Old 03-07-2016, 05:00 PM   #701
dp1
driving smoother faster
Drives: Sold
Originally Posted by texasbound972 View Post
So you're saying that 0w40 gives you worse gas mileage than 5w30?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Not my words but I clearly interpreted the comment that way
dp1 is offline   Reply With Quote
Old 03-07-2016, 07:47 PM   #702
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by dp1 View Post
Another private answer I got from a trusted source is that I can mix Motul 300V 5w30 and 0w40 oils on a tracked car, with some hit on gas mileage with w40. Thank you all
0w40 is often nothing but marketing, SAE J300 states that they can have the same viscosity and shear rate at engine operating temperatures. The range of viscosities that are allowed to be labeled as 0w40 can be more viscous than oils labeled as 5w30, but they don't need to be. I highly doubt you would ever be able to measure a mileage difference between the two in a real world test.
http://www.viscopedia.com/viscosity-...cosity-grades/
The Following 2 Users Say Thank You to Calum For This Useful Post:
Bykov (03-07-2016), dp1 (03-07-2016)
Old 03-07-2016, 07:49 PM   #703
Calum
That Guy
The higher number should indicate a more viscous oil, which would cause the engine to work harder to pump the oil. But the differences at operating temperatures are often negligible, if they exist at all.
The Following User Says Thank You to Calum For This Useful Post:
texasbound972 (03-07-2016)
Old 03-08-2016, 04:46 AM   #704
ajc209
Drives: GT86 Cosworth
It definitely does exist and its one of the reason our car runs such a low pressure; fuel economy.
Bare in mind a thicker oil will generate a bit more heat too. The extra energy used to pump the thicker oil round has to go somewhere.
ajc209 is offline   Reply With Quote
Old 03-08-2016, 06:16 AM   #705
Calum
That Guy
If you're comparing 0w40 to 5w30, than I disagree, for the reasons I stated above. If you're comparing 0w20 to either of the other two, that I'll agree with. Though the difference isn't going to be anything huge, I'd estimate a percentage or two for highway driving.
Old 03-08-2016, 05:27 PM   #706
derek1ee
Drives: BRZ/FRS/STI/M3
This may be totally off the topic, but I'm curious what this is?
derek1ee is offline   Reply With Quote
Old 03-08-2016, 06:43 PM   #707
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Fire extinguisher nozzle
The Following User Says Thank You to DocWalt For This Useful Post:
texasbound972 (03-08-2016)
Old 03-08-2016, 08:15 PM   #708
derek1ee
Thanks!
Old 03-08-2016, 10:34 PM   #709
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
it responds to the "oh shit" handle
Gear_One_Performance is offline   Reply With Quote
The Following User Says Thank You to Gear_One_Performance For This Useful Post:
sato (07-09-2016)
Old 04-25-2017, 01:37 PM   #710
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Updates after 1.5 years of racing
I know it's been forever since I've updated anything or even been on the forums. Honestly we have just been busy with engine building, client builds, and new projects. We also had been racing with the same FA20 successfully for over 1.5 years. Great photo by @JonAthanboppenheim
Our number one goal for our engine package was to get reliable oil pressure under racing conditions for higher power and also for our 9k rpm head package. As you can see these bearing could just go right back into the motor!
What nobody knew was that were were also testing WRX DIT parts in our engine as a means to further develop that platform without having to build another WRX race car. With the lower compression pistons and downright beefy ringlands we decided it was worth seeing how these engines held up. Now these do not drop into the BRZ motor so don't get any bright ideas but we broke multiple track records with this motor over the last 1.5 years.
If you've never seen this FRS Time Attack car in action, it's absolutely mental! Here's a record run and a win at Gridlife Atlanta. Even in 100 degree weather I was able to match my best ever lap there of 1:30.3
[ame="https://www.youtube.com/watch?v=2gr9ma_vFCw"]Another record lap at Gridlife Road Atlanta in the Time Attack FRS - YouTube[/ame]
That wasn't good enough for the racer in me and I wanted a sub 1:29 as I knew the car and me had it in us. As we all know that transmission is on the brink at 400 whp and so we've always raced it there and even detuned it more in 4th gear. My car has made over 500 whp on race fuel however and I wanted to risk it but even on E70 my fuel system was barely adequate for 400 whp. Given I would only turn it up in 5th and 6th I decided to risk a couple more psi even though I knew it would run lean. As I approached the last turn it let go and I coasted across the line with a 1:30. So close and so not worth it. Hahahaha! The carnage of what's left of the OEM cast piston.
Even with such massive destruction (it let go at 120 mph) you can still see how effective the oiling and engine mods were in our car. Now this is the major downside to a cast piston! Even though this piston handled over 500 whp on the street, and 400 whp racing for 1.5 year, when things go wrong the piston shatters in spectacular fashion. A forged piston would never do this so it's it's well worth the upgrade cost even though these FA pistons are a huge improvement over the EJ pistons.
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
The Following 14 Users Say Thank You to Element Tuning For This Useful Post:
AJPG (04-25-2017), BatStig (04-25-2017), DarkSunrise (04-25-2017), DustinS (04-25-2017), GsxrMe (04-25-2017), johan (04-25-2017), Jonsey (04-27-2017), Kris86 (04-25-2017), Lonewolf (04-25-2017), new2subaru (04-25-2017), RavioliG (09-01-2017), sato (04-25-2017), skylinekin (04-25-2017), SoCalArgento (04-25-2017)
Old 04-25-2017, 07:38 PM   #711
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Are those sexy king bearings I see?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 04-27-2017, 02:26 PM   #712
Element Tuning
OEM bearings actually.
Old 04-27-2017, 02:33 PM   #713
StraightOuttaCanadaEh
Wes
How much labour are you looking at if you want to replace your pistons for forged items? Just curious how long it takes
Old 04-27-2017, 07:38 PM   #714
Element Tuning
You have to split the cases so as long as a full build which is about 27 hours.
The Following User Says Thank You to Element Tuning For This Useful Post:
StraightOuttaCanadaEh (04-27-2017)
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 12:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-17-2013 11:24 PM
