Old 05-05-2017, 11:26 PM   #43
Originally Posted by JMon85 View Post
Yup same here!
I tried Royal Purple's first, didn't eliminate the chirping.
Since he hasn't been here for 3 years he probably has totally eliminated the crickets by getting a new car.
No additives have proven to work for more than a very short time. There is no snake oil that will eliminate them forever.
sroby (10-10-2018)
Old 05-05-2017, 11:32 PM   #44
JMon85
JMon85's Avatar
Drives: 2019 WRX
JMon85 is offline   Reply With Quote
The Following User Says Thank You to JMon85 For This Useful Post:
Tcoat (05-05-2017)
Old 05-07-2017, 07:46 AM   #45
BRZnut
Drives: BRZ DGM Limited
Sorry to disagree but I have noticed that using 3-4 oz of TCW3 two cycle oil with each fill up has reduced the crickets by 90% and made the engine much more quiet.
Old 05-07-2017, 10:36 AM   #46
90% is not eliminated (and not sure how you measured to get that number anyway). A bit surprised that you would continue to pour stuff into your fuel for this long when the manual expressly states not too use additives. It is not a two cycle engine and using oil in the fuel may be creating long term issues way worse than a chirp.
Old 05-07-2017, 12:10 PM   #47
BRZnut
I've done it on other cars too...no issues. But you are right, it is a risk... time will tell. 90% improvement based on a seat of the pants estimate. Likely closer to 98%. Only hear them maybe 2-3 times during the summer when unusually hot outside and have been driving for over an hour.
chirp, cricket fix, di pump
Tire smell harmful? eSOLOR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 01-27-2014 09:15 PM
Substantive Evidence K and N that harmful? BlackyRose Engine, Exhaust, Transmission 22 06-11-2013 03:27 PM
Local airport has 100 octane gas, would it be harmful to run? VesperLynn BRZ First-Gen (2012+) — General Topics 26 05-19-2013 09:02 AM
Myth about Fuel Additives Grishbok Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 09-20-2012 12:32 AM
Fuel Additives ArKiTeCkT Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 40 06-13-2012 03:26 AM
