Old 04-04-2017, 10:09 AM   #1
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Used Oil Analysis @ 51k miles
Clean bill of health! I'm happy with the results so far (mostly stock engine, just intake/exhaust, driven hard lol). Sample taken after 6k miles, great TBN so I'll change it at 8k next time.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 3 Users Say Thank You to 8RZ For This Useful Post:
Chimera (04-04-2017), Kaotic Lazagna (04-04-2017), Lantana frs (04-04-2017)
Old 04-04-2017, 11:16 AM   #2
Th3rdSun
Drives: 2013 FR-S MT Hot Lava
Wait,you're not changing after 3k miles like everyone else that's scared to actually follow the manual recommendation of changing after 7500 miles?
Th3rdSun is offline   Reply With Quote
The Following 9 Users Say Thank You to Th3rdSun For This Useful Post:
8RZ (04-04-2017), Cole (04-04-2017), Guff (04-19-2017), Hoahao (04-04-2017), kakacarrotcake (04-04-2017), Qadthane (04-05-2017), soulreapersteve (04-18-2017), strat61caster (04-04-2017), Tcoat (04-04-2017)
Old 04-04-2017, 12:14 PM   #3
kakacarrotcake
kakacarrotcake's Avatar
Drives: Man
Send a message via ICQ to kakacarrotcake Send a message via AIM to kakacarrotcake Send a message via Yahoo to kakacarrotcake
Gasp!
kakacarrotcake is offline   Reply With Quote
Old 04-04-2017, 12:25 PM   #4
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
Very nice. I've been going about every 5k miles on this car since I drive a lot of highway miles; my wife's nothin'-but-local short trips vehicle gets the 3k mile treatment. It ain't fear, it's caution, and probably over-caution, but I'm OK with that. I take enough chances in other aspects of my life..
Out of curiousity, what's an oil analysis cost? Never had one done, but you've inspired me...
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 04-04-2017, 12:27 PM   #5
radroach
Drives: car
@Th3rdSun the maintenance schedule was revised to change around 5000 miles. I'd go with the newer recommendation.
Old 04-04-2017, 12:30 PM   #6
strat61caster
strat61caster's Avatar
No it wasn't.
Here's the 2017 manuals:
http://www.toyota.com/owners/resourc...anuals/86/2017
Straight to the PDF, p.38 has 7.5k miles/months for oil and filter replacement:
http://www.toyota.com/t3Portal/docum...T-MMS-1786.pdf
Edit: You may be thinking of when Subaru changed their service intervals to 6k miles/6 months across their ENTIRE lineup. So according to Subaru an STI gets oil changes at the same frequency as Crosstrek Hybrid.
ineedyourdiddly
Tcoat (04-04-2017)
Old 04-04-2017, 12:37 PM   #7
8RZ
The Gunshine State
8RZ's Avatar
I forgot to post the link: http://www.blackstone-labs.com/
The test kits are free, just email them and they will send you some. The standard test starts at $28, for an additional $10 they will test TBN, which will tell you how much life your oil has left in it and whether or not you need to adjust your oil change interval.
Current DD: M235i
MuseChaser (04-04-2017), strat61caster (04-04-2017), Teseo (04-05-2017)
Old 04-04-2017, 12:46 PM   #8
bababooey
Drives: BRZ SWP Limited -6MT
for those that go a bit longer than the various manufacturer mileage recommendations,
are you changing the oil filter sooner than the oil? example being changed oil @ 8k but filter @ 4k & 8k?
Old 04-04-2017, 01:12 PM   #9
Gil Scott Heron
Drives: '17 Asphalt 86
I don't, but I always replace my air filters when required and I buy high quality oil filters.
I did a couple of oil analyses on my old 2008 Miata with Mobil 1 Full Synth 5w30 and a Mobil 1 filter. On the final OA after 9000 miles and running same Mobil 1 filter for the duration, the oil showed very "healthy" numbers. The TBN even showed that the oil could likely be extended out to 10,000 miles with no problems. On that car in particular, I saw no need to replace the filter at a sooner interval than the oil itself.
Addendum: FWIW, during that cycle, the car was driven through two dust storms, and throughout a summer where the temps were consistently over 100 deg. F.
I'm still on the break in oil on my 86, so it'll be a while before I do an OA on it.
Gil Scott Heron is offline   Reply With Quote
The Following User Says Thank You to Gil Scott Heron For This Useful Post:
bababooey (04-04-2017)
Old 04-04-2017, 01:18 PM   #10
WAIT? You are supposed to change the oil?
Old 04-04-2017, 02:07 PM   #11
strat61caster
Don't worry, soon you'll hit the Subaru extended service interval where you just replace the oil on a continuous basis since 1L/1,000 miles is acceptable oil consumption, boxers aren't so different from rotaries after all.
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
MuseChaser (04-04-2017), Tcoat (04-04-2017), Teseo (04-05-2017), toast (04-20-2017)
Old 04-04-2017, 02:51 PM   #12
8RZ
The Gunshine State
8RZ's Avatar
I'll be changing it the same time I change my oil, which will now be every 8k miles. I don't see any issues as long as you use a quality filter.
Current DD: M235i
The Following User Says Thank You to 8RZ For This Useful Post:
Old 04-04-2017, 05:51 PM   #13
LXXXV1
LXXXV1's Avatar
Drives: 2014 FR-S Monogram, Whiteout 6MT
Anyone care to chime in on length of time between oil changes? Currently at 15k miles in 3 years. I know...poor car
2007 Honda CBR600RR-Pearl White/Silver - Totaled
2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build)
φφκα
LXXXV1 is offline   Reply With Quote
Old 04-04-2017, 06:22 PM   #14
MuseChaser
MuseChaser's Avatar
You could probably go another couple years...
or...
you could change your oil every 6 months/7500 miles and take one worry off your list.. unless you don't worry...
Oil Analysis - 1st oil change R L Newb Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 375 11-19-2021 09:24 AM
BRZ MPG Data Analysis housecat BRZ First-Gen (2012+) — General Topics 30 02-14-2016 08:32 PM
MatLab log analysis ztan Software Tuning 12 12-02-2014 07:19 PM
Used Oil Analysis Results Captain Snooze Engine, Exhaust, Transmission 2 11-21-2013 12:59 PM
