Old 04-01-2017, 03:45 PM   #15
LancePower
Drives: 2020 BRZ tS
Originally Posted by MALAJSTD View Post
The drop on these springs should be even F/R
I'm curious about yours.
Did you measure before and after?
Any photos?
I also have TRD Springs. From some angles the drop in Rear seems greater, from other angles they seem even.
I think the wheel gap in the Front was larger to start with.
LancePower is offline   Reply With Quote
Old 04-01-2017, 06:47 PM   #16
MALAJSTD
Drives: 2016 FR-S 6MT Oceanic
Correct me if I'm wrong, but I think the rear sits 3/16" high than the front from the factory.
MALAJSTD is offline   Reply With Quote
Old 04-01-2017, 07:05 PM   #17
stevesnj
stevesnj's Avatar
Could be the fuel weight making it even, and less fuel higher rear end .
My 2016 Build thread
Old 04-01-2017, 07:12 PM   #18
ELLSSUU
Drives: FR-S, 951, Venza, Accord, MDX
Originally Posted by Mr. Kurtz View Post
I measured before and after, and they lowered the car approximately 1.25" at all four corners.
My son's dropped the same amount.
You will definitely feel road imperfections and will also become very aware of all curbs, potholes etc. It's not uncomfortable just rigid.
It's low. My son calls it PineCone low as in a with RocketBunny V1 front lip he's dodging anything taller than a PineCone.
ELLSSUU is offline   Reply With Quote
FS: stock BRZ springs, Eibach Pro Kit springs + Stock shocks (socal/OC) tracerit Brakes, Suspension, Chassis 7 04-02-2016 12:04 PM
FS: Openflash, Weathertechs,Mtech Trasmission Springs, Stock Exhaust, Stock intake Brahsbrah Canada Classifieds 11 11-09-2014 11:03 AM
Mix & Match stock FR-S and stock BRZ suspension and/or springs Weasel Soup Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-08-2014 01:53 PM
Selling stock FRS Springs/Struts + Stock Pads + Rotors 6k on all! NickFRS Brakes, Suspension, Chassis 6 03-14-2013 01:38 AM
FS: Ecutek Cable, stock axleback exhaust, stock springs Philly Canada Classifieds 4 11-02-2012 08:50 PM
