Old 05-03-2017, 04:02 PM   #15
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Originally Posted by justinco View Post
So what exactly does brake assist do? I know it does the brake LSD stuff and for traction/stability, is that it?
No, the '17s don't assist the diff anymore with the brakes. Brake assist "helps make sure maximum pressure is applied to the brakes as quickly as possible in an emergency situation."
It's basically a progressive curve on your brake pressure. It's not an active system nor a system that can be turned off or altered. It's also nothing you'll notice, especially autocrossing.
trippinbillies40 is offline   Reply With Quote
The Following User Says Thank You to trippinbillies40 For This Useful Post:
justinco (05-03-2017)
Old 05-03-2017, 09:06 PM   #16
nico_rsx
Drives: BRZ 2017 Pure Red, MT
I clutched dumped it at 7k rpms then moved my clutch foot to the brake. Maybe the fuel cut is silently disabled with pedal dance? You can test it out :p
I just tested flooring the throttle while rolling at 30mph (at 3000rpm approx), and then moderatly pressing the brake, and like you, no fuel cut. And I kept all stability control fully active.
That's strange, I'm sure I read it in the manual or something.
Maybe it's only when you press the brake really hard, like in an emergency situation.
Anyway I'm kinda glad, less nannies make me happy
nico_rsx is offline   Reply With Quote
The Following User Says Thank You to nico_rsx For This Useful Post:
Old 05-03-2017, 10:31 PM   #17
trippinbillies40
Drives: '22 WRB
There is no brake override system on the BRZ. It's on other Subarus to prevent accidental acceleration but it's not on BRZ, WRX/STI.
nico_rsx (05-04-2017)
Old 05-04-2017, 10:34 PM   #18
nico_rsx
Not to contradict you, because you may be right, but here is an excerpt from page 166-167 of the 2017 manual:
If the accelerator and brake pedals are depressed at the same time, driving
torque may be restrained. This is not a malfunction.
Of course they could be stating the obvious (when pressing the brake the car will accelerate less...DUH!! ). But some people, me included, deduced that meant that engine torque is reduced. Of course the test that Justin did, and also mine, suggest there is no override.
trippinbillies40 (05-04-2017)
Old 05-04-2017, 11:40 PM   #19
trippinbillies40
Drives: '22 WRB
Damn SOA peeps needs to get their ___ together
nico_rsx (05-08-2017)
Opensource Flex-Fuel Ethanol Content Analyzer with Bluetooth Fiskafan Software Tuning 26 05-13-2020 02:04 PM
Cost effecient (cheap) flex fuel kit to get up and running on E85 for 2017 BRZs? GNious Software Tuning 4 02-06-2017 06:22 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 10:40 PM
Delicious Tuning Flex Fuel for 2017+ Updated to Accommodate Manufacturer Revisions DeliciousTuning Software Tuning 0 01-04-2017 03:24 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 4 07-16-2016 07:43 PM
