Old 04-12-2017, 01:34 PM   #393
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by ILLSMOQ View Post
I'm sure there are some circumstances where this radium setup could be less effective but it definitely appears to be better than the stock setup.
I could build a box with check valves around the stock fuel pump housing and have it be just as effective...but this unit looks clean and will save me from engineering my own.
You have a pump in the other side of the saddle tank right?
Friend told me fuel starvation was a big problem in any saddle tank configuration community when you up demands with higher horsepower over OEM, simply adding another pump in the non-pump side with both feeding the engine is a fool proof cure, it has been for me....Haven't had one fuel starve issue.....My fuel return line which isn't OEM as we are return less, feeds the bucket on the driver side......Both pumps feed into a Y that feeds the engine.....There is actual dual pump kits for the BMW guys.Either one of my pumps can independently supply the 60psi pressure to run my LS which is set by the pressure regulator.
cf6mech is offline   Reply With Quote
Old 04-12-2017, 04:13 PM   #394
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Hey @cf6mech. Any chance you know What the choke diameter is on the headers from Vorshlag?
The Four Pipes merge into one and it's smaller than 3". It then expands into 3".
I am seeing this quite a bit as I am looking at collectors. Starting to think just cutting the headers at the end of the merge and transitioning to 3" may be the way to go instead of just trying to make it 3" straight off the bat.
I.E. 1 7/8 to 2.5" Merge to 3" Outlet From Vibrant
Old 04-12-2017, 07:53 PM   #395
cf6mech
Not really sure Dustin, would have to get underneath the car to check it out.
Old 04-13-2017, 10:14 AM   #396
DustinS
DustinS's Avatar
Fuel Components came in. Still waiting on the FPR by-Pass which is due for delivery Saturday, and fuel line which is suppose to ship first of next month (summit doesn't seem to stock Vibrant Hose). With the 25' I have should cover a feed and return set-up. Few other things trickling in.
Lots of Vibrant fittings.
Old 04-13-2017, 10:28 AM   #397
Dialkyl
Drives: Silver 2013 Subaru BRZ
This thread is so interesting to follow. Thanks for all the updates @DustinS
Dialkyl is offline   Reply With Quote
Old 04-13-2017, 10:36 AM   #398
ILLSMOQ
Drives: 2017 WR BLUE BRZ
You could open up a speed shop with all the stuff you have in your inventory haha!!
ILLSMOQ is offline   Reply With Quote
Old 04-13-2017, 10:48 AM   #399
DustinS
DustinS's Avatar
I have always wanted to open a speed shop. Might be what I do if my trans never comes in
Old 04-13-2017, 11:04 AM   #400
Dialkyl
Old 04-13-2017, 11:06 AM   #401
DustinS
DustinS's Avatar
Originally Posted by Dialkyl View Post
5 months on Saturday. And they are on the shelf apparently.
Old 04-14-2017, 10:11 AM   #402
DustinS
DustinS's Avatar
Well. One of the final pieces of the puzzle.
So excited
Also. Hood pins and trans tunnel wrap came in.
Old 04-14-2017, 11:46 AM   #403
DustinS
DustinS's Avatar
Oh S***. Good Friday has been amazing....
Old 04-14-2017, 11:53 AM   #404
Dialkyl
Its happening!
Old 04-14-2017, 12:01 PM   #405
ILLSMOQ
Dooood! And I was about to offer you my set of mounts so you could get the project moving!
Now we get to see this project move into top gear!
Old 04-14-2017, 12:03 PM   #406
DustinS
DustinS's Avatar
That is a giant offer. I would have politely declined, but that is nuts.
Any idea on when you start yours? Engine is still a couple weeks out if it was anything like mine.
Edit: Realized I never posted the pictures for the Clutch master cylinder (At least I couldn't find them)
Difference in length and thread pitch
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
