Old 04-04-2017, 06:24 PM   #15
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
The longest I've gone before changing my oil was nearly 8k miles. But I try to stick to around 6-7k miles.
MS, CSCS, TSAC-F, CPT
Old 04-04-2017, 07:13 PM   #16
extrashaky
Drives: 2014 BRZ Limited
Based on the TBN I got in my first oil analysis, I would expect the Subaru branded 0W20 to reliably go about 11K to 12K. However, I'm still changing mine on 7500 mile intervals to stay well within the safety margins and to keep there from being any warranty questions when my engine blows up again.
Originally Posted by MuseChaser View Post
I've been going about every 5k miles on this car since I drive a lot of highway miles; my wife's nothin'-but-local short trips vehicle gets the 3k mile treatment. It ain't fear, it's caution, and probably over-caution, but I'm OK with that.
You can actually increase wear by changing your oil too often. New oil has a period in which the volatiles are being burned out of it. The breakdown of the volatiles results in sludge and deposits. Then you hit a sweet spot of several thousand miles in which the volatiles have stabilized and the detergents in the additive package do their thing of cleaning up any deposits left behind.
If you change your oil too often, the only part of the cycle you get is where crap is being deposited into your motor. Back in the 70s you didn't have much choice because the additive package would run out after 3K to 5K miles. However, now that the detergents have gotten so good, the sweet spot is considerably longer.
That's one thing that makes the UOA so handy. With a TBN added to your analysis, you can see how well your oil is doing, and it provides a lot of comfort around the longer oil change intervals. I usually only get a TBN if I'm using a new oil I haven't used before.
Out of curiousity, what's an oil analysis cost? Never had one done, but you've inspired me...
As was noted above, the basic test is $28, but you also have to consider shipping cost. I sent my first sample via USPS in the provided mailer bottle, and the idiots at the local post office stuck it on a shelf for a month because they didn't know what to do with it and didn't actually send it until I got my local postmaster involved. Now I put the whole mailer bottle inside a padded envelope and send it UPS. It costs more, but at least I know it will get there.
Additionally, the way most people take their sample is to hold the collection bottle in the oil stream as the oil is being drained. Obviously you can't do that if you have your oil changed at the dealership. You can get a service tech to collect your sample for you, but you can't be sure they'll get it right and not contaminate it. I solved that problem by purchasing the $35 vacuum pump from Blackstone so I can pull the sample through the dipstick tube before taking the vehicle in for service.
Originally Posted by bababooey View Post
for those that go a bit longer than the various manufacturer mileage recommendations,
are you changing the oil filter sooner than the oil? example being changed oil @ 8k but filter @ 4k & 8k?
The UOA can help you decide whether you need to do that. Blackstone actually commented on how well the Subaru filters on the BRZ are working at 7500 mile intervals.
The Following User Says Thank You to extrashaky For This Useful Post:
MuseChaser (04-04-2017)
Old 04-04-2017, 08:04 PM   #17
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
If you change your oil too often, the only part of the cycle you get is where crap is being deposited into your motor. Back in the 70s you didn't have much choice because the additive package would run out after 3K to 5K miles. However, now that the detergents have gotten so good, the sweet spot is considerably longer....
That's a totally new one on me. As a lifelong "trust but verify" guy, I'm going to bounce that off a couple local guys who know a WHOLE lot more than I do and will report back. I find it hard to believe that fresh oil is somehow more damaging to your engine than oil that has been utilized for several thousand miles, but hey, I'm open to being edumacated.
Thanks for the response.
Barry
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 04-05-2017, 09:23 AM   #18
bababooey
Drives: BRZ SWP Limited -6MT
above is my exact situation as well.
it piques my interest reading all the oil analysis reporting okay beyond 10k, i just havent taken that gamble yet.
bababooey is offline   Reply With Quote
Old 04-05-2017, 12:51 PM   #19
extrashaky
Some of the diesel truck drivers are running Rotella synthetic 25K or 30K miles without losing any effectiveness in the lubrication (at least according to their UOAs). As long as you have good filtration, modern motor oil can last a pretty long time. Once upon a time the filters were not as good, the oil was not as good and the detergent was not as good, so the volatiles were the least of your worries. Now that conventional wisdom has been upended.
Old 04-05-2017, 07:41 PM   #20
Chronology
Drives: 13' Satin White Pearl BRZ
Originally Posted by LXXXV1 View Post
Anyone care to chime in on length of time between oil changes? Currently at 15k miles in 3 years. I know...poor car
So Cal and 626? The yolo is real for the 626 guys. LOL /s
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
Old 04-05-2017, 11:47 PM   #21
LXXXV1
LXXXV1's Avatar
Drives: 2014 FR-S Monogram, Whiteout 6MT
You could probably go another couple years...
or...
you could change your oil every 6 months/7500 miles and take one worry off your list.. unless you don't worry...
That's what I've been doing, every 6 months**. But then my research shows me that changing too frequently can be bad bc of the breakin period...
wut?
2007 Honda CBR600RR-Pearl White/Silver - Totaled
2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build)
φφκα
LXXXV1 is offline   Reply With Quote
Old 04-18-2017, 01:50 AM   #22
Vince526BRZ
Drives: Subaru BRZ
Switch to Amsoil and you could go to 25k or more on an oil change. The stuff is amazing.
Vince526BRZ is offline   Reply With Quote
Old 04-18-2017, 08:09 AM   #23
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
25k? Got any proof on that?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 04-18-2017, 09:29 AM   #24
Lantana frs
Drives: 13 frs red
Why not just stick to 5k intervals? Imo stretching it out is penny wisdom/pound foolishness.
Lantana frs is offline   Reply With Quote
Old 04-18-2017, 09:39 AM   #25
8RZ
The Gunshine State
8RZ's Avatar
Because even the factory says 7500 is ok. My car is mostly stock so I'll adhere to that schedule.
Current DD: M235i
Old 04-18-2017, 10:15 AM   #26
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
When the motor has consumed a quart, change it. I keep the level topped off but when the bottle is empty, I change the oil soon after. Consumption increases with rpms, as it should.
thomasmryan is offline   Reply With Quote
Old 04-18-2017, 10:29 AM   #27
Shady195
Drives: '13 10 Series FRS #1203
Because there is factual evidence you don't need to.
Modern engines, and the fluids that go in them have come a long way. Go look at the oil change intervals on a modern Lamborghini, they use off the shelf oil from Castrol.
They recommend oil changes at up to 10-20K miles, thats more than most lambo owners will ever put on their cars.
Its not about penny pinching, but why change your oil 2-3-4kmi's early if you dont need to?
Shady195 is offline   Reply With Quote
Old 04-19-2017, 10:17 AM   #28
radroach
Drives: car
All I know is that I feel way more scrape / wobble / slap on cold start (30-40*) with old (4000) mile oil more than I do on fresh oil. On ignition you can feel the friction. That's enough evidence for me. I say change it before 5000 miles.
Oil Analysis - 1st oil change R L Newb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 375 11-19-2021 09:24 AM
BRZ MPG Data Analysis housecat BRZ First-Gen (2012+) — General Topics 30 02-14-2016 08:32 PM
MatLab log analysis ztan Software Tuning 12 12-02-2014 07:19 PM
Used Oil Analysis Results Captain Snooze Engine, Exhaust, Transmission 2 11-21-2013 12:59 PM
