Old 03-02-2016, 03:37 PM   #687
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Originally Posted by Tim Radley View Post
Ok i'm a bit confused then as to how your setup worked as I thought you were running the upgraded stock pump with a scavenge pump.
I am currently running the OEM oil pump with an Element Tuning Pro Comp Engine package as I have always been with the exception to the one race where I tested the aftermarket oil pump gear.
The external oil pump has never proven better than the OEM pump at delivering optimal oil pressure. I am only testing the pressure stage because that is the most critical (not the scavenge stages). What would the point of releasing a 3 stage $6k dry sump kit when it produces less oil pressure than the OEM pump?
We've got 95% of the hardcore power guys handled with our motor builds. Any power you can throw at it, we've got you covered for drag racing and street abuse. It's the last 5% who are high power road racers (400+ hp) that we are trying to help.
Element Tuning is offline   Reply With Quote
Old 03-05-2016, 02:44 PM   #688
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
http://www.manchestersubaru.com/suba...thetic-oil.htm
Sent from my SAMSUNG-SM-N920A using Tapatalk
texasbound972 is offline   Reply With Quote
Old 03-05-2016, 05:45 PM   #689
Calum
That Guy
Drives: 2013 asphalt FRS MT
What was the point of this post?
Old 03-05-2016, 05:53 PM   #690
texasbound972
USMC
Just some info about what oil subaru recommends running if there is a turbo or not. Big debate over oil.
Old 03-06-2016, 08:42 AM   #691
Calum
That Guy
The only people that debate about which oil to use are the ones that don't know enough to make the decision based solely on facts. I don't have that knowledge, but the original poster certainly does. I know enough to understand that bearing clearances, bearing size, connecting rod force, oil temperature, and oil pressure are involved in the decision. Based on that, it should be obvious that the oil properties should be based on what the engine is going to be used for. Elemental Tuning builds their engines and they know exactly what each of those parameters is, so they are well aware of what oil they should be using in their builds to suit various end users.
Old 03-06-2016, 10:19 AM   #692
Element Tuning
Wrong. You use the oil viscosity required for whatever conditions the engine is being used in or used for. If you have a stock engine, oem power, and the car is daily driven then by all means use the factory recommend oil.
If you have triple the oem power and you run your oil at 280 degrees under track conditions, you do not use the oem oil viscosity.
Old 03-06-2016, 11:23 AM   #693
texasbound972
USMC
Crawford has me running 0W40 for their built block. A guy I know that's a Toyota mechanic says that 5w30 is better. It's a never ending argument lol.
Old 03-06-2016, 01:19 PM   #694
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
the cars' handbook actually recommends 5W30 for heavy / hot climate use and 0W20 for everything else
Matt@Cosworth is offline   Reply With Quote
Old 03-06-2016, 06:05 PM   #695
dp1
driving smoother faster
Drives: Sold
FA20 Engine Oiling, Bearings, and Starvation
I have been using Motul 300V 5w30 for track/ax in warm NE months. JRSC with JR oil cooler, delicious tune, lower fan temp 28k miles and over 40 track/ax days. Just noticed I have 4l worth of 0w40 300V that was sent by mistake as part of the 5w30 batch - is it ok to mix 5w30 and 0w40?
dp1 is offline   Reply With Quote
Old 03-06-2016, 07:40 PM   #696
Bykov
Drives: 2014 Monogram FR-S Whiteout
Savagegeese had a good explanation on this. The answer is probably but check out his video to see how it applies to you.
An engineer from Mobil 1 once said motor oils are designed keeping in mind some people may decide to mix oils and they account for that. But that's mobil 1 not Motul.
PS I would link the video but YouTube is blocked.
Bykov is offline   Reply With Quote
Old 03-07-2016, 04:11 AM   #697
ajc209
Drives: GT86 Cosworth
Whilst we are talking about oil viscosity, some might be interested the Toyota Motorsport GT86 race car runs on 10W60 race oil and has an optional oil cooler.
It does have a low temp thermostat which does help lower oil temp a little bit, but other than a remap and exhaust system its a stock FA20 engine.
TMG won multiple world rally championships back in the 90s with the Celica and currently build the Toyota Le Mans cars so I reckon they know a thing or two....
I wouldn't use that on the street though. 0W20 gives a nice 70-80psi @7krpms at @212F. Its only when things get hotter on the track that pressures starts to get a little low and a W30 or W40 oil might be useful.
If it a street and track car then there will always be a compromise between very high pressure on the street and acceptable pressure on the track.
ajc209 is offline   Reply With Quote
Old 03-07-2016, 06:04 AM   #698
TRAKRAVN
Drives: 2015 Scion FRS - Raven
I run 0w-50 in the car (car is summer use only) and I just let it warm up a bit before driving. Even with an oil cooler the temps will still climb and when they do that's when the extra pressure from the thicker oil makes a difference. As far as one oil being better for you than someone else is all application based. If you baby the car all the time and drive year round 0w-20 is perfect. Same thing like your body, if you work out and play sports you need more food then someone who is sitting around. Think of oil in the same way, thicker oil for those that are working hard.
TRAKRAVN is offline   Reply With Quote
Old 03-07-2016, 01:01 PM   #699
dp1
Drives: Sold
Another private answer I got from a trusted source is that I can mix Motul 300V 5w30 and 0w40 oils on a tracked car, with some hit on gas mileage with w40. Thank you all
Old 03-07-2016, 03:39 PM   #700
texasbound972
USMC
So you're saying that 0w40 gives you worse gas mileage than 5w30?
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 12:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-17-2013 11:24 PM
