Drives: '88 E30 325i, 2015 FR-S
Brake piston stuck really bad.
I was changing the studs on my FRS, and with the caliper off on one side, I stupidly applied the brakes.
Now one of my rear brake pistons is stuck really good. I took the cap off the brake fluid reservoir to release the pressure. I even opened the bleeder valve on the caliper just to make sure there was no pressure in there. I put a C-clamp on the piston, and squeezed the ever loving hell out of it, but it is not budging. It is stuck really good. I have a track day on Friday, and I need this fixed tomorrow. Here is an image of what's going on, you can see my C-clamp on the stuck piston: http://i.imgur.com/84urA1t.jpg I searched Google, I tried everything I could think of. Does anyone have any ideas?
#2 |
Drives: 2017 86 6-Speed
Idk about our cars (I haven't messed with my brakes yet since I got it), but a lot of calipers retract with a twisting motion rather than a squeezing motion, try to find something to twist the piston with without messing it up and see if it retracts.
#3 |
Drives: Toyota MR2 Spyder Turbo
yip, its probably a twist back
#4 |
Only users lose drugs.
Drives: All the time
It's not a screw in piston...I just did my pads a few weeks back and I pushed the front and rear pistons in by hand. From my experience, usually screw in pistons are for emergency brake systems that actuate the main caliper, whereas our ebrakes are a small drum setup inside the rotor hat. Sounds like the piston is wedged.
| The Following User Says Thank You to venturaII For This Useful Post: | strat61caster (03-30-2017) |
#5 |
Drives: 2013 satin white brz limited
Might be worth your time to just disconnect the line to make sure all pressure is relived and try and wiggle it back into place. My guess is it prob maxed out its travel and got cocked in there.
#6 |
Most likely this, those pistons need to move evenly in the bore, you can get a brass punch and gently tap the piston inside the hollow part with it with small hammer taps on the punch. Ideally you want to keep the piston in the bore but if it comes out just reinsert the piston evenly. I'd remove the caliper and drain any fluid that may be remaining. Just a little fluid could stop movement.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | strat61caster (03-30-2017) |
#7 |
Hey guys, I fixed it. I removed the two 14mm bolts to open up the caliper, then I was able to put my c-clamp all the way across the piston evenly. Then it went down very smoothly. This is why sometimes you shouldn't drink while working on cars, or maybe I'd have thought of this sooner. Seems simple now.
Since I opened the brake reservoir and opened the bleeder valve, I have to bleed the brakes now, right?
| The Following 2 Users Say Thank You to irocz0r For This Useful Post: | stevesnj (03-30-2017), strat61caster (03-30-2017) |
#8 | |
Drives: 2013 WRB BRZ 6MT
| The Following User Says Thank You to Lynxis For This Useful Post: | strat61caster (03-30-2017) |
#9 |
#10 |
Also, in the future if you're going to use a c-clamp to push the piston back in, you might consider keeping the old pad in the caliper and screwing the clamp against IT, rather than directly on the piston.
| Brake Rotors: Rusted Stuck | Apex_BRZ | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 33 | 08-21-2019 03:40 PM |
| Brake Piston Compressor Tool | n8dog11914 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 12-31-2014 09:23 PM |
| Front Brake Caliper Piston Rebuild? | smbstyle | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 0 | 10-17-2013 05:18 PM |
| BRZ/FRS big brake kit vs WRX counterparts: brake piston size (differences, if any)? | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-25-2013 12:07 PM |
| Brake piston sizes | coyote | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 09-25-2012 05:51 PM |
