#561 |
Does anyone know if you need to scale injen intakes?
#562 | |
Drives: 2014 BRZ sterling silver
#563 |
Drives: FR-S Whiteout
Yes. anything that does not use the factory MAF housing/airbox will require a rescale. Unless you dont mind it running like crap. Do enough lurking on threads about intakes and that injen will find it's next home in a trash bin.
Intent > Content
cowardice is the mother of cruelty. |
#564 | |
Drives: Toyota GT86
#565 |
Drives: 86
drop in filter need rescale at top end but not necessary
#566 |
One can argue that a completely OE intake could benefit from a MAF rescale and they would be 100% correct.
Intent > Content
| The Following User Says Thank You to solidONE For This Useful Post: | allowe (03-06-2017) |
#567 |
I'm legit about to buy oe intake from someone. My car came with an injen intake but I have yet to hear 1 person say "oh it's better" does it give any power at all over a drop in filter?....
#568 |
Drives: 86
proved
#569 | |
I'm sure if you decide to go with a stock intake and drop-in you can recoup some money selling the injen or trading it.
Intent > Content
#570 |
Drives: Hyper Blue BRZ
Hi Everyone, great post with lots of info, i was made the basic OTS guide adjustments from @Wayno's post and this post from @steve99 but no matter what i do, i am loggin 0 V on MAF voltage and my advance multiplier is always 0 and FLCK is -5 constant.
http://www.datazap.me/u/neilvosko/lo...&zoom=875-1240 i must be missing something, please help. much appreciated. |
#571 | |
Drives: FT86
either ask oft guys to fix it ot you will need to get a calid hacked tune file so you can run the older B01x roms in your car with oft that will log correctly. the tune will be ok its just a logging error you could use KC Learned to confirm the absence of knock it ususlly works on leter roms |
#572 | |
quick question
thanks @steve99
do these logs require MAF scaling? or leave as is? tough for me since i am not able to log MAF voltage. http://www.datazap.me/u/neilvosko/lo...zoom=1472-1543 http://www.datazap.me/u/neilvosko/lo...1&zoom=517-609 thanks, Neil Quote:
#573 | |
Drives: FT86
#574 |
The Dictater
Drives: '13 Red Scion FRS
Hey folks. Followed the instructions in the first post to scale my MAF as I was seeing LTFT of +5 to +10. The vgi scaling program worked great for closed loop. Though it resulted in a slightly bumpy scale, my LTFT was down to +-3%.
Open loop scaling, on the other hand was quite wavy, and the transition showed the 3V lump folks were talking about back on page 8 of this thread. I cant seem to follow the logic/conversation and stopped trying a few pages in, but it seemed like it involved having to first get the injectors set correctly? I know it was discussed in a number of threads back in 2014-ish, but if anyone could explain the consensus reached about why this happens and if I should/how I can get the scaling on the upper end right, I would very much appreciate it. Just FYI: Stock engine, OFT, and Perrin inlet tube (because sound generator was annoying) in case that matters. |
| AFR in Closed Loop | Toyota John | Software Tuning | 39 | 07-07-2019 08:26 AM |
| BRZedit Fuel Trims, Closed to Open loop transiton | mad_sb | Engine, Exhaust, Transmission | 32 | 08-06-2015 03:14 AM |
| Notes on injector / maf scalining using full time open loop | mad_sb | Software Tuning | 40 | 03-03-2014 05:49 PM |
| Screencast: closed loop boost control with RaceRom | jamesm | Software Tuning | 2 | 02-10-2014 02:23 PM |
| Screencast: experimenting with full-time closed loop fueling | jamesm | Software Tuning | 2 | 12-27-2013 10:19 AM |
