steve99
Old 03-05-2017, 11:36 AM   #561
allowe
allowe's Avatar
Does anyone know if you need to scale injen intakes?
allowe is offline   Reply With Quote
Old 03-05-2017, 12:27 PM   #562
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
Originally Posted by Tor View Post
That log is the stock A00G tune at 34 degs C, with 30.000 km of learning.
I'm sorry for the confusion, I included it to ask the following question:
So that log can be disregarded. Come to think of it, it could be entirely worthless as it is logged with the logfile.txt for A01G tune (I assumed it was A01G when I did the logs).
Otherwise, I am NA, completely stock except drop-in K&N air filter. I log and flash with Tactrix.
The actual current log is this one:
http://datazap.me/u/tor/tor-104-pull...5&zoom=550-688
Thanks for all the other information you provided.
I wonder If on his PI-DI scale if it's shutting off PI at 5000. Most of the tunes I have looked at that's usually to just DI.
oldgunfan is offline   Reply With Quote
Old 03-05-2017, 03:18 PM   #563
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Yes. anything that does not use the factory MAF housing/airbox will require a rescale. Unless you dont mind it running like crap. Do enough lurking on threads about intakes and that injen will find it's next home in a trash bin.
Intent > Content
Old 03-05-2017, 06:17 PM   #564
Tor
Tor's Avatar
Drives: Toyota GT86
It was. But this log is from a tune that is literally 30+ flashes ago.
Tor is offline   Reply With Quote
Old 03-05-2017, 10:54 PM   #565
aagun
Drives: 86
drop in filter need rescale at top end but not necessary
aagun is offline   Reply With Quote
Old 03-06-2017, 12:54 AM   #566
solidONE
solidONE's Avatar
One can argue that a completely OE intake could benefit from a MAF rescale and they would be 100% correct.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
allowe (03-06-2017)
Old 03-06-2017, 09:41 AM   #567
allowe
allowe's Avatar
I'm legit about to buy oe intake from someone. My car came with an injen intake but I have yet to hear 1 person say "oh it's better" does it give any power at all over a drop in filter?....
Old 03-06-2017, 01:21 PM   #568
aagun
Drives: 86
proved
Old 03-07-2017, 05:58 PM   #569
solidONE
solidONE's Avatar
If you dont already have the OE hardware, and that Injen intake is not giving you issues then I don't see the harm. Though many people have had problems with this particular intake in the past, while testers have seen good results. such as in this magazine article : http://dsportmag.com/the-tech/scion-...esting-ecutek/
I'm sure if you decide to go with a stock intake and drop-in you can recoup some money selling the injen or trading it.
Intent > Content
Old 03-12-2017, 12:15 PM   #570
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
Hi Everyone, great post with lots of info, i was made the basic OTS guide adjustments from @Wayno's post and this post from @steve99 but no matter what i do, i am loggin 0 V on MAF voltage and my advance multiplier is always 0 and FLCK is -5 constant.
http://www.datazap.me/u/neilvosko/lo...&zoom=875-1240
i must be missing something, please help.
much appreciated.
neilvosko is offline   Reply With Quote
Old 03-12-2017, 06:44 PM   #571
steve99
Drives: FT86
much appreciated.
Its a logging error with oft on leter rom calid
either ask oft guys to fix it ot you will need to get a calid hacked tune file so you can run the older B01x roms in your car with oft that will log correctly.
the tune will be ok its just a logging error
you could use KC Learned to confirm the absence of knock it ususlly works on leter roms
Old 03-12-2017, 08:44 PM   #572
neilvosko
neilvosko's Avatar
quick question
thanks @steve99
do these logs require MAF scaling? or leave as is?
tough for me since i am not able to log MAF voltage.
http://www.datazap.me/u/neilvosko/lo...zoom=1472-1543
http://www.datazap.me/u/neilvosko/lo...1&zoom=517-609
thanks,
Neil
Old 03-13-2017, 08:06 PM   #573
steve99
Drives: FT86
thanks @steve99
thanks,
Neil
looks pretty good , slightly rich over 6000 rpm so if you take 4% off the current maf flow numbers over 120 g\s it should fix it, but not rearly that bad
Old 04-27-2017, 10:10 PM   #574
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Hey folks. Followed the instructions in the first post to scale my MAF as I was seeing LTFT of +5 to +10. The vgi scaling program worked great for closed loop. Though it resulted in a slightly bumpy scale, my LTFT was down to +-3%.
Open loop scaling, on the other hand was quite wavy, and the transition showed the 3V lump folks were talking about back on page 8 of this thread. I cant seem to follow the logic/conversation and stopped trying a few pages in, but it seemed like it involved having to first get the injectors set correctly?
I know it was discussed in a number of threads back in 2014-ish, but if anyone could explain the consensus reached about why this happens and if I should/how I can get the scaling on the upper end right, I would very much appreciate it.
Just FYI: Stock engine, OFT, and Perrin inlet tube (because sound generator was annoying) in case that matters.
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 08:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 02:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
