's still further development possible in this area. Cam timing is very complicated.
Old 05-11-2017, 08:10 PM   #256
Unless you turbo and then simply replace the dip with lag.
humfrz (05-11-2017), nikitopo (05-12-2017)
Old 05-11-2017, 08:58 PM   #257
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
did it moneyshift tho??
HKz is offline   Reply With Quote
The Following 2 Users Say Thank You to HKz For This Useful Post:
bkharmony (05-12-2017), Tcoat (05-11-2017)
Old 05-11-2017, 09:38 PM   #258
Somerandom18
Drives: 2017 manual BRZ
Some turbos spool as soon as 3k.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 05-12-2017, 01:47 AM   #259
accel
Drives: Bmw
Jealousy?
Old 05-12-2017, 02:42 AM   #260
extrashaky
Drives: 2014 BRZ Limited
But somehow they'll succeed in making it suck in production.
Old 05-12-2017, 04:07 AM   #261
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Where did you hear that Subaru hired Porsche people?
The Following User Says Thank You to nikitopo For This Useful Post:
HKz (05-12-2017)
Old 05-12-2017, 11:36 AM   #262
HKz
Reformed
HKz's Avatar
Jealousy?
very every time I shift my 86 now I'm expecting money to rain all over me
Tcoat (05-12-2017), Ultramaroon (05-12-2017)
Old 05-12-2017, 12:15 PM   #263
bkharmony
bkharmony's Avatar
Drives: 2017 86GT
I disagree on all points. The info is vaguely attributed to the person they are allegedly quoting and is totally unconformable at best and possibly total fiction at worst. If Tada did indeed say or even "hint" that the Mark II has not been signed off then he would be hauled up in front of his superiors and flogged. Even he is not at liberty to tell the "press" such things I am sure.
The clickbait part comes in that they even mentioned the convertible at all since it has been very clearly taken off the table 2 years ago. Although I guess they had to do something to spice up a first drive article written in March of 2017 when the car has already been on the lots for six months.
We will see if there is a convertible when/if the next gen comes out and one of us will be vindicated and the other owe an apology.
I'll agree to disagree with you on everything but the clickbait part. Clickbait is defined by a misleading clickable headline. This article did not have that. It's not clickbait.
Also, I never said there would be a convertible. Please don't put words in my mouth.
bkharmony is offline   Reply With Quote
The Following User Says Thank You to bkharmony For This Useful Post:
Tcoat (05-12-2017)
Old 05-12-2017, 01:42 PM   #264
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Funny how you guys are arguing over dip on a variable valve engine.
Back in my days, the factory Nissan KA24DE not only had a torque dip, it had a torque cliff after about 5000RPMs... so all things considered, I'd take the FA20 stock any day of the week.
Torque dip is the result of many things, one thing most people keep forgetting is that almost all the "dips" are in the average range for cruising under normal conditions. It's done so you can get the best fuel economy, and it's also where most of the government emissions/economy test cycles fall into.
-alex
The Following 6 Users Say Thank You to mav1178 For This Useful Post:
darthpnoy1984 (05-12-2017), Gil Scott Heron (05-13-2017), humfrz (05-12-2017), new2subaru (05-12-2017), strat61caster (05-12-2017), Tcoat (05-12-2017)
Old 05-12-2017, 01:45 PM   #265
accel
Drives: Bmw
Drive to Vegas and try slot machines with stick shifts.
The Following User Says Thank You to accel For This Useful Post:
Tcoat (05-12-2017)
Old 05-12-2017, 02:33 PM   #266
darthpnoy1984
Drives: 15 ZN6 Asphalt
-alex
And we got robbed of the turbocharge engine as well and now were seeing cars with turbochargers as a rage lmafo Japan had it over twenty years ago.
2015 ZN6 DD AT
darthpnoy1984 is offline   Reply With Quote
Serious Question: Save for possible future BRZ tS, or throw money at current BRZ? Kostamojen BRZ First-Gen (2012+) — General Topics 72 05-08-2017 02:40 PM
Bad Sign for Future Twins, or Blessing? [Article] Koa Other Vehicles & General Automotive Discussions 14 11-19-2014 11:09 PM
a turbo in the twins future??? AndyJ Scion FR-S / Toyota 86 GT86 General Forum 19 05-07-2014 04:46 PM
Twins vs future competition regal FR-S / BRZ vs.... 69 07-12-2013 08:51 AM
Future of the "twins" regal Scion FR-S / Toyota 86 GT86 General Forum 85 06-05-2013 08:54 PM
