Old 04-17-2017, 11:51 AM   #1
JermMX5
Drives: 2017 Toyota 86
Project 2017 86 - C Street
Update 8/11/2017
So I've decided that I'm going to start slowly going towards STX because I really want some power parts for the street and for autocross, so that will be happening over the next few months and the bulk during the winter. Planned parts list will go down below soon.
Current State
  • Alignment - 1.2 up front, 2.4 in the rear, and 0 toe.
  • 20mm Whiteline front bar on stiff
  • Stock shocks with TRD springs
  • Custom muffler delete that is too loud most of the time
I finally found my self overwhelmed with everything that I needed to do to my STS Miata to get it competitive, and well...it was time for a new daily driver so that's when I bought this thing below!
I've decided to get it ready for C Street and decided I would document my journey for any one else to be able to replicate with the new 2017's. Below is my todo list with completed things marked accordingly:
  • Wheels and Tires - Done - O.Z. OMNIA 17x7.5 rims wrapped in 235/45/17 RE-71r's
  • TRD Lowering Springs - On order
  • Crash Bolts for camber - On Order
  • Alignment of max camber, 0 toe up front, and 1/8th toe in, in the rear - Waiting for above
  • Lightweight catback for weight savings and power ( Totally not just for the rumble) - Looking for input
  • Swaybar(s) - I can do one TRD and one aftermarket so I'm looking for input
Car is currently at 500 miles and I need another 500 before the event this Sunday so fingers crossed I can get the miles + all the camber stuff before then. Otherwise It will be bone stock with wheels and tires.
I have the part numbers for the crash bolts and nuts in my car and I'll grab those later to post in case anyone ever needs them.
JermMX5 is offline   Reply With Quote
Old 04-17-2017, 03:24 PM   #2
edj
edj's Avatar
Drives: 2022 Toyota GR86
Nameless Performance sells a Single exit muffled track pipe. It looks good and
only weighs 6 pounds. Worth a look.
Good luck with your build.
Eric
2022 Toyota GR86 Steel
edj is offline   Reply With Quote
Old 04-17-2017, 04:13 PM   #3
Biggins
Drives: Yes
Congrats, welcome! I doubt there will be many differences to your prep than those of us who prepped our 13-16 versions.
You might want to flip your camber settings though. I've always run a little toe out up front and a little toe-in or zero toe rear.
I'm in the camp that thinks almost any sway bar combo will work if you adjust your driving, pressures and shock settings accordingly. I'm still on the Perrin 19mm, but I'll finally switch to the TRD bars eventually, maybe... read through the existing CS thread because there are a lot of good tips/hints in there.
Biggins is offline   Reply With Quote
Old 04-17-2017, 05:53 PM   #4
JermMX5
This is exactly what I was looking for thanks!
The wheels and tires came in today and I test fitted them and I'm a little worried about the clearance. The TRD forged rims are 7.5 width but 42 offset and I got 7.5 with 48 offset and this is the distance between the tire and the spring perch:
It looks fine for now but once I get the additional camber I'm worried it will put me too close at the top, so I might pick up some 5mm spacers, unless anyone has some input.
The next issue is the lugs that came with the rims:
The holes in the rims are so small that I need to use this special spline tool, does anyone know of some extended lugs that will fit in there?
Overall the wheels look amazing though:
Old 04-17-2017, 06:08 PM   #5
scirocco78
Drives: Scion FRS
I said 1/8 toe IN on the rear.
No more than 5mm spacers on the front with stock wheel studs but if you can fit a credit card between the tire and the spring search you are good to go.
BTW the Perrin 19mm doesn't work at Devans. You need more front bar. 20mm adjustable White line or maybe even the 22.
Bill B.
scirocco78 is offline   Reply With Quote
Old 04-17-2017, 08:28 PM   #6
s203.22b
Drives: 2017 BRZ
Editing to remove incorrect info.
Last edited by s203.22b; 04-17-2017 at 09:40 PM. Reason: don't want to spread wrong info
s203.22b is offline   Reply With Quote
Old 04-17-2017, 08:47 PM   #7
dutchman1
Drives: 2017 86 6-Speed
Originally Posted by s203.22b View Post
I believe the 17x7.5 wheels will not be CS legal with your car, as it comes with 17x7.0 stock. Cannot change width. Only +/- 1" in diameter and +/- 7mm in offset.
