Drives: 2015 FR-S Asphalt, racing stripes,
Exhaust disappointment please help!!!
Bought the 2015 FR-S with a Borla muffler from the dealership. That's what I liked about it a good sound. Ok now for more power and better torque curve. So purchase Open Flash Performance UEL header tuner combo and installed it. Hate the loud almost misfire like sound at low rpms. So called Open Flash Performance they said try a different quite muffler any suggestions? But also is the stock manifold more like an equal length. This set up almost sounds as If I have a misfire!!! Anyway should I get an EL header or just a better muffler suggestions please!!! Don't want to give up any little power gain.
#2 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
EDIT: wait, nevermind. thought you have stock headers.
#3 |
Drives: 2014 FR-S
Are you running the stock frontpipe still?
The stock is very close to an EL setup. Any non-catted aftermarket header will add a good amount of volume to the exhaust no matter if its UEL or EL. There is a few options to quiet it down. One is to change out the Borla for a quieter exhaust, Invidia Q300 for example, there is a few more on the quiet side just lazy to list. check the Exhaust sticky area, there is a thread there for most exhausts out there. Another is to get a catted header but that will not produce as much as an uncatted a few Hp loss. There is a few dyno comparisons for catted vs. uncatted out there just search. If you get another header you should have no problem selling the one you currently have. |
#4 |
Señor Member
People seem to sell the stock exhaust quite often for fairly low prices. That will be your quietest option.
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | steve99 (04-04-2017) |
#5 |
Drives: 2013 GBS BRZ Limited
Perrin 2.5 Resonated and Invidia Q300 are a couple good quieter options. Like KnightRyder said, it's possible that the previous owner swapped out the front pipe for an aftermarket one as well. The stock one has a cat that will reduce rasp/volume. Aftermarket ones either delete it, or use an HFC that will increase volume.
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
#6 |
Drives: between cars...
Let me know if you want to ship that Borla for a reasonable price...
#7 |
If you want a quiet exhaust that still commands a presence, try the CSG x MXP Touring86 or Ace Laguna90 exhausts.
#8 | |
Drives: FT86
if still dont like the sound the only option will be an EL header |
| The Following User Says Thank You to steve99 For This Useful Post: | bfrank1972 (04-04-2017) |
#9 | |
Drives: 2014 Scion FR-S Monogram
As others have stated a quieter catback will make it less noticeable for you inside but outside it will always sound that way because of the physics behind a UEL header and exhaust pulses. If you can't stand it the only solution is to switch to a EL header setup. If it was me I would just stick with the OFH as they are specifically designed to work perfectly with OFT tunes and will yield great results. Have you had someone else drive your car with you outside to listen to it? The only reason I say this is you could like how it sounds outside more than inside. The "dropped cylinder" beat of the UEL can be somewhat compared to a crossplane V8's rumble which is caused by the firing order those engines use.
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
#10 | |
Drives: 2013 FR-S Argento
Is that closer to what you're looking for? |
#11 |
Drives: Scion FRS
| Oft disappointment | bRZillian7 | Software Tuning | 45 | 09-30-2015 05:19 PM |
| Valenti Tail lights disappointment/question | kincito | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 07-02-2014 09:47 PM |
| Revive Your Exhaust Tone with Our Debut FT86Club Exhaust Clearance Sale! | FRSport.com | Engine, Exhaust, Bolt-Ons | 0 | 09-06-2013 02:08 PM |
| Pre-Order Disappointment woes | Draco233 | BRZ First-Gen (2012+) — General Topics | 16 | 03-03-2012 04:31 PM |
| BRZ pricing disappointment thread | dsgerbc | BRZ First-Gen (2012+) — General Topics | 42 | 02-29-2012 02:37 PM |
