Old 02-08-2017, 03:33 PM   #1
Prmspen
Student Driver
Prmspen's Avatar
Drives: 2016 Subaru BRZ Limited
Creaking After Sway Bar Install
I installed the Perrin 19mm adjustable front sway bar a couple of weeks ago, and now I'm getting a creaking noise from the front of the car. It's not too loud, and only happens sporadically. I can't pin it down to a specific cause (turning left, right, bumps, etc.). Does anyone know what could be causing it?
I installed by removing the two chassis members as described in this install, and followed the torque specs it gave when reassembling.
http://www.ft86club.com/forums/showthread.php?t=39003
Prmspen is offline   Reply With Quote
Old 02-08-2017, 04:01 PM   #2
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Sorry if this sounds too obvious, but did you remember to lube the bushings? I've found if you don't lube every surface of the bushing, you can get squeaks.
smg1138 is offline   Reply With Quote
Old 02-08-2017, 04:02 PM   #3
jasonojordan
Drives: 2013 satin white brz limited
Let me know what you find. My brz does this as well but only turning left and right and at low speeds. Sounds like the power steering is creaking but never could figure out of thats what it was or what was going on.
jasonojordan is offline   Reply With Quote
Old 02-08-2017, 04:09 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
Wild guess but maybe loosen and then re-torque the fasteners for those sub-frame stabilizers while the wheels are loaded.
Old 02-08-2017, 05:26 PM   #5
Prmspen
Student Driver
Prmspen's Avatar
I lubed extensively where the bar goes through the bushings. I didn't lube where the bushings meet the brackets, but that seemed to have a decent amount of lube on it already. Maybe I should have added more.
Old 02-08-2017, 05:28 PM   #6
Prmspen
Student Driver
Prmspen's Avatar
That could be worth a try. I'll have to hit up someone in our PDX/Vantucky group who has ramps so I can get under the car while the wheels are loaded.
Old 02-08-2017, 06:34 PM   #7
norcalpb
norcalpb's Avatar
Adding a stiff front sway bar sometimes makes the top hats come loose. Worth a shot.
The Following User Says Thank You to norcalpb For This Useful Post:
Prmspen (02-08-2017)
Old 02-08-2017, 06:36 PM   #8
Ultramaroon
not playing cards
Always welcome at Ultra's Junkyard. <Theme to Sanford & Son plays in background>
Sway Bar Creaking smg1138 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-16-2015 01:28 PM
Creaking during turning after coilovers? Rifle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-10-2015 12:51 PM
Say no to SWAY with our Anti-Sway Bar and Sway Bar Bushing Special. FRSport.com Brakes, Suspension, Chassis 0 01-23-2015 12:38 PM
Install time trd sway bars? Frs32907 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-28-2014 12:11 PM
Seats creaking Wes Issues | Warranty | Recalls / TSB 28 06-15-2014 06:19 PM
