Old 04-21-2017, 10:32 AM   #1
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Rake
Hey guys. I was wondering if anyone is running with a "raked" setup. I'm curious to see how it looks. Wanting to put a pretty meaty tire in the back, but nothing obnoxious. Post some pictures if you have them!
DaBoBo21 is offline   Reply With Quote
Old 04-21-2017, 10:43 AM   #2
Shady195
Drives: '13 10 Series FRS #1203
It will look silly.
Why are you only running a meaty tire in the rear? Are you drag racing? If so then what does it matter how it looks..
Also keep in mind that you change the weight distribution of the car doing something like this and it may not handle how you want.
I guess it all depends what the end goal here is.
Shady195 is offline   Reply With Quote
Old 04-21-2017, 10:45 AM   #3
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Like this?
I kid, I kid!
Ok, seriously though, what're your goals here? Are you going for just a look, or is there some performance intent here?
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 04-21-2017, 10:47 AM   #4
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
I'll be honest, I'm not 100% certain what direction to take. I am aware it will handle differently, and no I'm not looking to drag. Like I said, I'm not going for anything obnoxious. A subtle rake.
Old 04-21-2017, 10:50 AM   #5
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Originally Posted by Ryephile View Post
Like this?
I kid, I kid!
Lol, definitely not. I guess I'm going for more look, but nothing to the extent to take away the full nature of the car. I don't track it, nor do I plan to. It's my daily and I'm active at shows and meets.
Old 04-21-2017, 10:56 AM   #6
Shady195
Leave the car alone then. Not sure why you'd want any sort of rake?
Old 04-21-2017, 11:05 AM   #7
Ryephile
Hot Dog
Ryephile's Avatar
From a technical aspect, the last thing the car needs is proportionally more rear tire. It has a front weight bias, so it theoretically needs more front tire contact patch than rear.
If you were going for a bit of a California Rake aesthetic, perhaps a same width but taller aspect ratio might accomplish that without overly messing up the overall handling, but it certainly won't improve anything other than having that specific look.
What tires and wheels are you running now?
Same subject but a different take on it would be chassis rake, via changing the roll center axis. Lowering the front end or raising the rear would accomplish this, but whether it would help or hurt the handling is something I'd have to defer to the guys that have done the measurements and sorted it out on-track. Chassis rake is a useful and important handling tuning facet, I don't recommend changing it just for funsies.
Old 04-21-2017, 11:11 AM   #8
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Just going for something different, man. Not everything has to make sense.
I'm not going for a drag look. Just trying to see if anyone has ran with a slight rake on this platform. I'm looking at running with the Ambit RT5s and I believe I could pull off a slight rake with them.
Old 04-21-2017, 11:13 AM   #9
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
That all makes sense. Could you give me an example of "California Rake?"
Old 04-21-2017, 11:24 AM   #10
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I think most people run a little bit of rake on this car. I personally set my ride hide at about 5" from the ground to the pinch welds front and back. That way as the fuel gets lower and/or I remove the trunk junk, I can get a little bit of positive rake. I'm not a fan of the dead body in the trunk look.
smg1138 is offline   Reply With Quote
Old 04-21-2017, 11:32 AM   #11
Ryephile
Hot Dog
Ryephile's Avatar
That funny car picture I posted would be the most extreme example of California Rake. In traditional hot rodding it's simply running a taller rear tire to improve weight distribution during launch at the drag strip.
Old 04-21-2017, 11:54 AM   #12
Gunman
Drives: 2019 Mazda Miata RF
Slight rake is good for aero, basically makes the entire under body a large diffuser.
Old 04-21-2017, 11:55 AM   #13
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Do a reverse rake and have the front sit taller.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 04-21-2017, 12:49 PM   #14
Icecreamtruk
Drives: Track preped NA FRS
You trying to take off or something?
Icecreamtruk is offline   Reply With Quote
Best Steering Wheel Column for Feel - Rake and Reach brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-21-2015 09:24 PM
Lowered, but want thoughts on rake. DrDuquette Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 03-31-2014 10:49 PM
Rake TheseColorsDontRun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 09-03-2013 10:24 AM
