Old 03-30-2017, 03:24 PM   #1
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
Marks on Rotors
Yesterday I just gave my car a rinse to get rid of the pollen on it, parked the car and didn't drive it for the rest of the day. When I went to work this morning, when I first started backing out of my garage I heard/felt a clunk from mostly the rear. My brakes were also making rubbing/grinding noises when the pedal was pressed on the way to work.
Now I know when rotors get wet they develop surface rust, but I've never experienced it like that before. It rained today while at work, and they made the same noise on the way back. Anyways, once I got home from work I took a look at my rotors and found this:
Each rotor has a spot like this on them where you can see a mark left by the pads. Anyone know if this will wear off or are my rotors fubared? I'm not terribly familiar with brakes
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 03-30-2017, 03:26 PM   #2
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Car is totaled. lmao
Nah, you're good.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Shark_Bait88 (03-30-2017)
Old 03-30-2017, 03:52 PM   #3
BFIFE22
BFIFE22's Avatar
Nah, you're good.
I knew I was gonna get a totaled/part out comment lol
Old 03-30-2017, 03:55 PM   #4
toast
Drives: 14 BSP Edelbrock BRZ
After a few stops they will be gone. In general, you don't want to apply your emergency brake when parking overnight if the rotors are wet, you will get that same kind of thing only much worse. You also shouldn't apply it if the rotors are still very hot from aggressive driving.
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
Teseo (03-30-2017)
Old 03-30-2017, 10:16 PM   #5
BFIFE22
BFIFE22's Avatar
Good to know. I knew about avoiding it on hot rotors, didn't know to try to avoid it if the car is gonna sit overnight with wet rotors.
Old 03-31-2017, 01:23 AM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Just get in habit leaving it in gear (if MT) instead of using parking brake. And after track session do a cooling lap.
Old 03-31-2017, 07:35 AM   #7
skylinekin
skylinekin's Avatar
Drives: 22 GR86, 13 FRS, 15 BRZ, 13 FRS
The parking brake is a drum type system, doesn't use the rear caliper..
skylinekin is offline   Reply With Quote
The Following 3 Users Say Thank You to skylinekin For This Useful Post:
Icecreamtruk (03-31-2017), solidONE (03-31-2017), strat61caster (03-31-2017)
Old 03-31-2017, 11:09 AM   #8
toast
Ha! I remembered that last night after I wrote that post...
Old 03-31-2017, 02:20 PM   #9
solidONE
solidONE's Avatar
Imagine what the drum surface looks like. Car will definitely be look FUBARed if you got a visual. lmao
Will still scorch your brake shoes if you engage the parking brake while they're hot. So you'd still want to take the same precautions.
Intent > Content
Old 03-31-2017, 02:27 PM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
I know that. But it being drum type doesn't mean it cannot sieze, or freeze in winter. I've been tought to leave car stationary in gear, unless on steep incline or if diesel, that can self-prime w/o ignition, using parking brake usually for short periods of time or eg. by starting going up steep hill. By all those years driven using gearbox when parking has become natural habit since long ago.
LOL, i've also been told if i'll ever go to France, to never leave car with parking brake OR in gear, only in neutral to enable rolling, due their "parking methods" of multiple bumper contacts to squeeze between other cars
Marks on Rotors BFIFE22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-31-2017 08:13 PM
Marks on Glass VMRamos Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 16 11-04-2015 10:35 PM
Help on Swirl marks on my new FRS xcooperx Southern California 9 02-10-2015 05:36 PM
Marks on car ID86 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 34 12-26-2013 10:43 AM
swirl marks jarviz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 31 07-12-2012 08:33 AM
