Old 05-11-2017, 01:48 AM   #57
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Here is more information:
The Following User Says Thank You to nikitopo For This Useful Post:
steve99 (05-11-2017)
Old 05-11-2017, 05:21 AM   #58
steve99
Drives: FT86
Im unsure why those guys are reading 11.8 or what ever afr you said, that graph your looking at is pretty low resolution.
Did you look at the intake shootout data from Drift office, they like most other tuners are measuring stock 2012-2016 cars down in low 11 or high 10 as per OL fuel table. The intakes that produce the power increases are also the one that leans the afr the most. Ive no explanation why those guys are different to everyone else
Old 05-11-2017, 09:36 AM   #59
wparsons
wparsons's Avatar
What sensor though? The stock one, or an aftermarket one? If it's the stock one, did the re-scale the O2 so it'll read that low?
flickr
Old 05-11-2017, 12:24 PM   #60
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
A high precision aftermarket sensor.
Old 07-03-2017, 10:16 PM   #61
Qc86
Drives: 2017 Toyota 86 M6
Im really surprised by the number you are getting, I just got my 86 on the dyno today at Lachute Performance.
I have the gruppe s headers and overpipe, invidia catless resonated front pipe, invidia n1, grimmspeed intake, ecutek tune, whiteline diff, trany and rear subframe bushings.
Results : 212hp/159tq .. 166whp
This was done on their dyno which is a MAHA lps 3000pkw i believe.
I always fill with shell 91 vpower but i had a badluck and had to fill with ultramar 91, the tuner ask me if i had put in normal gas in it because he couldnt get higher numbers..
After i picked up the car for a drive back home (8h drive btw) the car was feeling slower than before i got the tune and the gas pedal was very not accurate.
After 300km gas pedal came back to normal and i felt there was A LOT more power then when i picked up the car from the dyno.
The power band now is very very linear and the power is better than before i got the tune now that i drove it over 500km. My butt dyno feels like my car is doing a lot more than 166whp and that i am closer to 175_180whp.. bht thats just my butt.
Also torque dip completely gone
If i get the chance ill try to do a run on a another dyno
Qc86 is offline   Reply With Quote
Old 07-04-2017, 08:57 AM   #62
Qc86
So i did some researsh on the 86 quebec forum and seems like everyone who been on their dyno did lower numbers than what we see on this forum. There is a sheet with results of members who did run on Lachutes dyno, after seing this, i think my numbers are not too bad after all.
The Following User Says Thank You to Qc86 For This Useful Post:
StraightOuttaCanadaEh (07-04-2017)
Old 07-04-2017, 09:21 AM   #63
Wes
It's crazy how much power is lost between the engine and the wheels. Almost 40 hp. Is there a way to minimize that loss? How do you increase efficiency in that regard? Or is it just the innate characteristic of this engine
Old 07-04-2017, 09:47 AM   #64
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I have the gruppe s headers and overpipe, invidia catless resonated front pipe, invidia n1, grimmspeed intake amd ecutek tune.
There's lots of ways to cheat on a dyno or to just scre up the results. Lots of places are run by monkeys and many just don't calibrate often enough. The results of that shop's dyno are abnormal compared to every other non-boosted 86 on the planet. I suspect the dyno operator is the reason the results are so far above norm. I have no proof but I can tell you- those numbers ain't right.
It's every car. There's loss in the drivetrain and you can minimize it somewhat by stiffening the driveline and tranny but at the expense of NVH and reduced lifespan and increased wear and tear of components. But the gains are so small you just have to suck up the loss.
guybo is offline   Reply With Quote
The Following 2 Users Say Thank You to guybo For This Useful Post:
StraightOuttaCanadaEh (07-04-2017), strat61caster (07-04-2017)
Old 07-04-2017, 07:53 PM   #65
Qc86
If you look above your post i did post a sheet with people who been on there dyno and did very similar numbers to mine, my guess is that this kind of dyno reads a lot lower than other dyno. Lachute performance is a very reputable shop in canada they did a lot of frs/86/brz as well as a lot of subies.
Old 07-04-2017, 07:59 PM   #66
Qc86
Originally Posted by justinco View Post
Another thing to add about ECUtek: It seems the RaceRom features (ie: launch control, flat-foot shift, auto-blip downshift, etc) do not work on the 2017 cars. I have done extensive testing with my tuner and cannot see to get them to work. Map switching via the cruise control stalk is also not working, we had to go back to the old style map switching, which works (gas pedal + defrost button).
Racerom features works great with my 2017 86 and i do switch the map with the cruise control. Your tuner should ask help from ecutek because from what my tuner says its a little bit more work to make it work on the 17's but ecutek can help you out.
Old 07-04-2017, 08:14 PM   #67
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
This is why you get a stock dyno before mods, on the same dyno. Then you know what you gain from the mods. Just looking at post upgrade numbers is kind of pointless IMO, because every dyno on any given day is different than the next.
justinco is offline   Reply With Quote
The Following User Says Thank You to justinco For This Useful Post:
JDM4E (07-05-2017)
Old 07-04-2017, 08:44 PM   #68
new2subaru
Weight Weenie
Drives: 15 FR-S
Doesn't that make Dyno results pretty much useless, even if using the same dyno?
Old 07-04-2017, 08:51 PM   #69
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Ambient changes are so minimal, so not really as far as I'm concerned. Going to a dynojet then to a mustang dyno are going to look a lot different on the other hand.
new2subaru (07-05-2017)
Old 07-05-2017, 08:41 AM   #70
Qc86
I live 8hours away from the closest dyno, so 16 hours to go amd comeback. Not to me tion the road to get there is full of potholes and bumps.
I just wanted to get my car dynoed so it run better with the mods and to get rid of the torque dip and have a linear power band, so for me getting a dyno when i was stock would have been a waste of money and time. To each theire own
stock tune only bolt ons dyno slow15frs Engine, Exhaust, Transmission 14 05-12-2016 12:42 AM
Ace Header 4-2-1 CS400 Custom BRZEdit Tune Dyno Results JDM-dono Engine, Exhaust, Transmission 24 05-05-2016 04:54 PM
My Dyno Tune Results brz961 Software Tuning 3 08-28-2014 11:43 PM
Visconti vs FA20Club vs Stock Tune Dyno Results mechaghost Engine, Exhaust, Transmission 153 07-08-2013 11:35 AM
Moar power with simple bolt-ons & ECUTek tune @ OnPoint Dyno l8apexr CANADA 23 04-25-2013 06:50 AM
