| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: 2014 GT86
If OEM rim had been 16", 17" winter tires cost more and often much harder to find in (advisable for winters) narrower widths .. but there should be many cheap enough and good enough cast wheels out there .. or even of higher end if one can consider used ones from classifieds, to not use steelies and/or spacers.
#16 | |||
Drives: FRS 10-series
As it stands right now all the spacers have been taken off the car. I'll be buying new studs for the rears all around and have gotten myself longer lugs (steel gorilla acorn style) with almost double the thread length as factory lugs just in case there was any bottoming out. Spacers will be uninstalled again next winter and I think I've got to replace those steel wheels they are definitely tired Thanks for all the input guys |
| The Following User Says Thank You to rmr For This Useful Post: | Tcoat (04-03-2017) |
#17 | |
Drives: Track preped NA FRS
Back on to OP, 100% convinced the seat of the nuts in your wheels is so corrupted the nut came loose and allowed all the charge to be placed on the stud, which you know, breaks them. I think this would've happened on the stock studs as well. |
#18 | |
I'm just thankful I noticed something driving two blocks to the store and not two days before on a major highway. Terrible to think what could have happened if a wheel decided to go on its own out on a highway. Lesson learned. Thanks for the input guys. |
#19 |
As a followup to this thread, having decided I will replace all the studs on the spacer I've been thinking whether or not the integrity of the spacer itself has been compromised.
It probably took a lot of forces it wasn't designed to take having those studs/lugs shear right off. The spacer itself looks completely fine as do the holes for the lugs. I just wonder if its still safe to use it, if there is some defect that I cannot see? If anybody has any ideas or experience with this it would be greatly appreciated. |
| Bought winter tires with studs (live in hilly area). Now I want to remove the studs.. | redwing634 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 12-18-2016 08:57 PM |
| MAX Spacer thickness for stock studs? | FRSpdDmn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 06-09-2016 01:02 PM |
| How much spacer is safe on stock rear studs? | wparsons | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 12-27-2014 01:49 AM |
| <FS> 4x H&R 15mm spacer and 15x extended studs (H&R and ARP) $140 shipped | mav1178 | Wheels and Tires | 0 | 08-22-2014 01:10 AM |
| 3mm spacer...need longer studs? | Fizz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 04-16-2014 02:50 AM |
