Old 07-21-2015, 11:34 AM   #1
Phothiraj
Drives: Lightning Red BRZ
Abs and Traction Control Issues
Recently installed coilovers a few months ago and just started having issues with the ABS and Traction control light. It only happens when I drive longer distances like 25Miles+ then my abs light and traction control light would come on and then my cruise control would not also work. Would this be an issue due to the coilovers? When i turn the car back off then on the lights go away and start functioning again until i start driving the long distances again.
Phothiraj is offline   Reply With Quote
Old 07-21-2015, 12:34 PM   #2
fika84
fika84's Avatar
Hrmmm... have you gotten an alignment?
EDIT: There are lots of threads about this stuff too.. https://www.google.com/search?safe=o....0.wLeie1lbYlc
fika84 is offline   Reply With Quote
Old 07-22-2015, 06:23 AM   #3
Talus1
Talus1's Avatar
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
I do crunches every morning so my abs are great. Too much beer to be ripped, though.
Anything worth doing is worth doing twice...
Talus1 is offline   Reply With Quote
Old 07-22-2015, 12:48 PM   #4
kch
Senior Misanthrope
kch's Avatar
I've heard that changing the rake of the car (difference in ride height between front/back) can mess with the sensors and set off some lights. Check that.
Old 07-23-2015, 10:51 AM   #5
jinyang1590
Drives: 2015 BRZ WRB
In my experience, traction control, ABS, Cruise Control, are all controlled by your brake or ABS module. Either your ABS or Brake module has gone bad, or your wheel speed sensor has gone bad(the wheel speed sensors relay wheel speed information to your ABS or Brake module). You might have knocked a wheel speed sensor out of spec while installing your coilovers. Hope this helps.
jinyang1590 is offline   Reply With Quote
Issues - Traction control and ABS warning light on G86 Issues | Warranty | Recalls / TSB 109 10-17-2021 04:32 PM
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Traction Control vs. Stabilization Control vs. Sport Question MurderRider Scion FR-S / Toyota 86 GT86 General Forum 26 08-07-2014 12:56 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 03:28 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
