Old 04-27-2017, 01:28 PM   #15
M0nk3y
Originally Posted by stevesnj View Post
You took that totally the wrong way. I posted the thread because I wanted opinion through data and experience. Maybe it will help someone out too. Jeeze
What "Data" do you expect? Vibration analysis?
You realize OPR will quickly off-balance a "balanced tire" right?
The Following 2 Users Say Thank You to M0nk3y For This Useful Post:
Icecreamtruk (04-27-2017), stevesnj (04-27-2017)
Old 04-27-2017, 01:31 PM   #16
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Originally Posted by M0nk3y View Post
lol. Okay.
I don't know anything then.
Enjoy your balanced tires and bead sealer then. Stupid for me to comment on a thread you clearly already know the answer to.
There was no reason for that harsh comment. I think you misinterpreted OP's reply.
As for the original question, for AutoX, that's probably ok not to balance, but for track, at 120mph, I would definitely not take the chance and would balance them.
Where I live we get lots of snow, and sometime it gets in the Wheel, and when that happens, the vibration at 60mph can be scary. To the point you have to stop and clean the wheel.
Of course that's a lot more imbalance than a clean wheel that's not been balance, but still...
nico_rsx is offline   Reply With Quote
The Following 2 Users Say Thank You to nico_rsx For This Useful Post:
stevesnj (04-27-2017), Tcoat (05-16-2017)
Old 04-27-2017, 01:33 PM   #17
jasonojordan
Drives: 2013 satin white brz limited
"Data" he is looking for is people with more experience in the matter then he sharing their personal preferences so that he can see what everyone else is doing and based off majority and his own personal comfort level move forward with a somewhat informed opinion.
jasonojordan is offline   Reply With Quote
The Following 2 Users Say Thank You to jasonojordan For This Useful Post:
MuseChaser (05-16-2017), stevesnj (04-27-2017)
Old 04-27-2017, 01:35 PM   #18
stevesnj
stevesnj's Avatar
Not the harsh responses you give, this is how you treat people when they thank you? Wow
My 2016 Build thread
Old 04-27-2017, 01:35 PM   #19
stevesnj
stevesnj's Avatar
+1
Old 04-27-2017, 01:36 PM   #20
stevesnj
stevesnj's Avatar
Lot's of help and data, thanks
Old 04-27-2017, 01:47 PM   #21
oinojo
Suspension Nerd
oinojo's Avatar
Drives: 2019 Mazda MX-5
Don't mind him, hes pretty slow =P.
It also comes down to your rim condition. If the wheel has a slight bend to them, it is worth balancing the setup as it can be really out of balance (+2.50 ounces worth). You don't want that kind of vibration at 100+.
Best advice I can give you is to make sure you mount your tires well in advanced to your track day. I've seen guys mount up the night before and completely throw off their balance as the tire moved on the rim from the lubrication not being allowed to dry first. This is true for balance or not balanced. You'd be surprised how imbalance just a tire can be outside of being mounted to a rim.
OS Giken / Bridgestone / Lot-USA BRIDE
oinojo is offline   Reply With Quote
The Following User Says Thank You to oinojo For This Useful Post:
Old 04-27-2017, 01:54 PM   #22
stevesnj
stevesnj's Avatar
lol, I see that he is slow. But thanks for the info, great insight on tires. I'm sure someone else will use this info.
Old 04-27-2017, 01:57 PM   #23
M0nk3y
#alternativefacts
A good experiment to do is mark your wheel/tire with some sort of removable marker. You'll be able to see if the wheel has slipped at all and rotated on the wheel itself.
The Following User Says Thank You to M0nk3y For This Useful Post:
Old 05-15-2017, 01:30 AM   #24
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
I do not balance my slicks. Once you complete 1/4 of a lap and pick up even a small amount of rubber you'll realize that your time was wasted. We only balance stickers on our Lamborghini Huracan Super Trofeo.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 05-15-2017, 03:00 PM   #25
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
EXACTLY!
I just had brand new hoosiers mounted & balanced for my track car.
When I loaded them on the trailer after a day of racing each tire had about 2 extra pounds of "Clag" ( rubber picked up from the road) on each one. Balancing a true road tire is good when brand new but doesn't really mean much after a few hot laps.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
Old 05-15-2017, 10:46 PM   #26
zdr93523
zdr93523's Avatar
Originally Posted by justatroll View Post
EXACTLY!
The other thing is that you only really feel balance when steady cruising at 70-78mph. You're never in that situation on the track, or at least I hope not. Haha
www.makesmodels.com
www.camautomag.com
Old 05-16-2017, 12:00 PM   #27
subielife
Subaru Ambassador
subielife's Avatar
Drives: 13 BRZ 18 Silverado
I've been tracking/instructing for 15 years and I have never balanced my track tires. Like others have said your never at a steady speed so you effectively drive thru any vibration.
subielife is offline   Reply With Quote
Old 05-16-2017, 12:40 PM   #28
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
If you don't put some sort of heat tape or thermal barrier over the wheel weights they have a good chance of falling off at the track anyway.
14stu is offline   Reply With Quote
Are my wheels improperly balanced? lupindub Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 04-11-2016 03:54 PM
Engine swap that will improve the car in a balanced way? DVNARC Scion FR-S / Toyota 86 GT86 General Forum 2 09-04-2015 02:01 AM
Brand New FRS/BRZ Tires and Rims (mounted, balanced) Hamza7 Canada Classifieds 1 05-16-2015 02:12 PM
perfect balanced wheels BRZtoni Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 05-06-2014 12:27 PM
Got Corner Balanced and Aligned track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 08-10-2012 01:35 PM
