Old 02-16-2013, 09:17 PM   #1
nerb
nerb's Avatar
Drives: Scion Fr-s Argento
How do I use my paddle shifters?
I'm scared to use my paddle shifters because I have little knowledge of manual shifting of any sort... Please explain!
nerb is offline   Reply With Quote
Old 02-16-2013, 11:02 PM   #2
jflogerzi
jflogerzi's Avatar
I have to ask. Are you seriously asking how to use your paddle shifters? How about this. What do you not understand?
Old 02-16-2013, 11:08 PM   #3
TOMIMOTO
TOMIMOTO's Avatar
Drives: MY00 Impreza 2.5RS
Right paddle goes up a gear, left paddle goes down a gear.
Here's the really important part. There is a big white gauge in front of you in the middle. It has a little stick that moves around in a sweeping left to right motion. Don't let the stick sweep into the red zone or bad things can happen.
TOMIMOTO is offline   Reply With Quote
The Following User Says Thank You to TOMIMOTO For This Useful Post:
whataboutbob (02-16-2013)
Old 02-16-2013, 11:31 PM   #4
whataboutbob
AutoX-10/10ths every run
Be nice, this could be a genuine question. Everyone had to learn once.
To the OP, do a bit of Googling and read up. Then try and find a forum local with an AT and have them take you for a ride.
Build thread:Here
Old 02-16-2013, 11:36 PM   #5
Burrcold
Drives: Subaru BRZ Limited
You know there is an owners manual that explains it quite well.
The Following User Says Thank You to Burrcold For This Useful Post:
bestwheelbase (02-17-2013)
Old 02-16-2013, 11:40 PM   #6
whaap
whaap's Avatar
Most importantly spend some time with your owners manual. For relaxed, around town driving keep your rpm's between 2000 and 3000. When you get above 3000 shift up a gear and when you get below 2000 shift down a gear. The more you drive and gain experience the more it will all start to come together for you.
whaap is offline   Reply With Quote
Old 02-16-2013, 11:45 PM   #7
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
If you want to go faster, pull the left paddle once. If you want to really go faster, pull the left paddle twice. When you get to the redline on the tach (the big round gauge in the middle), pull the right paddle. Enjoy!
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
The Following User Says Thank You to Spaceywilly For This Useful Post:
davesrave (02-17-2013)
Old 02-16-2013, 11:57 PM   #8
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
There are up and down arrows in the cluster when you are in manual mode.
JoeBoxer is offline   Reply With Quote
Old 02-17-2013, 12:12 AM   #9
The359
X Rated
The359's Avatar
Drives: 2017 BRZ Series.Yellow
Just to specify, if the original poster is talking about an FR-S/BRZ, then the right paddle, pulled toward you, goes up one gear. The left paddle, puddled toward you, goes down one gear.
If you don't know what gear to be in, don't worry, the system is pretty smart and wont let you do anything that will damage your car. Just play around with it and see how it all works.
Just had to specify because some automatics with paddles do not do the "up on the right, down on the left" setup. My parents Malibu is pull toward you on either paddle to go up, push forward to go down.
NULLA TENACI INVIA EST VIA
My BRZ
The359 is offline   Reply With Quote
Old 02-17-2013, 12:14 AM   #10
Burrcold
Old 02-17-2013, 01:18 AM   #11
nerb
nerb's Avatar
Thank you! That's the answer I was looking for.
Old 02-17-2013, 01:21 AM   #12
nerb
nerb's Avatar
Sorry I didn't specify, I was mainly asking for when I should shift up or down based on rpm levels not just based on sound.
Old 02-17-2013, 07:03 PM   #13
hunter3232792
hunter3232792's Avatar
Drives: FRS
[QUOTE=nerb;739770]Sorry I didn't specify, I was mainly asking for when I should shift up or down based on rpm levels not just based on sound.[/QUOT
you should take some more drivers ed
hunter3232792 is offline   Reply With Quote
Old 02-17-2013, 07:10 PM   #14
nerb
nerb's Avatar
[quote=hunter3232792;740734]
pancake potato
automatic, paddle-shifters
Paddle Shifters Atticus808 Scion FR-S / Toyota 86 GT86 General Forum 8 10-01-2012 08:34 PM
paddle shifters Sasquachulator Scion FR-S / Toyota 86 GT86 General Forum 11 08-28-2012 10:15 PM
Paddle Shifting switchkick Scion FR-S / Toyota 86 GT86 General Forum 13 08-14-2012 03:29 PM
Can you manually shift automatic version w/out the paddle shifters? maxeveland Scion FR-S / Toyota 86 GT86 General Forum 31 02-01-2012 11:51 AM
Paddle-Shifters Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 45 09-14-2011 12:20 AM
