Drives: 2013 WRB Subaru BRZ 6MT
Brake Piston Compressor Tool
I'm coming up on another track day and need to install my set of high temp pads. I've been fortunate to not need a compressor tool to push the piston back recently, but I'd rather be prepared this time. What brand/tool would you recommend? I noticed the Harbor Freight version had so so reviews so I thought I'd check what everyone is using.
Thanks, |
I just use a small block of wood and a clamp, works like a charm and I saved money for elsewhere.
Drives: 13 Scion FRS, 93 JDM Toyota Supra
Yep, a c-clamp also works great with a wood paint stir stick like this: ![]() I've also used the curved part of the wrench in the trunk and that works great, just make sure to press the pistons fairly evenly.
2022 BRZ Build 2013 FR-S Build |
Drives: 2017 BRZ
I actually used a small Bessey bar clamp last brake job I did and it was easier by far than the C clamp - probably because it's lighter and easier to get to size. Plus it comes with silicone pads... Of course, if you don't have much of a non-automotive shop, you may not have these just lying around (let alone a wall full... it's a small wall, I swear) IIRC it's narrow enough I was able to depress the piston without removing the old pads, which made it easier to get the old one off.
Drives: SC RB FRS
yup or get old brake pads and a pry bar and push that sucker in.
Two C clamps for the front calipers, one for the rears. If you use a piece of wood you can use a single clamp for the fronts as well.
| BLACK FRIDAY SPL - StopTech Big Brake Kit 2PC - 1 kit left 328mm, red slotted | Gruppe-s | Brakes, Suspension, Chassis | 35 | 11-04-2015 09:39 PM |
| Seized brake rotor removal tool | fstlane | DIY (Do-It-Yourself) Guides | 15 | 09-06-2015 12:38 AM |
| Front Brake Caliper Piston Rebuild? | smbstyle | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 0 | 10-17-2013 05:18 PM |
| BRZ/FRS big brake kit vs WRX counterparts: brake piston size (differences, if any)? | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-25-2013 12:07 PM |
| Brake piston sizes | coyote | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 09-25-2012 05:51 PM |
