Old 03-17-2017, 03:17 PM   #15
reeves
Originally Posted by Exrald View Post
Originally Posted by reeves View Post
Getting that code doesn't necessarily mean something's gonna break.
I get that code everytime I hit 8K RPM.. first time was 3 yrs ago, my car hasn't blown up yet.
Thank you! It gives me a peace of mind. I was about to drop hella cash to get it "fixed."
Although, just keep in mind.. getting that code at 4-5K RPM, and getting it at 8K RPM can be two totally different things. Not trying to scare ya, just saying.. different circumstances, different loads, different tunes, etc...
Old 03-17-2017, 03:34 PM   #16
whataboutbob
AutoX-10/10ths every run
From my experience once you get a P035X code, it will continue to happen again with increasing frequency. I agree that you can change the coil pack out yourself and about $120 seems to be the correct price for the part.
In order to change it out you'll just need a 10mm 1/4 in socket (probably with a finger driver and a regular handle), a bit of time, and make sure the motor has cooled off.
Make sure you connect the wire harness to the new coil pack BEFORE you slide it back into the motor.
Build thread:Here
Old 03-24-2017, 12:09 AM   #17
DarkSunrise
DarkSunrise's Avatar
Just as a warning, the last time my car threw the p0351 code I happened to be data logging at the track. I was only getting the code above 6000 RPM. Later that night when I looked over my data logs, turns out I was getting fairly significant knock above 6000 RPM (-4 to -5 degrees FLKC) from the failing ignition coil. If you're planning to drive the car hard in the upper RPM range, probably best to replace the coil ASAP. As mentioned above, it's not too difficult, just a little annoying.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
Exrald (04-12-2017), reeves (03-24-2017)
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open romin Engine, Exhaust, Transmission 468 11-26-2021 05:05 PM
Has anyone resolved their ignition coil CEL issues? (P0351, P0352, etc.) edward Issues | Warranty | Recalls / TSB 41 11-06-2017 08:48 AM
Ignition coil information 1quickchic Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-12-2017 10:10 PM
Ignition Coil A CEL Whats that smell? Issues | Warranty | Recalls / TSB 12 10-10-2016 02:09 PM
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open Rossi AFRICA 18 02-02-2016 06:26 PM
