Old 03-27-2017, 09:49 AM   #1
michaelchatten
Drives: 2016 FR-S RS 2.0
TRD Springs vs Stock?
Considering the TRD Springs for my FR-S. I am not looking for performance gains, I would just like to get rid of some of the wheel well gap.
Do the TRD Springs make to car ride a lot stiffer then the stock springs? I do a lot of highway driving and do not want to get beat up on the long drives.
michaelchatten is offline   Reply With Quote
Old 03-27-2017, 09:54 AM   #2
EnoOnraefi
EnoOnraefi's Avatar
Drives: MY17 Asphalt 86
I had the TRD Springs installed before I picked up MY17 and I don't feel like I have been beaten up at all. I've only done a handful of 30+ minute highway drives though.
EnoOnraefi is offline   Reply With Quote
Old 03-27-2017, 10:11 AM   #3
StraightOuttaCanadaEh
Wes
How much do they lower it by? 1"?
Also, the dealer wants 1K for it, which is way too steep for lowering springs. Do they sell them on ebay or something? I'd just get my mechanic to install them.
Old 03-27-2017, 10:19 AM   #4
LancePower
Drives: 2020 BRZ tS
I would have to classify the ride with TRD Springs as harsh. You will feel every road imperfection.
Now the roads in TN are probably a lot better than the roads in NJ, which is like driving through Beirut.
LancePower is offline   Reply With Quote
Old 03-27-2017, 10:25 AM   #5
EnoOnraefi
EnoOnraefi's Avatar
Yes about 1"
I want to say that I paid about 600 for parts and install.
Harsh isn't a bad description, but I expected a bit of a drop in ride comfort when I lowered it. I definitely wouldn't call it a beating though.
Old 03-27-2017, 10:50 AM   #6
novice
novice's Avatar
Drives: Fr-S 2.0 Release
I have trd springs and anti roll bars. Its not bad at all. I can hardly tell the difference from stock as far as ride harshness. It does feel different. CAn't really describe it as I am no race car driver. I do like the ride better though. Feels more locked in on turns etc.
novice is offline   Reply With Quote
Old 03-27-2017, 10:58 AM   #7
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
My wifes 15' is bone stock and my 16' has TRD springs and Koni shocks. My car is not as comfortable as my wife's, but it's still not bad IMO.
I need to get the two cars on the stock wheels and tires to compare again now that they are settled, but I think the drop is just a little over half an inch. I doubt it's a full inch.
Twinz is offline   Reply With Quote
Old 03-31-2017, 07:43 PM   #8
Mr. Kurtz
Mr. Kurtz's Avatar
Drives: None
I put TRD springs on my 2017 back in October, after 2000 miles of driving on the stock springs. I wouldn't call the ride harsh at all.
I measured before and after, and they lowered the car approximately 1.25" at all four corners.
Mr. Kurtz is offline   Reply With Quote
The Following User Says Thank You to Mr. Kurtz For This Useful Post:
Samba86 (03-09-2022)
Old 03-31-2017, 08:00 PM   #9
mr_squirrel
mr_squirrel's Avatar
Drives: 2017 86 Halo
I put on trd springs with stock struts. Front didn't go down much: .5ish. Back went down a good amount 1-1.5. TBH, I put them in before I drove a lot on stock, and this car is stiffer than my last (tC). If anything, car looks a lot better with the gaps reduced. The link in my signature has pictures of the before and after (near the bottom, iirc)
Sent from my ONEPLUS A3000 using Tapatalk
mr_squirrel is offline   Reply With Quote
Old 03-31-2017, 08:58 PM   #10
MALAJSTD
Drives: 2016 FR-S 6MT Oceanic
I can help you out with TRD parts pricing if you so choose.
MALAJSTD is offline   Reply With Quote
The Following User Says Thank You to MALAJSTD For This Useful Post:
StraightOuttaCanadaEh (04-01-2017)
Old 04-01-2017, 10:00 AM   #11
Wes
Not sure if 0.5 at the front would be enough though.
Old 04-01-2017, 11:15 AM   #12
MALAJSTD
The drop on these springs should be even F/R
I'm curious about yours.
Did you measure before and after?
Any photos?
Old 04-01-2017, 11:25 AM   #13
MALAJSTD
To each their own, aesthetics are a determining factor for many. The other half wants no compromise performance.
keep in mind it's very dificult to improve on the suspension set up this car came with, with springs alone.
1" drop is about the max for OEM shock travel.
Old 04-01-2017, 03:29 PM   #14
Gforce
Drives: 2013 Subaru BRZ
Lowering springs have to be shorter springs. Shorter springs have to be higher rate springs. Lowering will always cause a harder ride. Always.
Gforce is offline   Reply With Quote
The Following User Says Thank You to Gforce For This Useful Post:
funwheeldrive (04-01-2017)
FS: stock BRZ springs, Eibach Pro Kit springs + Stock shocks (socal/OC) tracerit Brakes, Suspension, Chassis 7 04-02-2016 12:04 PM
FS: Openflash, Weathertechs,Mtech Trasmission Springs, Stock Exhaust, Stock intake Brahsbrah Canada Classifieds 11 11-09-2014 11:03 AM
Mix & Match stock FR-S and stock BRZ suspension and/or springs Weasel Soup Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-08-2014 01:53 PM
Selling stock FRS Springs/Struts + Stock Pads + Rotors 6k on all! NickFRS Brakes, Suspension, Chassis 6 03-14-2013 01:38 AM
FS: Ecutek Cable, stock axleback exhaust, stock springs Philly Canada Classifieds 4 11-02-2012 08:50 PM
