Old 04-25-2017, 07:45 PM   #4075
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
30mm kit is out now. http://kraftwerksusa.com/150-12-9300.html
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 04-25-2017, 08:30 PM   #4076
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I really feel for these guys. I was super close to purchasing their kit but due to belt snapping issues I went to fullblown. Its really tobad they dont have an auto tensioner.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 04-30-2017, 11:49 PM   #4077
EchoHotel
Drives: 2013 FR-S Hot Lava
Talking 30mm kit kicks ass
Originally Posted by Apoc View Post
Got it and love it!!
https://goo.gl/photos/3RZPVA6zayyJeDgS6
https://goo.gl/photos/BhJuXWBr3TsP3Uyp7
https://goo.gl/photos/Ucqyrwhjo2YLRG1L9
18-20psi on c30-94 on high boost
https://goo.gl/photos/Ep3cySFYPoMr5WjPA
EchoHotel is offline   Reply With Quote
Old 05-12-2017, 03:39 PM   #4078
KiwamiPG
Drives: AE86, KP61, FRS RS2.0 (116-1000)
Just installed my c30kit with a delicious tuning map ... did 3 third gear pulls to log for them and on the third one while slowing down the car cut off started right back up then died again unless I stayed in the gas...idle was going from like 2500-3000 up and down. Let it sit for a while and turned it on again but stalled a few times but eventually started and idled kind of rough at 1000..little rev to 3000 no problem but then the idle stayed at 2500 won't dro..anyone have similar issue?
KiwamiPG is offline   Reply With Quote
Old 05-12-2017, 04:20 PM   #4079
John92
Drives: White scion frs
Might want to send him your log and have him look at the tune.
Follow me on IG:@john9207
John92 is offline   Reply With Quote
Old 05-12-2017, 05:21 PM   #4080
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
doesn't seem right to me. could be a number of different things, I, too would recommend calling them and telling them the scenario. Do you have a AFR gauge what does it say when it's idling? What does it say at WOT? And what does your boost read when you get into the higher RPMS? That will tell you if you have a leak or not if it's not holding boost. These are just the basics.
Otherwise what this sounds like is you may have popped the hose off the evap line... that happened to me on track and the car was driving similar to yours very rough and I would have to gas it to keep it alive. OR you hit boost and popped one of your intercooler piping hoses... I'd check that also.
http://www.ft86club.com/forums/showthread.php?t=109444
pgranberg11 is offline   Reply With Quote
Old 05-30-2017, 10:39 AM   #4081
PulpBrah
Drives: 2014 frs
what do you all think of buying this kit used? what should I look for?
PulpBrah is offline   Reply With Quote
Old 06-03-2017, 01:26 PM   #4082
Helios
Helios's Avatar
Drives: 2014 Red Subaru BRZ
I bought mine used. I saved approx $1500 by doing so. I did the install myself. I had to replace/ purchase some hardware, the MAP sensor, Rotrex oil, and ECUTek license that weren't included. I also has to fabricate some brackets that weren't included. So, if you buy used I'd make sure all the stuff comes with it or you make sure you know how to fabricate and know screw sizes/ material type/ material hardness. Honestly, I wouldn't recommend doing the install if you're a novice. You must have decent mechanical ability and know your way around the engine bay of the car. Buying used is a great option if the person you're buying from took care of the kit and you know how to install or know people that can.
Helios is offline   Reply With Quote
Old 06-03-2017, 01:28 PM   #4083
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
At bare minimum buy a new belt with it and rotrex oil
Freeman is offline   Reply With Quote
Old 06-10-2017, 12:16 PM   #4084
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Originally Posted by mscamp02 View Post
Pullet is toast to S/C is toast screws backed out. Actually was kinda lucky because I was doing a random check and noticed the pulley wobbling, well while I was watching it wobble trying to remember how I had to attach it or if it was a bearing or something going out it snapped the last bolt or two that was holding it causing it to jump and grind.
I got the pulley and belt off after pulling the main bracket off its mounts. Looks like I'll have to reflash back for a while until I can get a new pulley, no damage to s/c at least.
This just happened to me today while driving. I thought a hose popped off because of the pressure dispersal sound, but after inspecting the pulley was leaning against the compressor. Taking it apart right now.
Output shaft broke. Factory 30T-75 pulley on a C38. =( Its been almost exactly 3 years since install.
D-VO is offline   Reply With Quote
Old 06-21-2017, 02:14 PM   #4085
Freeze2196
Freeze2196's Avatar
Drives: 2013 Scion FRS
Skunk 2 Sandwich Adapter seems to have dropped in price
Amazon has it listed for only $73.76
https://www.amazon.com/Skunk2-626-12...ndwich+Adapter
I have only ever seen it for around $200
-Capetwn
Freeze2196 is offline   Reply With Quote
Old 06-21-2017, 02:58 PM   #4086
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
-Capetwn
I would never buy that thing again after my first mistake of buying it. There's no way that thing will hold any type of oil from leaking. I had to custom make an oil cooler with stacking spacers together. Pain in the ass.
Old 06-22-2017, 12:00 AM   #4087
Super Dave
Stuck In a Sandbox
Drives: FRS RS1.0
does anyone get a whooshing sound when in partial throttle in boost? i assume its the "blow off" releasing pressure but i just want to make sure its not a loose hose. It cuts off when fully on the gas and in boost. apologies in advance for the dumb question
Super Dave is offline   Reply With Quote
Old 06-27-2017, 12:21 AM   #4088
Helios
Helios's Avatar
Yes, I get that sound under partial throttle.
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
