Old 03-25-2017, 12:41 PM   #267
wooly35
Drives: 2014 Scion FR-S LS3
Originally Posted by DustinS View Post
From what I understand, the Master cylinder side is different because the BMW Master is retained, whereas the FRS Master is changed for a Tilton one. I have the Tilton in my cart on summit, I have a friend that can make the adapter. When Vorshlag gets back to me I am going to see if they can either 1: Send the FRS specific slave early, 2: Send the BMW one and I'll make the master side fitting, or 3: Refund that purchase
That's sort of what I was planning. I just want the damn motor and trans bolted up to the car so I can start working around it
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
The Following User Says Thank You to wooly35 For This Useful Post:
DustinS (03-25-2017)
Old 03-25-2017, 03:50 PM   #268
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Haha! Same. Talked with my friend who owns a shop/machine shop about it and says he can probably knock one of those hoses out quick. So I'll probably switch to the BMW one.
Also reminded me he orders CX Racing wholesale. So prices are cheap for him. Hopefully I can talk him into cutting me a deal.
The Following User Says Thank You to DustinS For This Useful Post:
wooly35 (03-25-2017)
Old 03-25-2017, 07:27 PM   #269
wooly35
it appears that the water pump that was on my motor is the same one they used... so now I have two water pumps. If anyone needs an unused ls3 water pump, hit me up. lol Just one of many mistakes ill make on this build. ha ha
DustinS (03-27-2017)
Old 03-27-2017, 12:16 PM   #270
all4spl
where is the element tuning build thread? Lots of good info here. I'm kinda not liking the weight time for vorshlag either. :/
all4spl is offline   Reply With Quote
Old 03-27-2017, 12:18 PM   #271
DustinS
DustinS's Avatar
They have an instagram for it.
Monster86swap
Edit: Hopefully today doesn't set the mood for the rest of the week, been an interesting one for sure between talking with Element Tuning, issues as work, and dealing with my brother wrecking his car because he wasn't paying attention.
Element Tuning is telling me they can get the transmission in about a weeks time... Said the driveshaft is about the same wait time. Also offered to modify a CX Kit to work with the Magnum XL. They also have a few other parts they say help make the job a bit easier. Hearing a week wait time on a part I have been waiting 4 months for is a bit hard to swallow. Assuming Vorshlag actually gets back to me this time, depending on what they say, I may just cancel my order and get everything through Element. Funny how I was going to get my FA20 built by them before I changed to LS swap and may end up making an order through them anyway. Nothing against Vorshlag, just trying to do this in a timely manner.
Edit: Called Tremec just to see what lead times are on their side, 30-60 days but most suppliers should have product on hand. Starting to think my order was lost.
The Following 4 Users Say Thank You to DustinS For This Useful Post:
6-Shift (03-28-2017), ILLSMOQ (03-28-2017), M1K3 (03-27-2017), wooly35 (03-27-2017)
Old 03-28-2017, 01:57 AM   #272
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
@DustinS so does this mean you're selling me your turbo kit?
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
The Following User Says Thank You to 6-Shift For This Useful Post:
DustinS (03-28-2017)
Old 03-28-2017, 09:48 AM   #273
DustinS
DustinS's Avatar
I'll let you know When I am ready to sell
Old 03-28-2017, 10:17 AM   #274
all4spl
So is Element using the CX racing trans mount? Just the engine mounts? I wonder if they would sell their "version" of the mounts that are slightly worked.
Old 03-28-2017, 10:25 AM   #275
DustinS
DustinS's Avatar
Yes. They modify it to work with the Magnum XL. The CX Trans mount is made to run a T56 with GTO shifter. From what I understand they plan to have them available to order on the website here eventually.
Old 03-28-2017, 10:31 AM   #276
all4spl
Also Why wouldn't the cx racing trans mount work on the tremec XL? I thought all t56 mounts were the same?
Old 03-28-2017, 01:09 PM   #277
DustinS
DustinS's Avatar
Good question. Not sure. I imagine it comes from the extra length of the XL?
Old 03-28-2017, 01:27 PM   #278
all4spl
Also here is another option I found for exhaust manifold.
http://www.speedwaymotors.com/Tru-Ra...hed,53711.html
Old 03-28-2017, 01:40 PM   #279
DustinS
DustinS's Avatar
I really like the CX Racing for a bit more, it bolts to a 3" FRS/BRZ Exhaust. So it will bolt right up to my Greddy exhaust with little to no modification.
Old 03-28-2017, 02:17 PM   #280
Bullitt2496
Guest
Posts: n/a
You'll like it until you try to install your plugs and wires and until you realize the piping is only 1 5/8th
The Following User Says Thank You to For This Useful Post:
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
