#15 |
Huge E85 fan!
Drives: 2016 Scion FRS
Color me unsurprised. The only real differences between the pre-17 hardware and the new cars are the intake mani and the header. There are some tuning differences too and the end result is +5 HP and Tq.
Soooo, you replace the intake, put a new header on it and tune it and you've changed everything that is new about the new car and you made it into the old car, but tuned. Like every other old style tuned 86. I would have been surprised if the new 86 tuned made more power than the average older style tuned 86. |
| The Following User Says Thank You to guybo For This Useful Post: | strat61caster (05-09-2017) |
#16 |
btr.life
Drives: 2022 GR86
I see what you are saying and it makes sense. The intake was not changed out though, except for the inlet tube.
Part of my test was to use as much of the same parts that I had on my FRS. My FRS made 10hp & 8tq peak over stock, with mostly the same mods. So the thought is that the BRZ might net similar peak gains. But, as I noted in the video, the BRZ was already pretty good from the factory due to the upgrades you mentioned. So, the bolt-ons are not as beneficial on the new car, at least bolt-ons made for the previous years. Maybe vendors will release updated parts for the 2017+ cars.
#17 | ||
| The Following 3 Users Say Thank You to wparsons For This Useful Post: |
#18 |
@justinco just goes to show how poor the factory exhaust manifold and tune of the first gen 86's were. It would be interesting to see auto-x times between your old frs and new brz though.
#19 |
Drives: '15 BRZ RA
The tune of the 2017 cars is more optimized, because they emphasized also on a better fuel consumption.
#20 | |
Drives: '15 BRZ RA
#21 |
So is a stock 2017 better than an earlier model with a stage 1 OTS tune?
#22 |
Drives: 2017 BRZ
#23 |
Ohne Titel
Drives: 2017 BRZ PP ISM
@justinco - who did the tune, and why 14 revisions? Someone who doesn't tune 86's often? Delicious completely nailed it on my tune with 3 revisions.
#24 |
I didn't know that either but according to the brochure on toyota.nl, both auto and manual cars have 147kw (~200hp).
https://www.toyota.nl/brochures/gt86-brochure.json
#25 | |
btr.life
Drives: 2022 GR86
Being in mile high altitude also made it more time consuming I guess.
| The Following User Says Thank You to justinco For This Useful Post: | D_Thissen (05-07-2017) |
#26 | |
btr.life
Drives: 2022 GR86
A pre-2017 car with a base tune will likely have the torque dip smoothed out. So that might feel smoother with better power delivery. But that's just my thoughts on what I've driven.
#27 | |
Drives: '15 BRZ RA
Correct. It is the same for the whole Europe. |
#28 |
Should be a cool comparison once you get the GrimmSpeed intake back on. Back when we tested our prototypes against a silicone inlet+ K&N panel filter we saw a couple more ponies in the midrange, and a bit more torque. I really feel like the area that our intake makes power is going to compliment where the 2017 manual cars are making power. Should probably produce a little bit more power in those areas too, so we'll see!
Very few people look at directions anymore, but please make sure to do so with our intake. The most important point is if you put the filter onto the intake tube too far the tube will stick past the venturi on the filter, and give some weird airflow readings. During our dyno testing the difference between a filter that was on too far, and one that wasn't was substantial. I know you said your tuner saw some MAF scaling issues, so you'll want to be sure that you just do not put the filter on the end of the tube farther than 1in MAX. I usually do about .75in, and keeping the filter as straight on the tube will help some too. Should be a cool test! Chase Engineering |
| The Following User Says Thank You to GrimmSpeed For This Useful Post: | justinco (05-08-2017) |
| stock tune only bolt ons dyno | slow15frs | Engine, Exhaust, Transmission | 14 | 05-12-2016 12:42 AM |
| Ace Header 4-2-1 CS400 Custom BRZEdit Tune Dyno Results | JDM-dono | Engine, Exhaust, Transmission | 24 | 05-05-2016 04:54 PM |
| My Dyno Tune Results | brz961 | Software Tuning | 3 | 08-28-2014 11:43 PM |
| Visconti vs FA20Club vs Stock Tune Dyno Results | mechaghost | Engine, Exhaust, Transmission | 153 | 07-08-2013 11:35 AM |
| Moar power with simple bolt-ons & ECUTek tune @ OnPoint Dyno | l8apexr | CANADA | 23 | 04-25-2013 06:50 AM |
