#113 |
Drives: 2014 GT86
People want specific front-rear grip balance. In most cases everything else untouched most are happy with a bit more grip in front vs stock, hence if you change grip bias with dialing extra negative camber only, most commonly suggested alignment is with more camber in front. One can play also with different coilover tuning / different rollbars / staggered wheel-tire setup to overcompensate camber choice of "other way around", but why? KISS principle still applicable, no?
#114 | |
Drives: 2013 FR-S 10 series [755]
i dont know if i go too fast or i throttle too early.... I have -3 camber front/ -2.5 rear 0 toe front, 0.05 toe in rear 255 tires 22mm front sway bar/ stock rear |
#115 | |
There's a difference between tendency to oversteer and power oversteer. If you have the car set up neutral, which I think you do, then it will be less forgiving of harsh driver input. Also, that's a lot of rubber. Tire pressure will have a big effect.
#116 | |
Drives: '13 FRS - STX
Spring rates and sway bar are likely the next steps to hook up the rear. Damper adjustments as well. |
#117 | |
Drives: Track preped NA FRS
So a oversteery car could be caused by driver inputs. So lets try to see if its true or not. When do you feel/experience the oversteer? On corner entry, mid corner (right before and during the apex), or on corner exit? Do you experience oversteer only after applying throttle? A car that naturally oversteers will do so when you enter a corner, but without any throttle input. If the car oversteers only when throttle is applied (commonly known as power oversteer), then its usually drivers input, you are mashing on the throttle too hard or too soon, or both (usually both). Last edited by Icecreamtruk; 03-27-2017 at 11:36 AM. Reason: clarification |
| The Following 3 Users Say Thank You to Icecreamtruk For This Useful Post: |
#118 | |
I had some rear toe-out on accident for awhile, the rear end would jump out when the throttle was applied. It absolutely wasn't the driver, it was the car. But I think you're on the right path, driver induced handling issues are more common than anything else for us amateurs. Especially if the suspension is off the shelf by a reputable company (or OE). @FR-Sky see if you can ride along with someone else on the same course, doesn't even have to be the same car as long as grip levels aren't too different, that can be eye opening. If there's someone you trust with lots of experience, they may be willing to sit with you as a coach and notice if you're making obvious errors or even drive your car and give feedback. It's easiest to do if you're at autox (low risk) but there may be opportunities at track days as well (SpeedSF has an autox setup at most of their events, should work well as a test n' tune). |
| The Following 2 Users Say Thank You to strat61caster For This Useful Post: | FR-Sky (03-27-2017), Icecreamtruk (03-27-2017) |
#119 |
Huge E85 fan!
Drives: 2016 Scion FRS
If your inputs are too harsh you can induce lift-off oversteer too. That's when you lift off the gas too abruptly, upset the car and the rear wheels want to kick out. If your driving is the problem, chasing a fix with alignment will only make the car worse.
It all depends on WHEN you get that oversteer. Is it in the braking phase? Transition? Apex? throttle application? or track out? |
| The Following 2 Users Say Thank You to guybo For This Useful Post: | Gforce (05-07-2017), Icecreamtruk (03-27-2017) |
#120 | |
#121 |
Yea...forgot to mentions, I have spring rate 6k f/r damper 5/8 from hard
#122 | |
More into your setup, you seem to have adjustable dampers, so try soft in the rear and hard in the front (which seems to be oposite of what you have). As a rule of thumb with dampers, the softer you go, the more grip there will be, but the more roll you might encounter. So try way softer in the rear, and way harder in the front than your current settings, that should help. I honestly think you are chasing a problem you "think" you have, but im not sure you do have an oversteering problem (looking at your spring rates, I cannot imagine a car with square spring be an oversteery car). |
#123 | ||
Drives: FR-S Whiteout
What brand dampers and settings? Which tires? Are the tires different front to rear? How are you determining that you have oversteer if traction is on? From experience, the TC tend to make the car understeer when it does kick in.
Intent > Content
cowardice is the mother of cruelty. |
| The Following User Says Thank You to solidONE For This Useful Post: | strat61caster (03-28-2017) |
#124 | |
It is factory setting 35psi all around. It is TEIN flex Z, indy 500 , 255/40/17 square. When I turn the traction control will kick in, and it is hard to throttle unless the car almost full straight. |
#125 | |
I've driven a similarly set-up car same dampers, similarly sized tires 255/35/17 RSR tires with 35psi cold all around -2.5 fron -2.0 rear camber and 0 toe front and rear. Stock sways front and rear, and it didn't have a oversteer bias. With your 22mm front sway I'd assume it would understeer much more than the car I drove. What are you ride height and damper settings?
Intent > Content
#126 | |
Yes I do have 22mm front sway, and I thought it would fix it as well. My ride height is Flex Z standard, 0.8 inches front, 0.7 inches rear. Damper is from hard, front 5, rear 8. |
| Alignment Specs? | 86_ZN6 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 06-10-2013 06:30 PM |
| Anyone do their own alignment? | TemeCal | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 11-09-2012 11:36 PM |
| Another crash bolts alignment thread | jeebus | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 10-28-2012 12:29 AM |
| DIY alignment | dsgerbc | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-17-2012 11:41 AM |
| where to get alignment? | FML | Hawaii | 2 | 08-08-2012 01:36 AM |
