#43 | |
No additives have proven to work for more than a very short time. There is no snake oil that will eliminate them forever.
| The Following User Says Thank You to Tcoat For This Useful Post: | sroby (10-10-2018) |
#45 |
Drives: BRZ DGM Limited
Sorry to disagree but I have noticed that using 3-4 oz of TCW3 two cycle oil with each fill up has reduced the crickets by 90% and made the engine much more quiet.
#46 |
90% is not eliminated (and not sure how you measured to get that number anyway). A bit surprised that you would continue to pour stuff into your fuel for this long when the manual expressly states not too use additives. It is not a two cycle engine and using oil in the fuel may be creating long term issues way worse than a chirp.
#47 |
I've done it on other cars too...no issues. But you are right, it is a risk... time will tell. 90% improvement based on a seat of the pants estimate. Likely closer to 98%. Only hear them maybe 2-3 times during the summer when unusually hot outside and have been driving for over an hour.
| Tags |
| chirp, cricket fix, di pump |
| Tire smell harmful? | eSOLOR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 01-27-2014 09:15 PM |
| Substantive Evidence K and N that harmful? | BlackyRose | Engine, Exhaust, Transmission | 22 | 06-11-2013 03:27 PM |
| Local airport has 100 octane gas, would it be harmful to run? | VesperLynn | BRZ First-Gen (2012+) — General Topics | 26 | 05-19-2013 09:02 AM |
| Myth about Fuel Additives | Grishbok | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 0 | 09-20-2012 12:32 AM |
| Fuel Additives | ArKiTeCkT | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 40 | 06-13-2012 03:26 AM |
