Old 03-11-2017, 09:32 AM   #3375
FujiwaraTofu86
Drives: gt86
17x8 45 offset -2 camber up front, stock struts.
Anyone with this set up experiencing rubbing?
FujiwaraTofu86 is offline   Reply With Quote
Old 03-11-2017, 11:26 AM   #3376
TommyW
TommyW's Avatar
Drives: '13 Whiteout
That's a pretty mild setup you shouldn't have any problems
TommyW is offline   Reply With Quote
Old 03-11-2017, 12:22 PM   #3377
FujiwaraTofu86
Drives: gt86
oem struts seat is big in radius, i think im rubbing a little
Old 03-12-2017, 09:58 PM   #3378
nichaelmicely
Drives: Whiteout FR-S
Hi, I'm looking at 18x8.5 +35 in the front and 18x9.5 +25 in the rear. I am lowered on Eibach springs, and have no camber adjustments. Gonna run 225/35 all round. Will the 9.5 fit? or should I just get 8.5 and get spacers?
nichaelmicely is offline   Reply With Quote
Old 03-13-2017, 12:25 PM   #3379
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
I would strongly recommend to run at least a 245 on a 9.5". 225 tire on a 9.5" is very streched and in some countrys not even legal to drive due to safety concerns.
18x8.5 +35 all around is a very good Setup and pretty much flush. If you run a 245/35/18 tire Setup on it you will not Need any spacers.
I run myself a 18x8.75 +35 with 245 tires, feel free to check my car Journal (link below in my signature) to see how it Looks.
If you insist on 8.5 / 9.5 staggered, rather go for 8.5 +35 and 9.5+35, the wheel is alreay 1" wider, so will be 0.5" more "outside" than the front. But please Mount at least a 225 in the front and a 245 in the rear then
Killerbee is offline   Reply With Quote
Old 03-13-2017, 12:29 PM   #3380
Killerbee
Killerbee's Avatar
What tires do you want to mount?
Old 03-13-2017, 03:24 PM   #3381
FujiwaraTofu86
Drives: gt86
235/45/17 Ventus V12 evo 2
Old 03-13-2017, 04:25 PM   #3382
D-rek07
17x8 +48 245/40r17. Stock everything. Anyone have that?
D-rek07 is offline   Reply With Quote
Old 03-14-2017, 04:33 AM   #3383
Killerbee
Killerbee's Avatar
http://www.ft86club.com/forums/showthread.php?t=10257
Its very very tight, but it seems to work, maybe get in contact with the guy in the thread to reconfirm he had no camber or anything done
http://www.ft86club.com/forums/showthread.php?t=11493
Not sure if it will fit with 245 tires, as it is Ultra tight in the front to the inner struits, but it seems to fit with 215 tires. Maybe ask the guy in the thread obove for some Pictures from the inner struits to be sure
The Following User Says Thank You to Killerbee For This Useful Post:
FujiwaraTofu86 (03-14-2017)
Old 03-16-2017, 01:56 PM   #3384
Loetke
Drives: 2015 Scion FR-S Release 1.0
Hey, I'm looking at going with a staggered setup. 18x8 +40 in front, 18x9.5 +40 in the rear. I'm lowered 1" on TRD springs. What tire sizes would be best for these? I was told 235/35 in front and 255/35 in the rear, but I want to make sure that's correct. Thanks.
Loetke is offline   Reply With Quote
Old 03-16-2017, 04:14 PM   #3385
swarb
235/35 is really rare.
Front 225/40 or 235/40
Rear 245/35 or 255/35
Staggered setup isn't a good idea for this car, you can search for peoples opinions. It's mostly because of understeer and can't rotate tires.
Old 03-16-2017, 06:10 PM   #3386
Loetke
Well I'm boosted so I need the wide wheels/tires in the back. I think 18x9.5 would be overkill up front, if it would even fit.
Old 03-17-2017, 12:15 AM   #3387
StraightOuttaCanadaEh
Wes
Getting Varrstoen ES1 rims 18x8.5. I don't like the stretched look, and the rims have a bit of dish to them. So what tire size would look normal? 235? Thank you!
Old 03-17-2017, 05:30 AM   #3388
Killerbee
Killerbee's Avatar
Why not a 18x8.5" with 245/35/18 all around? You dont need 9.5" wheels to fit an 245 tire
245/35/18 is what you should look for
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
