Old 04-07-2017, 04:51 PM   #1
lupindub
Drives: Scion FR-S
Any DIY fix for leaking window seal?
So I noticed when it is very cold and starts to rain, the rubber weather strip shrinks and let's in some water into the inside of the car.
I just called Toyota and they quoted me approximately $300 for labor + parts to replace the weather strip on both sides of the car.
I am wondering if there is a cheaper DIY fix for this problem.
Thanks in advance.
lupindub is offline   Reply With Quote
Old 04-07-2017, 08:07 PM   #2
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
If I remember correctly, the outer gasket has a void tword the outside, you could try pulling that back and stuffing some weather stripping foam or something at that trim peace. I can't remember which, but I was told that a 4 or 8 gauge lenght of wire will fit in it, which was used to keep the seal from rolling over and bunching when rolling up the window. (an issue for some earler cars)
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
The Following 2 Users Say Thank You to Target70 For This Useful Post:
lupindub (04-07-2017), Tcoat (04-08-2017)
Old 04-07-2017, 10:42 PM   #3
lupindub
Drives: Scion FR-S
Just went to Home Depot and bought me some backer rod's thanks to your suggestion. Just killed two birds with one stone - fixed the seal from rolling up and fixed the leak near the A-pillar. We'll see how it holds up - especially when it gets cold and starts to rain again.
The Following 2 Users Say Thank You to lupindub For This Useful Post:
Djratrap (04-03-2018), Tcoat (04-08-2017)
Old 04-08-2017, 04:06 PM   #4
Target70
Target70's Avatar
It stopped the leak? If so, I hope it keeps working for you. I found a post similar to the one I mentioned in case anyone else has the same problem
Originally Posted by jeffchap View Post
Mine was rolling up and causing a gap at the top rear corner of the window, and the wind whistled thru it at highway speeds. Here's my redneck fix...
I cut a 6" piece of coax I had lying around and slipped it into the channel in the top of the seal right where it rolled over. No more rolling, and it's invisible and free.
CatDaddysBBQ (04-10-2017), soulreapersteve (04-08-2017)
Old 04-08-2017, 11:01 PM   #5
lupindub
Drives: Scion FR-S
I gave the A-pillar area of my window a good 20 sprays of water and so far its not leaking. Usually only leaks when its really cold though so we will see.
Old 04-13-2017, 06:59 PM   #6
Scourge
Agent 86
Drives: 2017 Toyota 86
I don't know if this will help but a lot of Honda guys swear on this stuff called Shin-Etsu to restore seals. But our seals would be fairly new so I don't know...
Scourge is offline   Reply With Quote
Old 04-03-2018, 04:22 PM   #7
Djratrap
Drives: BRZ CSB Limited
Bought backer rod to fix the seal, great stuff. I used that in combination with rubber cement and it worked like a charm. No leaks or whistling (decided to do something about after a no touch car wash). Not bad for a 5 dollar fix, great tip!
Djratrap is offline   Reply With Quote
Old 04-03-2018, 04:26 PM   #8
Ghost of Akina
Ghost of Akina's Avatar
Drives: DE5 Integra Type S
Just don't do this...
https://www.bing.com/images/search?v...x=2&ajaxhist=0
"Precision without speed is empty, speed without precision, chaos."
Ghost of Akina is offline   Reply With Quote
Old 04-03-2018, 09:11 PM   #9
darko
Drives: RAVEN FRS
Originally Posted by Ghost of Akina View Post
haven't seen a bing link in a LONG time
darko is offline   Reply With Quote
Old 04-03-2018, 09:28 PM   #10
Ghost of Akina
Lol yeah for some reason that is the default search engine on my work computer.
Just gave away I was on the forums instead working shhh dont tell anyone
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Drivers window grabbing window seal and pushing it up. stockysnail Issues | Warranty | Recalls / TSB 22 12-22-2015 01:08 PM
window seal deforming mokinbird87 Issues | Warranty | Recalls / TSB 33 10-31-2014 05:14 PM
window seal? ravenblackfrs Issues | Warranty | Recalls / TSB 3 01-29-2014 05:12 PM
AT Transmission rear seal leaking. CircuitJerk Issues | Warranty | Recalls / TSB 6 10-31-2013 03:41 PM
