Old 03-24-2017, 07:19 PM   #253
Zer0
Drives: 2015 frs
Did they give you an ETA on when They would send them to you?
No ETA on when I will get them. I did get the transmission it seemed to take a few months to receive It. I pushed back my build until January 2018 due to home purchase.
seems as though this is not realistically going to be much of a set back due to parts wait times. I'm feeling better about putting it off the more I read about the wait times. I'm sorry those who are ready to proceed are experiencing these delays though.
Zer0 is offline   Reply With Quote
Old 03-24-2017, 07:24 PM   #254
Bullitt2496
Guest
Posts: n/a
Not sure why you guys are all into buying the "custom" tremec magnums when the WGP kit works with any T56.
Old 03-24-2017, 07:34 PM   #255
Zer0
Drives: 2015 frs
I guess we're just perfectionists. It's a sickness thankfully I'm not looking for a cure. So I will wait on the best parts made by the people who developed this swap.
Old 03-24-2017, 07:36 PM   #256
Bullitt2496
Guest
Posts: n/a
Not to be argumentative, but Weapons Grade developed the swap 2 years earlier ha.
Old 03-24-2017, 07:49 PM   #257
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Sure it works and works just fine I bet. I'd rather use the transmission that has the shifter in the right place rather than using a bracket/linkage to get the shifter there. Just a matter of preference.
ILLSMOQ is offline   Reply With Quote
Old 03-24-2017, 07:51 PM   #258
Bullitt2496
Guest
Posts: n/a
Their kits don't have linkages on the standard T56.
Old 03-24-2017, 07:53 PM   #259
Zer0
Drives: 2015 frs
Yeah I read all about them and passed. I wanted a higher quality product. In my opinion I will be getting just that. I'm going with the product that was developed the way I would build it myself are philosophies are a better match. Vorshlag is my ideal build with heavy documentation of the complete process and explanations of why the did what they did with weights and measures to back it up. They are the original ones to do the swap this way. I'm sure the others will do the job too, just not for me.
The Following 2 Users Say Thank You to Zer0 For This Useful Post:
DustinS (03-24-2017), wooly35 (03-25-2017)
Old 03-24-2017, 08:24 PM   #260
ILLSMOQ
Which transmission are they using?
Old 03-24-2017, 10:26 PM   #261
Bullitt2496
Guest
Posts: n/a
Any T56 will work.
Old 03-24-2017, 10:42 PM   #262
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Then they are using some kind of linkage on a T56. From what I understand most use a T56 with GTO shifter, which locates the shifter further out. The Magnum XL is the only one that fits with direct linkage.
Old 03-24-2017, 10:44 PM   #263
Bullitt2496
Guest
Posts: n/a
This isn't the case. My car is a GTO T56 and there is no linkage.
Old 03-24-2017, 11:02 PM   #264
DustinS
DustinS's Avatar
T56 GTO shifter. Not direct.
The Following User Says Thank You to DustinS For This Useful Post:
ILLSMOQ (03-25-2017)
Old 03-24-2017, 11:06 PM   #265
Bullitt2496
Guest
Posts: n/a
^Thats not what I think of when I think linkage. The CTS-V shifter... now that's linkage.
Old 03-25-2017, 01:15 AM   #266
ILLSMOQ
Right, anyway, GTO and CTSV use linkage...it's factory and it works fine. Given the choice I'd rather have less moving parts...that's why some of us have chosen the magnum XL.
The Following User Says Thank You to ILLSMOQ For This Useful Post:
DustinS (03-25-2017)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
