Old 04-07-2017, 12:29 PM   #1
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Creaking Chassis?
Hey all,
The last couple months I've noticed creaking in what sounds like the suspension or maybe even the chassis. I only truly notice it when going slow over bumps and uneven surfaces. I have TRD springs which I put on over a year ago. Double checked the bolts, and everything is tight. Any ideas?
MS, CSCS, TSAC-F, CPT
Old 04-07-2017, 12:36 PM   #2
jasonojordan
Drives: 2013 satin white brz limited
Let me know what you find. I have a case where when I rotate my steering at slow speeds/stopped I get a creaking sound. Has been that way since shortly after buying it new.
jasonojordan is offline   Reply With Quote
Old 04-07-2017, 01:14 PM   #3
evomike
Drives: frs
its a cheap car its going to creak and make noises
evomike is offline   Reply With Quote
Old 04-07-2017, 03:58 PM   #4
weederr33
weederr33's Avatar
True it's cheap. However, this developed in the last couple months. Before it was fine. It's not a pressing issue tbh, I'm just curious what it is.
Old 04-07-2017, 09:38 PM   #5
Maybe the coils are squeaking against the spring perches. If so, a squirt of oil may stop the squeaking ...... fer sure.
Creaking noise from overpipe sydious Engine, Exhaust, Transmission 4 06-27-2018 03:13 AM
Creaking After Sway Bar Install Prmspen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 02-08-2017 07:36 PM
Sway Bar Creaking smg1138 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-16-2015 02:28 PM
Creaking during turning after coilovers? Rifle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-10-2015 01:51 PM
Seats creaking Wes Issues | Warranty | Recalls / TSB 28 06-15-2014 07:19 PM