Incorrect, because for the 2017's it specifies that the optional TRD wheels are legal. The dealer offered TRD rims for the 2017 86 are 17x7.5. You can go to build the car on the Toyota website and see the wheels, and you can look at the SCCA Solo rules and see the allowance for the TRD wheels in the class listings.
dutchman1 is offline   Reply With Quote
Old 04-17-2017, 09:40 PM   #8
s203.22b
Drives: 2017 BRZ
I stand corrected. They must have just updated that.
Old 04-17-2017, 10:18 PM   #9
JermMX5
Bill B.
Haha I'm glad you found me on here Bill! I would've been stuck with some bad alignment otherwise. And awesome I figured as long as there was some room I'd be fine, and I saw a thread where someone else was running 17x7.5 +55 with no issues so I'm less worried now.
I think I'll do the first event this weekend without the sway just so I'm not trying to get too much done in the few days I have and then I can try to figure out if i'll go 20mm or 22mm. What about Devans makes a 19 not work well? The higher speeds than other lots or just different courses?
And I'm considering returning the rims I got because of that stupid spline tool, the reading I've done has said that if I use impact tools on it (Like I would do every event) that the tool/lugs will get destroyed, so maybe I might just return them for some RPF1s, but I'm just worried about the strength of the RPF1s if I hit some bumps or a small pothole with them ever. Anyone with the RPF1s know?
Old 04-17-2017, 11:27 PM   #10
nico_rsx
Drives: BRZ 2017 Pure Red, MT
I've used those kind of lug/tool for some time. At least 2-3 years of Autox. 10 event per year. They are starting to show some wear, and would have needed to be changed if I didn't changed car.
I think that's not that bad. BTW, I used an impact with them all the time.
You can also get the kind of nut that stick out of the wheels holes. That's probably what I'll do with the BRZ.
You may have the same problem with the RPF1. The holes are really close to the edge of the recessed center (google a picture).
nico_rsx is offline   Reply With Quote
Old 04-17-2017, 11:30 PM   #11
JermMX5
I've been looking around for something exactly like what you're describing but I havn't had any luck, maybe I'm using the wrong search terms?
Old 04-18-2017, 12:54 AM   #12
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Extended Lug Nuts
Gorilla brand is relatively affordable and easy to find on Amazon. Beware the longer ones may require a deep socket to get on and off which may be a bit inconvenient.
ineedyourdiddly
Old 04-18-2017, 02:44 AM   #13
pinoy_dorifto
Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
Let me know what camber you get on the rear after the trd springs installed, my right rear was off, around -2.7 and the left side was about -2.3.
I.G. @mytoy86
pinoy_dorifto is offline   Reply With Quote
Old 04-18-2017, 08:19 AM   #14
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
TRD offers both 7.5" and 7" wheels on their website, but when I try to "build" an 86 on the toyota website, It only has a single TRD wheel "package".
Is that a staggered wheel package they offer? What does the car come with if I select that package?
*edit* Found this on the TRD site's description for both wheels:
PRODUCT DESCRIPTION
18-in. x 7-in. front and 18-in. x 7.5-in. rear staggered fit; (both with 35-mm. offset, a 5-on-100-mm. bolt circle [P.C.D.] and a 56-mm. center bore) cast alloy wheels designed specifically for the vehicle
http://www.trdusa.com/parts-detail.h...categories=all
Twinz is offline   Reply With Quote
Review: Project Mu HC+ 800 Street/Track Pads spitz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 65 11-30-2019 01:58 PM
C Street Guys with 2017 PP What size tires? imnotsureaboutbrz Tracking / Autocross / HPDE / Drifting 19 04-15-2017 11:21 AM
Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift ModinJapan Southern California 1 01-25-2017 12:46 AM
Tein Street Flex/Bridgestone Summers 18in/Project Kics/Morimoto HID Kit CreinCrein Canada Classifieds 23 04-15-2016 10:06 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
