Old 03-17-2017, 12:53 PM   #1
Armin93
Drives: Toyota 86 GTS
Traction control warning light
Hey guys
So i was driving today and it was raining pretty bad. I pulled into a carpark looking for parking and i see my traction control warning light is on. It stayed on even after i turned the car off and on a few times.
So i connected an odb to it to see what the error is and it came up as " no error codes" and when i unplugged it and started the car the warning light was gone.
Any idea why this happened?
Armin93 is offline   Reply With Quote
Old 03-17-2017, 01:12 PM   #2
Most likely the car lost traction due to the wet roads.
Then, the system righted itself.
Unless it comes back for no good reason, I wouldn't worry about it.
Old 03-17-2017, 01:36 PM   #3
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
The light should not STAY on. More likely the rain somehow messed with a wheel speed sensor temporarily
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
Old 03-17-2017, 03:50 PM   #4
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
auto drift mode?!
FR-Sky is offline   Reply With Quote
The Following User Says Thank You to FR-Sky For This Useful Post:
mazeroni (03-17-2017)
Old 03-18-2017, 01:56 PM   #5
BRZnut
Drives: BRZ DGM Limited
Mine comes on all the time but then goes off right away. I would suspect there was some error in the traction control system that kept yours on. Not sure that in and of itself would throw a code with a standard code scanner since those codes are mostly engine/emissions related issues, but I could be wrong.
Old 03-18-2017, 04:50 PM   #6
Zhangy
Drives: 2015 FRS
this is normal and happened to me when I drove in snow. VSC keeps on flashing and then it goes "fk it man im just gonna stay on". Don't worry it will go off by itself eventually.
Zhangy is offline   Reply With Quote
Issues - Traction control and ABS warning light on G86 Issues | Warranty | Recalls / TSB 109 10-17-2021 05:32 PM
Traction Control and ABS warning light comes on [YOYO] Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-08-2016 11:19 AM
No traction control/ABS light on Hollwood_lives CANADA 6 01-13-2016 10:11 PM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 08:37 AM
ABS/Traction Warning Light - Turbo Build Tiz Issues | Warranty | Recalls / TSB 0 04-12-2015 01:56 PM
