#16 |
Drives: UK GT86
You should be able to log AVCS commanded, however at idle it should be 0 degrees.
Did the cams get timed correctly when it was put back together? That's the obvious issue and may need checking. If it's not that then I'd guess something is preventing oil flow to the solenoid to give it control. The fact the engine has been apart and is running poorly suggests it's going to be mechanical.
.: Stealth 86 :.
#17 | |
Drives: RHD Gt86
My mechanic took off the front cover and back checked the timing and said it is correct. I will be speaking with my mechanic about looking into taking the engine back out and atleast check the internals and also make sure no oil ports are being blocked
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
#18 |
Drives: RHD Gt86
Would be tuner be able to pick this up through the log I sent him?
#19 |
Drives: '15 Subaru BRZ
I'd bet the chain is on wrong. It's also possible to install the cam sprockets incorrectly. They have a nipple on the back side to locate them properly but if you just run the bolts in anyway they bolt on.
| The Following User Says Thank You to Ragin Gti For This Useful Post: | Kris86 (04-10-2017) |
#20 | |
Drives: RHD Gt86
Calling my mechanic right now to mention this
#21 | |
Drives: FT86
As kodename47 said it's most likely mechanical issue. It's often difficult to detect from logs if it's mechanical issue. Best way would be to log a car with same calibration I'd ecu and confirm it logs ok |
#22 |
Drives: UK GT86
If you're logging using the supplied tune that is flashed to the car, this isn't the issue. As Steve said, it wouldn't tie in with the poor running anyway.
.: Stealth 86 :.
#23 | |
Drives: RHD Gt86
I have already got and replaced the cam sprocket :-S
#24 |
Drives: RHD Gt86
any ideas as to what all mechanically I can look for?
#25 | |
Drives: RHD Gt86
anything else I can have a look at?
#26 | |
Drives: RHD Gt86
so does this mean I dont have a oil pressure issue u think? or can lack of oil still cause this
#27 | ||
Drives: UK GT86
.: Stealth 86 :.
#28 | |
Drives: RHD Gt86
Yes these are the same stock cams and cam sprockets that came on the motor that were reused, up until this past weekend when I got another sprocket from the U.S and changed it to see if anything changes, got the very same result
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission Last edited by Kris86; 04-11-2017 at 07:25 PM. |
| AVCS - Intake and Exhaust Timing | Kodename47 | Software Tuning | 274 | 02-28-2021 12:39 PM |
| AVCS Explained | Rennmeister | Engine, Exhaust, Transmission | 3 | 03-15-2016 04:12 AM |
| AVCS tuning | Turdinator | Software Tuning | 9 | 11-24-2015 02:31 PM |
| P000A AVCS check engline light? | cookiesowns | Issues | Warranty | Recalls / TSB | 4 | 10-24-2015 02:48 AM |
| AVCS failures? | hmong337 | Forced Induction | 26 | 02-12-2015 04:01 PM |
