Old 03-27-2017, 04:51 PM   #43
cmurp96
Drives: Black 2013 Scion FR-S
Alignment is acceptable, IMO. My gut says you're just overdriving the car.
1. What car have you driven that does what the frs doesn't do?
2. When the VSC kicks in, which end is letting go?
3. What's the outside temperature when you are driving
4. What's your tire pressure. If they're not even, tweak them and try again.
For the price point, none driven a brz and a lexus that drove very well, almost on par. I have driven a corvette z06 and a nissan gtr grannd turismo but never got about 65mph bc not my car. It feels like the back is the one fucking up when it kicks in. tire pressure and temp are g2g
cmurp96 is offline   Reply With Quote
The Following User Says Thank You to cmurp96 For This Useful Post:
Ultramaroon (03-27-2017)
Old 03-28-2017, 09:34 AM   #44
wparsons
wparsons's Avatar
What are you doing with the gas pedal in this corner? What gear are you in?
If the rear is letting go it's likely because you either lifted off the throttle mid corner or you're too hard on the gas with too much steering angle.
Any videos of what you're experiencing?
flickr
Ultramaroon (03-28-2017)
Old 03-28-2017, 07:58 PM   #45
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
@cmurp96 your responses are cryptic and almost juvenile. I don't like being the word police, but it would really be helpful if you gave meaningful responses to our questions and actually used complete spelling instead of codes and slang more suitable for a text than on a forum where people are trying to help you. I'm happy to try and help you with your car, but I don't want to have to figure out what you're trying to say.
Saying it's a 40 degree turn taken at 60mph leaves a fair amount open for interpretation. It sounds like it's a sweeping turn taken at pretty decent speed, but the VSC is engaging before you expect it to, right? The first thing that comes to mind is that your VSC may not have been reset by the dealership using Toyota Techstream after the car was lowered, and is now not properly calibrated. If so, that can certainly explain your problem. The next questions have already been asked of you, but I didn't see a meaningful response given, specifically:
- What are you doing with the car when the VSC engages? Meaning...
- Are you powering through the corner while tightening your line? Or...
- Are you coming in too hot and dropping the throttle, causing the rear end of the car to become unloaded?
Start there and I'll try and help if I can.
Last edited by RJasonKlein; 03-28-2017 at 09:21 PM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
Old 03-28-2017, 09:01 PM   #46
wparsons
wparsons's Avatar
- Are you coming in too hot and dropping the trhottle, causing the rear end of the car to become unloaded?
To add to the bolded part, radius also matters, not just how much of a turn it is. You could take a larger radius 180* turn way faster than a shorter radius 40* turn.
flickr
Old 03-28-2017, 09:19 PM   #47
Wait, so it's temperature and radius? How are those two related?
RJasonKlein (03-28-2017), wparsons (03-29-2017)
Old 03-29-2017, 01:30 PM   #48
wparsons
wparsons's Avatar
Pi, duh!
flickr
Ultramaroon (03-29-2017)
Old 03-29-2017, 03:00 PM   #49
Pi, duh!
Oh!
I don't bake much.
Lynxis (03-29-2017), wparsons (03-29-2017)
Old 03-30-2017, 12:02 PM   #50
Astroboy
Astroboy's Avatar
Drives: None
Originally Posted by Clee View Post
Are you slipping when turning that fast? How about turning off traction control
Im slipping when turning fast. I think i might need new struts. Allignment tech told me my camber was like -.15 all around if that even makes sense. I asked for a copy of allignment specs, but the printerwas down supposedly
Sent from my LG-H820 using Tapatalk
Astroboy is offline   Reply With Quote
Old 03-30-2017, 01:02 PM   #51
churchx
churchx's Avatar
Drives: 2014 GT86
-.15, if those are degrees, is very close to "stock" 0. I advise to rise negative camber to -2 to -2.5 front, -1.5 to -2 degrees rear, even on very same tires will rise grip when cornering noticeably, yet is reasonable enough to not affect tire wear much when daily driving.
P.S.
For future, even if no printing capabilities, one can simply take a pic with phone from alignment screen.
P.P.S.
To rise camber i suggest buying camberbolts for front & lca for rear. Shouldn't be too expensive. Camber is unadjustable in stock twin suspension, and about only other means to get more neg. camber is if one lowers car, or if pays for something more expensive then bolts & some cheap rear lca (eg. SPC), for example camberplates/slotted coilovers with camberplates and such.
Old 03-30-2017, 08:55 PM   #52
Astroboy
Astroboy's Avatar
Drives: None
P.S.
P.P.S.
Damn you're right. I should have taken a pic. I didn't know he was going to give me that bs on the printer being down tho. Oh well. Next time ill know what to ask for
SPC LCA Alignment Issue? ssidd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-15-2018 12:58 PM
FRS Bumper alignment issue, help please Brody602 Cosmetic Modification (Interior/Exterior/Lighting) 5 06-04-2015 02:27 PM
Do I just need an alignment or... (scraping issue) IDFWU 420 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-26-2014 12:26 AM
Alignment issue guscab Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 09-08-2014 10:26 PM
