Old 04-05-2017, 05:44 PM   #15
CSG Mike
CSG Mike's Avatar
Have you aligned the car?
Old 04-10-2017, 11:37 AM   #16
Chronology
Drives: 13' Satin White Pearl BRZ
Originally Posted by TrqlessWonder View Post
All that stiffness should just make the car unpleasant. It's still the tires doing the work, and they've got springs and shocks in between them and all that bracing.
Which I think is what you'll find to be the likely issue. You swapped out all of your suspension bits, for fancy ride-height adjustable coilovers during that flurry, and then proceeded to not align it or set the ride height correctly. That needs to be job numero uno after doing that.
Do that first, and just for everyone, this alignment isn't a job for your local MidAdvanceZoneBoys chain garage. If they aren't asking you what settings you're looking for, it's not the right shop. If they even seem hesitant about adjusting outside of what the computer says, it's not the right shop.
Sorry just got back to this post.
I have personally enjoyed "stiff" cars. Just my style I guess. I did have an initial alignment done. At this point, once the tires/rims come in ill get the 4 corner balance.
The shop I went to has/had/and does performance alignments, we started off with "stock" numbers, adjusted for my requirements, the car goes where it's pointed, had 4-5 buds drive it on the track and the comment I got was "dude get rid of the $h!t tires".
Ride height was adjusted
Toe was adjusted
camber was adjusted
**Note all the alignments were done on USED (My own use) stock tires, even the alignment shop told me to come back after getting new tires to "finish" the job correctly.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
Old 04-10-2017, 11:40 AM   #17
Chronology
Yes Sir. WestEnd did the initial setup, going back for the 4 corner after new tires and rims.
Old 04-10-2017, 11:41 AM   #18
Chronology
Originally Posted by redlined600 View Post
Start with the cheapest easiest things first
-Alignment (if you haven't)
-Re-zero the Stability system (google zero setpoint or something to that effect)
Then see where you're at.
I think we can all agree you're not actually breaking traction in 5th, 4th and probably 3rd in a straight line.
100% Agree - I did the alignment, I need to do the Re-zero I just figured I would wait till new parts come in.
I definitely do not have the power to break 3rd/4t/5th lol. I know it's a misread from a sensor, configuration.
Old 04-10-2017, 02:15 PM   #19
TrqlessWonder
Drives: 2014 FR-S
Toe was adjusted
camber was adjusted
I'd highlight the specific parts of the post that give that away, but it's pretty much the whole passage.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 04-10-2017, 04:18 PM   #20
Chronology
Sorry don't mean to be dense but I don't understand your question.
Old 04-10-2017, 05:36 PM   #21
CSG Mike
CSG Mike's Avatar
Can you get me a datalog when the TCS is going off?
Old 04-11-2017, 04:17 PM   #22
TrqlessWonder
Drives: 2014 FR-S
Perhaps a bit harsh. But, the idea is that, with that info and some in your other posts, I don't think you can say that you did in fact get that alignment. You might think you did, you might have paid for one, but you didn't actually receive one. All of those things you report they adjusted? That should show what they were adjusted to. Not "stock" plus "adjustments for your requirements" Actual numbers on a printout. A specification.
The tires don't have anything to do with what direction the wheels are pointed. They're just along for the ride.
-Mike
#24 CS/CSR
Old 04-11-2017, 05:07 PM   #23
Chronology
I get what you are saying. The reason why the details on camber,toe,caster were not added to my post was: I didn't have the actual sheet with the #'s and I didn't know that I should really add them to have a well-posted question. I personally feel there are better ways to point that out, and I am not a 17 year old with mom and dad money who goes to Jiffy Lube for an alignment.
West End is a widely known shop in SoCal that deals with a variety of cars, grocery getters to SLS MB's and tracked Porches. I'm pretty sure I picked a solid place since even Matt Farah takes his personal cars to West End. https://www.instagram.com/explore/lo...end-alignment/
What I think I remember is that the camber, and toe where adjusted including ride height from memory I am -1 camber all around with a 0 deg toe, I'll update my original post with the data from the sheet once I am home.
Saying that - I'll have the tires/rims on this week, have the shop check the alignment and ride height and update this post with more detailed information.
Issues - Traction control and ABS warning light on G86 Issues | Warranty | Recalls / TSB 109 10-17-2021 04:32 PM
Staggered tires can cause over-active traction control issues KoolBRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 12-23-2015 02:01 PM
Abs and Traction Control Issues Phothiraj BRZ First-Gen (2012+) — General Topics 4 07-23-2015 10:51 AM
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
