Old 04-28-2017, 03:25 PM   #491
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by all4spl View Post
Thanks buddy Also looking at that picture, why no oil pressure sensor? I know with my corvette, it will go into limp mode / wont start without oil pressure, temp, and level sensors.
Is that what goes in that big plug?? Would correlate with the Plug that isn't labeled on the harness right there. I'll check to see if they just left it off and put it in the box, or if I need to get one ordered. Thanks!
Edit: Seems that it can be optional. Plug is there, but sensor is not. I will go ahead and get one and install it, but should be fine without it. I may just install my aftermarket gauge into the port.
Also got to thinking about alternator wiring. Do I need to tie in the alternator wiring into the factory harness? or is that something that shouldn't really matter.
Old 04-28-2017, 05:27 PM   #492
all4spl
When you mean wiring, which wiring are you referring to?
all4spl is offline   Reply With Quote
Old 04-28-2017, 05:32 PM   #493
DustinS
DustinS's Avatar
Plug coming off the Alternator into the GM harness. Is that something that needs to be tied into the factory alternator plug somehow, or doesn't really matter. May be controlled by can bus module. Asking before I try and tackle getting everything set-up.
Old 04-29-2017, 12:56 PM   #494
all4spl
That should go to gm ecu
Old 04-30-2017, 01:43 AM   #495
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by DustinS View Post
I thought they were talking about not needing to clearance it for the sway bar. What they mean is you don't need to notch it for the steering rack. The pan still hit sits on the sway bar. So no matter what exhaust you run - Vorshlag or not - you cannot run a sway bar with these mounts.
They notched it before they moved the engine back another inch, they scrapped the proto type engine mounts and made a new complete set of engine mounts......Terry wanted the engine as far as it could possible go aft and still retain HVAC.....it cost them but they found another inch and it was very important to them to do so......btw I have driven my car all this time with no reverse lock out connected and it hasn't really been an issue.....I have driven it hard......on the Magnum XL it takes considerable force to get it in reverse.....like way more than any other car or for that matter truck I have ever owned.
cf6mech is offline   Reply With Quote
The Following User Says Thank You to cf6mech For This Useful Post:
wooly35 (04-30-2017)
Old 04-30-2017, 01:48 AM   #496
cf6mech
It seems your missing a lot of information on their build thread, like what needs to come out of the trans tunnel , the reason for the notches and other things......read it carefully......and frequently.
Old 04-30-2017, 02:10 AM   #497
cf6mech
Originally Posted by MRS-Colin View Post
ABS module is the other termination point for the CAN bus (ECU being the other). A bunch of nothing will work if the CAN bus isn't properly terminated.
Not so ! ......I can prove it!.....haha!
Old 04-30-2017, 12:21 PM   #498
Zer0
Drives: 2015 frs
Hey Is been a while. Could you elaborate in a pm or on your build thread I don't want to end up doing this but I'm very interested in what you have done with your can bus system
Zer0 is offline   Reply With Quote
Old 04-30-2017, 03:10 PM   #499
cf6mech
Kind of an inside Joke between Collin and I,... I got a unique situation that him and I still need to fix, ....yes sorry Dustin for the thread jack.
Zer0 (04-30-2017)
Old 04-30-2017, 04:18 PM   #500
DustinS
DustinS's Avatar
I have read it quite a few times. Not to mention looked through their entire photo album for the swap. A lot of what is required hasn't been posted. I mis-understood the notching the pan thing as I though they notched it for sway bar fitment. When I went back through, I noticed it was for steering rack.
Old 04-30-2017, 07:25 PM   #501
MRS-Colin
Drives: 2001 Impreza 2.5 RS
I wired Rick's car in such a way it essentially needs a 31 ohm resistor in the DLC. This is 100% unintended and will be fixed when rick gets the time to swap the wiring over to the newer setup
Colin Beck
MRS-Colin is offline   Reply With Quote
The Following 2 Users Say Thank You to MRS-Colin For This Useful Post:
cf6mech (04-30-2017), Zer0 (05-01-2017)
Old 05-01-2017, 02:11 AM   #502
Zer0
Drives: 2015 frs
Nice hopefully I can get my set-up hooked up by you to run the power steering.
Old 05-01-2017, 09:35 AM   #503
DustinS
DustinS's Avatar
Terrible Rain and storms this weekend. A lot of flooding. So not much progress, and by that I mean I put the wiring harness through a hole in the firewall. Weather looks really good this week. So hopefully everything progresses nicely. I will also have an update on the rywire master cylinder adapter.
The Following 2 Users Say Thank You to DustinS For This Useful Post:
M1K3 (05-01-2017), Sportsguy83 (05-01-2017)
Old 05-01-2017, 11:08 AM   #504
all4spl
This is most likely because of the reverse lockout not being connected. When it is setup properly, it will allow you to go into reverse when the car is not moving as the solenoid is energized to allow it to move. essentially, if the solenoid never gets power, you're forcing it to move which equates to the "shifting into reverse being so hard"
The Following User Says Thank You to all4spl For This Useful Post:
cf6mech (07-04-2017)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
