Old 04-29-2017, 11:56 PM   #15
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
Originally Posted by Summerwolf View Post
Yeah, no.... I understand how you are saying it. I don't think you know what CVT is, or what it means.
maybe i'm way off and or using the wrong acronym, my bad
VoltsFRS2013 is offline   Reply With Quote
The Following User Says Thank You to VoltsFRS2013 For This Useful Post:
Summerwolf (04-30-2017)
Old 04-30-2017, 12:07 AM   #16
Originally Posted by VoltsFRS2013 View Post
Maybe you didn't read my post correctly or didn't understand what I was trying to say -- My family was under the assumption that because my vehicle has a way to shift the gears that it is CVT, and even though I told them it wasn't they were still under the impression that it harms the transmission just like CVT does.
They are wrong on both counts. A CVT tranny is not harmed in any way shape or form by using paddle shifters. I am baffled why they would even think that.
You can not harm the engine or transmission in your car by using paddle shifters. The rev limiter and the control unit will not let you do anything bad. No chance of a miss shift like on a MT since it simply will not shift down too far.
humfrz (04-30-2017)
Old 04-30-2017, 12:20 AM   #17
Continuously Variable Transmission. They are operated by a belt (or belts depending) that is sped up or slowed down by changing the position of the pullies. There are no gears in the traditional sense so it isn't really shifting at all. When paddles are used with a CVT all that happens is the pullies move to a set position and do not move again until you hit the paddle again.
Some CVTs (my wife's new Impreza) have artificial "shift points" that make it seem like there are gears even though there really is no practical need for them. Her last car (Outlander Sport) did not have shift points and the car just sped up evenly with the revs at a constant rate. Was a weird sensation that I never quite got used to. Probably why some have the fake shift points.
Old 04-30-2017, 12:32 AM   #18
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
I think he just means his family assumes being able to select specific gears with an automatic means the car has a CVT. Probably because of the marketing hype around CVTs in the past, and paddle shifters were mentioned in those ads.
Basically vroom vroom commercials for fancy cars made some people equate paddle shifters with CVT.
Most people with automatics are just used to R, P, N, and D lol.
The Following User Says Thank You to PandaSPUR For This Useful Post:
Tcoat (04-30-2017)
Old 04-30-2017, 01:12 AM   #19
VoltsFRS2013
My bad for the confusion guys lol, but yeah it's good to know. I love the paddles, auto gets boring and the shift points in the auto are very awkward, there's times where i'll be in second and it wont shift until around 6k RPM (around 60mph most times)
Old 04-30-2017, 01:14 AM   #20
VoltsFRS2013
exactly
Old 04-30-2017, 01:15 AM   #21
Well some know L as well. Even the 2 speed Powerglde in my 64 Impala SS had L.
Qadthane (04-30-2017)
Old 04-30-2017, 01:15 AM   #22
VoltsFRS2013
thank you for the info
Old 04-30-2017, 01:19 AM   #23
Ya the shift points are set up for fuel economy and at least the basic ability to keep up with normal traffic. They are not entertaining. If people with MTs turn on the shift indicator and follow it they would have no fun either though since it is also set up for economy.
Old 04-30-2017, 01:22 AM   #24
VoltsFRS2013
You can adjust the shift indicator though, I set mine for 6500 RPM
Old 04-30-2017, 01:26 AM   #25
Not the max the indicator that tells you when to shift. The MTs have a setting that blinks when you should shift. It is sort of like a game to hit it right on. I called it "Shift Hero" and it was very boring after about an hour.
Old 04-30-2017, 01:35 AM   #26
VoltsFRS2013
Ahh, I never really noticed if the AT's version of that caps your RPM's at that number but I'm assuming by your post it does
Old 04-30-2017, 01:39 AM   #27
It doesn't stop you shifting higher it just gives you warning you are up there. It will not let you rev over 7400 though. It is just an indicator and you could set it at 1000 if you wanted too.
Old 04-30-2017, 01:55 AM   #28
PandaSPUR
PandaSPUR's Avatar
I would probably end up in a crash because I'd be too busy shifting back and forth constantly from following that eco shift indicator lol.
The only autos I've ever driven were family cars and yea I hated them. For the ones I drove, when it shifted was based on how much I was on the gas pedal. Putting my foot to the ground to try and switch lanes would make the car chug along for a second before dropping a gear and suddenly being in the upper RPMs. Same idea as manually dropping a gear for acceleration, except you didnt know exactly when that drop was going to happen.
Have fun with the paddles. The car will probably develop other issues in old age before the transmission dies from paddle usage.
How do I use my paddle shifters? nerb Other Vehicles & General Automotive Discussions 13 02-17-2013 07:10 PM
Paddle Shifters Atticus808 Scion FR-S / Toyota 86 GT86 General Forum 8 10-01-2012 08:34 PM
Paddle Shifting switchkick Scion FR-S / Toyota 86 GT86 General Forum 13 08-14-2012 03:29 PM
Paddle shifting automatic downshift FR-YES Scion FR-S / Toyota 86 GT86 General Forum 15 08-06-2012 09:18 AM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
