Old 04-13-2017, 12:26 PM   #71
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
There are many threads on how to change the plugs without lifting the engine. With the right tools and girlie hands it is tricky but can be done.
Yea just figured it out, the birds have to chirp, the sun has to be up and u have to have your tounge on the roof of your mouth.
On a second note...do not follow the full race spark plug guide. They tell u to put a ngk bkr9eix plug in...but that plug has a 14mm thread pitch and stock is 12mm. FML AND FU FULL RACE!!!
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
The Following User Says Thank You to sosick For This Useful Post:
Tcoat (04-13-2017)
Old 04-13-2017, 02:39 PM   #72
empower-auto
Kouki-Monster
empower-auto's Avatar
Originally Posted by whitefrs View Post
Great info by @2forme
First thing -- the OEM plug is a 9 heat range plug.
Next, you don't NEED to change it by your rule.
I'm 150+ whp over stock and on an HKS plug in the OEM 9 heat range -- no issues.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 04-15-2017, 09:53 PM   #73
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Sorry I have to chime in on this. Just heads up everyone. When boosting my Hayabusa I have to change my gap to .020 Also noted the WRX plug gap is .020
So why the %#$@ would we keep the gap at a wide .032??? This miss leading information can cause misfires, knocks and loss of horse power. Tuners will not share this information as they want you to use them. $$$$
As well... the BRZ fa20 motor is nothing more than an engine, please study gap to boost recommendations a crossed all boosted cars and bikes. You will learn something.
factory plugs gapped correctly will reduce knock and save your plugs, engine and give your car more balls.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 05-01-2017, 03:58 PM   #74
Amputechture
Drives: 2014 BRZ
Mind if I inquire what gaps you are running? I hear so many different things and not sure what exactly is misinformation. I know that sounds lazy of me to be spoon-fed an answer...if you could even point me in the direction of some sort of credible material to read up on I would appreciate it.
Amputechture is offline   Reply With Quote
Old 05-02-2017, 08:53 AM   #75
GsxrMe
GsxrMe's Avatar
.024 w/ OEM dealer plugs. I really wish we had an access panel in the wheelwell, the sparkplug swap is a huge pain in the ass.
2014 Subaru BRZ
Old 01-11-2018, 07:58 AM   #76
Glenncoco
Drives: Ultramarine
Any one have the hks v3 kit. And use the 50003-M50HL spark plugs. Did you set the gap same as the stock plugs
Sent from my SM-N950U using Tapatalk
Glenncoco is offline   Reply With Quote
Old 01-11-2018, 02:14 PM   #77
Amputechture
Drives: 2014 BRZ
I am running a turbo set-up, but I am using those same plugs. They are pre-set to .028 if I remember correctly, and it is recommended to leave them there at the default gap.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
Old 01-11-2018, 02:25 PM   #78
Glenncoco
Drives: Ultramarine
Okay awesome and do you know what the stock ones were set at.
Old 01-11-2018, 02:46 PM   #79
Amputechture
Drives: 2014 BRZ
Old 01-11-2018, 03:11 PM   #80
Glenncoco
Drives: Ultramarine
.032
Okay awesome thanks bud.
Old 01-11-2018, 04:44 PM   #81
Amputechture
Drives: 2014 BRZ
You're welcome. Good luck with your build!
Old 01-11-2018, 05:07 PM   #82
Glenncoco
Drives: Ultramarine
Thanks. And good luck to you too
Old 05-04-2018, 04:23 PM   #83
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I am around 60k miles and was going to swap plugs when I install my Harrop SC. I was thinking of going with the OEM plugs, but gapped smaller. I don't know what would be ideal, but it sounds like it could be anything between 0.020 to the stock 0.032. I will be at 11psi. If anyone has any suggestions that would be great. I know some have kept the stock heat range, or the stock plugs, or the stock gap. Seems like 0.026 on the stock plugs would be a good compromise.
Also, I have some of these which I think would make getting to the spark plugs easier:
https://www.harborfreight.com/3-piec...aps-67011.html
Old 05-04-2018, 07:17 PM   #84
FRS Justin
Drives: 2013 Asphalt FRS
710whp for a couple of years stock plugs no problem
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
Irace86.2.0 (05-04-2018)
spark plugs change... fistpoint Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 53 02-23-2022 09:37 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 11:24 AM
Where do these plugs go from? Z3D BRZ First-Gen (2012+) — General Topics 10 02-18-2013 10:59 AM
Car won't start, no spark? #87 Other Vehicles & General Automotive Discussions 5 12-19-2011 12:29 PM
Jowett Jupiter/spark plugs aspera Engine, Exhaust, Transmission 6 02-25-2010 05:47 PM
