Old 04-23-2017, 03:16 AM   #1
ChaosBlades
ChaosBlades's Avatar
Drives: 17 BRZ PP CWP
What supporting mods can I install and keep the car drivable before getting tuned?
So the closest tuner for me is a 4-hour drive, so 8-hours both ways. To keep from having to get a hotel, unforeseen installation issues, shop installation cost, or towing costs I would like to install my supporting mods and make sure everything is working as properly without a tune as possible before getting a proper tune. I am not interested in e-tunes, I want a proper dyno tune so no need to try to convince me to go that route.
What should I expect symptom wise and what if anything does Dynosty need to install? Also what supporting mods if any could I install with the Jackson Racing Tune without causing any issues at all? I was just going to slowly install all the supporting mods but then I started reading things from reputable users on the forum saying not to use catless headers and lightweight pulleys with the JR Tune without explaining why. Wouldn't a catless header just through a CEL code, no biggie?
I am going to have the following done to the car then once I acquire more funds I am going to be installing the following supporting mods and scheduling a tune with Dynosty.
Jackson Racing Supercharger w/ Factory Tune
Jackson Racing Track Engine Oil Cooler
FX400 CLUTCH KIT (NORMAL FW)
Driveshaft Shop Aluminium Driveshaft
JDL 3″ Test Over Frontpipe
Perrin Cat-back Exhaust 3" Resonated
Supporting Mods:
JDL UnEqual Length Catless Header
Velox Billet Fuel Rail Kit w/ Fuel Rail Covers
Deatschwerks 700CC Injectors
AEM 320LPH High Flow Fuel Pump
Perrin Lightweight Crank Pulley
Perrin Lightweight Accessory Pulley Kit
Moto-East Flex Fuel Kit
Also AFR, Oil Pressure, Boost, and Ethanal Gauges not that it will effect the tune.
ChaosBlades is offline   Reply With Quote
Old 04-23-2017, 04:46 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
If it's just for getting you somewhere to be tuned, the manifold and pulley should be fine. I'd imagine the pulleys are more likely to make it shall, if anything, and the manifold will just cause a CEL. Does the JR tune come ready for those injectors though?
Just an aside but I would suggest against running non-OEM pulleys on SC applications. If they're already on the car then TBH I wouldn't bother to take them off but if not then it might be worth considering. It just reduces the risk of belt issues IMO.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-23-2017, 05:58 AM   #3
ChaosBlades
The JR Tune is designed for a completely stock car (91, full stock exhaust, etc) with just the supercharger kit installed. That is why I am wondering what the injectors are going to do on that tune.
Old 04-23-2017, 07:15 AM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
It'll struggle to start and run, if at all as it will run very rich. Is there no way you can get Dynosty to email you a base tune to get you running?
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-23-2017, 02:55 PM   #5
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
I understand that you would prefer not to have an e-tune but to be honest its the best route forward for your situation
once you have the car up and running and your tuner has a had a couple of goes at e-tuning it , it should then be safe enough to drive to the rollers to finish the job and get it spot on
Matt@Cosworth is offline   Reply With Quote
Old 04-23-2017, 05:18 PM   #6
ChaosBlades
I do see now that they offer remote tuning. Perhaps this is something I can work out with them when the time comes. At least now I know the catless header is just going to throw a CEL code.
WTB Turbo and supporting mods OzzyGT86 Want-To-Buy Requests 2 08-26-2017 06:14 PM
E85, what are the best supporting mods? ProjectMidnight86 Engine, Exhaust, Transmission 9 06-25-2016 02:56 PM
What supporting Mods do you REALLY need? Adrian002 Forced Induction 27 05-09-2015 08:27 PM
Supporting Mods For F/I Applications Tansey86 Forced Induction 59 02-26-2013 01:42 AM
Supporting Mods Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 02-21-2012 05:33 PM
