Old 05-09-2017, 11:54 AM   #547
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I look forward to updates in this thread everyday. Great job Dustin, hats off for all your creativeness and the just make it happen mentality!
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
Dialkyl (05-09-2017), DustinS (05-09-2017), ILLSMOQ (05-09-2017)
Old 05-09-2017, 12:58 PM   #548
all4spl
I agree!! Thanks for going through the tough stuff. Shops don't usually disclose what kind of work they have to do to make things fit.
all4spl is offline   Reply With Quote
The Following 3 Users Say Thank You to all4spl For This Useful Post:
DustinS (05-09-2017), ILLSMOQ (05-09-2017), Sportsguy83 (05-09-2017)
Old 05-09-2017, 02:27 PM   #549
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Okay, Found my ignition source wire. I am going to run a relay (possibly Fan relay 2 that I removed earlier) to power the Ignition source for GM harness. Using the Grey C/Open relay trigger wires (IG2) to trigger ignition relay.
If you follow the Grey wire that comes from IG2 and C/Open relay it leads to the ECM ignition switch wire (from what I understand that is what it is on the ECM). This is the end of wiring for my swap until the MRS Device arrives.
Edit: This wire at the ECM is needed for the MRS Can Bus Device. Keep that in mind, I bought a package of wire taps the other day to make sure I had them ready. Wire is at Connector A33 - Pin 27 Grey wire
The Following 4 Users Say Thank You to DustinS For This Useful Post:
flippy (05-11-2017), gtpvette (05-09-2017), ILLSMOQ (05-09-2017), Sportsguy83 (05-09-2017)
Old 05-09-2017, 05:56 PM   #550
wooly35
Drives: 2014 Scion FR-S LS3
damn, I love how that radiator sets. Perfect for that air intake to slip in right where it needs...sry, but I think I may steal this idea.lol
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
The Following User Says Thank You to wooly35 For This Useful Post:
Old 05-09-2017, 07:36 PM   #551
DustinS
DustinS's Avatar
Steal away! That was the reason I wanted to angle it. Better intake and the possibility of venting the radiator out the hood. With how the hoses are, the venting is going to be a little more challenging than I originally thought. I'll get it eventually. More pictures tonight. Not a lot of progress as I am at the hospital.
Old 05-09-2017, 08:45 PM   #552
wooly35
Ha, I really appreciate the wiring you are sharing... that is where I fall apart. Its going to help a lot. I canceled everything with vorshlag, ordered the parts I need and now everything will be here by tomorrow. Shame I waited so long.
I'm hoping ill have my car running by the time you head up here for the car meet in KC.
DustinS (05-10-2017)
Old 05-09-2017, 11:43 PM   #553
all4spl
what mounting solution do you have?
Old 05-10-2017, 01:09 AM   #554
DustinS
DustinS's Avatar
He has Vorshlag Mounts from what I remember.
I still need to call and cancel my order for the slave cylinder. Will definitely be doing that tomorrow.
Got the Ignition wire and relay hooked up. Didn't get any pictures as I was sort of rushed. Also got the radiator hose routing chosen. I spent about 45 minutes going through O'reillys radiator hose selection trying to figure out hoses that would work. I left empty handed and resorted to ordering the silicone bends and aluminum tubing. I am going to redo the routing later when I install slim fans and shroud. Right now, plan is to just get it running. I never realized how expensive small silicone hose is.
Core Support Cut. No turning back haha. Needs cleaned up and paint still. Won't be able to tell it's there under the bumper support piece. If the storms forecasted the next few days are anything like last week, Won't be doing anything until Saturday
Intake. The MAF Slot will be moved when final assembled. Cool piece that Texas Speed includes with engine. Has a honey comb in front of maf to help smooth air out.
The Following 3 Users Say Thank You to DustinS For This Useful Post:
ILLSMOQ (05-10-2017), Sportsguy83 (05-10-2017), wooly35 (05-10-2017)
Old 05-10-2017, 09:17 AM   #555
all4spl
Ya the ls1 maf has that. I actually am selling one
Old 05-10-2017, 09:48 AM   #556
Dialkyl
Drives: Silver 2013 Subaru BRZ
Boo! How will we get through the rest of the week without updates?
Dialkyl is offline   Reply With Quote
The Following 2 Users Say Thank You to Dialkyl For This Useful Post:
DustinS (05-10-2017), Sportsguy83 (05-10-2017)
Old 05-10-2017, 11:47 AM   #557
DustinS
DustinS's Avatar
Fed-Ex has notified me of a package being delivered today, and I have no idea what it is. It is either the bash bar, or the can bus device. Neither of which I have received a notification that the product is shipped. So it's like Christmas.
Called Vorshlag to cancel my slave cylinder/TOB order and got told I would be contacted later today as the person taking care of that was on the other line. Not holding my breath as I have been told that before. Being optimistic though.
Currently trying to decide what filter I want to run. Between a large Carbon Fiber K&N and an oval AEM Dry Flow... $200 vs $90. hmm...
Edit: The good thing is, even with the possible storms, I have packages coming in. So you guys will get SOMETHING to look at. Not anything actually good or exciting, but something is better than nothing? Maybe...
I am guessing the package is the MRS device. See if I am right when It arrives.
The Following User Says Thank You to DustinS For This Useful Post:
Old 05-10-2017, 04:43 PM   #558
MRS-Colin
Drives: 2001 Impreza 2.5 RS
It is not
I've been watching your progress closely and I'm holding off shipping as long as I can as I have another tester back online and want to make 100% sure everything is working tip top to avoid any frustrations. We should be testing within a day.
Colin Beck
MRS-Colin is offline   Reply With Quote
The Following 3 Users Say Thank You to MRS-Colin For This Useful Post:
DustinS (05-10-2017), gtpvette (05-11-2017), ILLSMOQ (05-10-2017)
Old 05-10-2017, 04:51 PM   #559
DustinS
DustinS's Avatar
Originally Posted by MRS-Colin View Post
It is not
No problem! Thanks for the update. I'll be patiently waiting.
Package wasn't shipped from a city/state where any of the companies that sell the drift armor bar is sold. So this shall be interesting.
Old 05-10-2017, 05:58 PM   #560
wooly35
I am using Vorshlags mounting solution. Putting the motor in for the final time tonight.
Just got a call from Vorshlag, and the Master slave cylinder kit is in and ready for shipping... so this may be what you have on the way Dustin.
The Following 2 Users Say Thank You to wooly35 For This Useful Post:
DustinS (05-10-2017), Zer0 (05-10-2017)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
