Old 04-25-2017, 05:34 PM   #1
sfruski
Drives: Many
Rear upper control arms with spherical bearings
I've been looking for a while and I can't find any great options for rear upper control arms with spherical bearings. This will be for a car running 265 slicks in NASA TT4. I have SPL for all other bearings.
racerX no longer makes their control arms with spherical bearings.
I can replace stock bushings with spherical ones, but that is a huge pain and fairly expensive as well as time consuming.
Parts Shop Max seems to have a set including hubs for around $850.
P2M has a set for $450 but I can't find any information about them. I have no idea if they are junk or safe to use.
One other company has them for $1400 which is really hard to justify.
Any opinions on the Part Shop Max ones?
Any opinions on the P2M ones?
Thanks
sfruski is offline   Reply With Quote
Old 04-25-2017, 06:17 PM   #2
whataboutbob
AutoX-10/10ths every run
I've never used these, but found a reference to them here: http://www.ft86club.com/forums/showp...6&postcount=10
Here's a link to the part:
http://www.mooresport.com/indexe.php...ear-upper-arms
Build thread:Here
Old 04-25-2017, 06:23 PM   #3
sfruski
Drives: Many
Yeah, those are the $1,400 ones I found. They look good, but questionable for that price.
Old 04-25-2017, 09:21 PM   #4
norcalpb
norcalpb's Avatar
I'd just do the bushings. I feel like it would be easy because you can take the arm out before catching the bushings on fire.
Old 04-26-2017, 02:37 AM   #5
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
Contact @CounterSpace Garage and order the Cusco spherical bearing kit for rear upper control arms - I got mine from them and they're much cheaper than the other options you're currently looking at.
RJasonKlein is offline   Reply With Quote
The Following 3 Users Say Thank You to RJasonKlein For This Useful Post:
BlueWhelan (11-15-2023), CounterSpace Garage (04-27-2017), wparsons (04-26-2017)
Old 04-26-2017, 05:23 AM   #6
DIY
DIY's Avatar
Drives: BRZ, WRX
http://racefab.co.nz/
DIY is offline   Reply With Quote
Old 04-26-2017, 01:12 PM   #7
sfruski
Drives: Many
Originally Posted by DIY View Post
Thank you for the link!
Old 04-27-2017, 03:27 AM   #8
mkivsoopra
PM sent regarding RacerX control arms with spherical bearings.
mkivsoopra is offline   Reply With Quote
Old 04-27-2017, 08:07 PM   #9
TRAKRAVN
Drives: 2015 Scion FRS - Raven
I dropped off a set of OEM rear upper arms to ESM Race to make some spherical bearing to replace in the stock bushings last week. That will complete their kit for ALL of the suspension bushings to be converted to bearings.
Give them a call to generate some interest so they can get it to market a little sooner.
TRAKRAVN is offline   Reply With Quote
Old 04-28-2017, 02:00 PM   #10
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
Its upper control arms with spindle not hubs
Having had their RUCA and spindles for my 240sx in the past I have been waiting for this kit for the 86 since they started the design. I have their fronts and all their suspension parts and its worth it at twice the price.
irax is offline   Reply With Quote
Old 01-24-2018, 02:46 PM   #11
Jonsey
Jonsey's Avatar
For anyone else looking for rear UCA w/ spherical bearings, I reached out to RacerX again today and they still haven't received enough interest to justify building them. Would be nice but looks like RaceFab or MSI are the only options currently.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
Old 01-24-2018, 11:28 PM   #12
jamal
jamal's Avatar
Drives: Legacy GT
The cusco part numbers for the spherical bearings for the rear upper arms are
965 464 LV - front
965 464 IV - rear
If you order 1 each of those you get 4 bearings for both the arms. 240 each msrp.
Since I have the catalog open here are the other part numbers for the spherical bearings
965 464 AV - Front control arm F
692 464 BV - Front control arm R
692 464 HV - Rear LCA inner (outer mount in upright is already a bearing)
692 464 NV - Rear trailing arm F (rear mount in upright is already a bearing, I think)
692 464 JV - Toe link inner
Whether cusco usa or any dealers have any of this I don't know, but they can get stuff fairly quickly if you need it.
jamal is offline   Reply With Quote
The Following User Says Thank You to jamal For This Useful Post:
RedReplicant (05-12-2023)
Old 01-25-2018, 08:49 PM   #13
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
965 464 LV - front
965 464 IV - rear
We sold many sets of sphericals depending on what the client is looking for.
CounterSpace Garage is offline   Reply With Quote
RacerX Rear Upper Control Arms 636 Brakes, Suspension, Chassis 2 01-05-2017 10:05 PM
FS - racer x rear upper control arms. jay92 Brakes, Suspension, Chassis 3 08-12-2016 10:05 PM
FS: Rear Upper Control Arms MicheleAbbate Brakes, Suspension, Chassis 1 05-03-2016 06:44 PM
Oem rear upper control arms Jhon19lopez Brakes, Suspension, Chassis 1 08-25-2013 09:01 PM
