| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2022 GR86
FYI - no fuel cut on 2017 MT BRZ's (burnout content)
A friend of mine had thought that the new 2017 cars may have introduced a fuel cut "feature", when applying the brake pedal at the same time as the gas pedal. Much like a lot of cars have these days for safety reasons.
So, naturally I put the theory to the test, because why else would we be giving the car gas while braking? Well, brake stand burnouts of course FYI I did this with pedal dance mode on. Skip through to about 6:00 minute mark if you just want to see the smoke ![]() [ame="https://www.youtube.com/watch?v=EXy8tiYJSuI"]BRZ burnout challenge part 2. Can a BRZ do a burnout? - YouTube[/ame]
Drives: '22 WRB
Ha. After I looked into it further, the BRZs have brake assist but not brake override.
#3 | |
Drives: 2019 MX-5 RF
Drives: BRZ SWP Limited -6MT
that exhaust sounds great.
Drives: between cars...
When you say 'pedal dance mode on' you mean you just used the 'off' button right?
Drives: 2022 GR86
No, I did the "pedal dance" combo of ebrake+brake pedal to disable everything.
#7 | |
see below... http://i.imgur.com/fk9oNZ8.png |
#8 | |
Drives: 2022 GR86
On my old FRS, I did pedal dance because of the brake LSD interference. So, I just do it on the BRZ out of habit for stuff like this. There was some rumors/chat on the older cars about pedal dance vs button disabling and how ABS changes with that. Never was able confirm. I actually started using the both button disabling method for racing on the 17.
#9 | |
Mode 2: Short press of the Off button Mode 3: Press and hold (1 sec) "Track" Button Mode 4: Press and Hold (3 sec) "Off" Button And heres a confusing diagram to move between the modes.
#10 | |
Proud of BOXER
Drives: Subaru Boxer
What exhaust? All I heard was brostep.
#11 |
Drives: 2022 GR86
hehe brostep
![]() It's a Tanabe Concept G If you want to hear more sound, I did that in another video. [ame="https://www.youtube.com/watch?v=MVzzv1HVDo0"]Tanabe Concept G exhaust install on 2017 BRZ[/ame]
#12 |
Drives: BRZ 2017 Pure Red, MT
I also read from a good source that they had a fuel cut feature. What sequence did you do exactly with the throttle/brake?
Because it's only when the throttle is already pressed, and then you apply brake. There is no fuel cut if the brakes are applied before the throttle (so heel-toe work). But I'm guessing you pressed the brake after the throttle, so i'm puzzled Maybe you need to go a certain speed for the fuel-cut to engage. Or have the nannies on. I'll have to test that. |
#13 | |
Drives: 2022 GR86
#14 |
Drives: 2022 GR86
So what exactly does brake assist do? I know it does the brake LSD stuff and for traction/stability, is that it?
| Opensource Flex-Fuel Ethanol Content Analyzer with Bluetooth | Fiskafan | Software Tuning | 26 | 05-13-2020 01:04 PM |
| Cost effecient (cheap) flex fuel kit to get up and running on E85 for 2017 BRZs? | GNious | Software Tuning | 4 | 02-06-2017 05:22 PM |
| Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L | BRZ_HaVoKx | Engine, Exhaust, Bolt-Ons | 9 | 01-15-2017 09:40 PM |
| Delicious Tuning Flex Fuel for 2017+ Updated to Accommodate Manufacturer Revisions | DeliciousTuning | Software Tuning | 0 | 01-04-2017 02:24 PM |
| Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L | BRZ_HaVoKx | Audio/Visual, Electronics, Infotainment, NAV | 4 | 07-16-2016 06:43 PM |
