Old 03-17-2016, 08:08 AM   #323
JGalp
Drives: 2015 CWP BRZ Limited
Originally Posted by RickyBobby View Post
After I purchased the knock off Rydeen Duo from eBay I contacted Rydeen about the camera. Here's the reply from Rydeen's director of sales and marketing:
"We do not sell to any On Line merchants and if a product is missing a serial number it will not have a warranty no matter what it's origin is. Unlike Costco, we do not sell "bulk" items. Sorry, I can't be of more assistance but when you buy products from ebay you are taking a risk. Good luck with your purchase."
I found out that the only authorized Rydeen online vendors are Al & Ed's AutoSound and Crutchfield. Al & Ed's is mainly a brick & mortar chain of car stereo installation shops and also has an online store. Rydeen may be giving them a pass due to the volume of cameras they purchase for their own installs. http://www.al-eds.com/Rydeen-Mobile-...0B-p22239.html
Crutchfield sells the Rydeen MINy but not the Duo. http://www.crutchfield.com/shopsearc...en_camera.html
So where are ebay and Amazon vendors getting their Rydeen Duo cameras from? They may be gray market cameras and may or may not work with 6V.
You can do like I did and use AutoHarnessHouse's wire harness. This harness uses a 6-volt relay and the 12-volt accessory power provided to the stock head unit to provide a 12-volt output and composite video input for any standard automobile backup camera. http://www.autoharnesshouse.com/19867.html
The FR-S also needs the reverse trigger wire.
the fr-s needs the reverse trigger wire..does the BRZ as well? someone in another thread said they didn't, just want to confirm
JGalp is offline   Reply With Quote
Old 03-17-2016, 08:41 AM   #324
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
@JGalp The BRZ does not need the extra wire
Cockatoo is offline   Reply With Quote
Old 03-17-2016, 10:12 AM   #325
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Why would the BRZ not need a reverse trigger wire? How else would it know when you're in reverse?
@Chillz you can easily make a harness yourself with some wire and a $5 relay off of eBay. I made my own for my backup cam.
B-R-Z is offline   Reply With Quote
Old 03-17-2016, 10:23 AM   #326
Aozora.BRZ
Aozora.BRZ's Avatar
Drives: '15 WRB Series.Blue
Reverse signal is already part of the harness on the BRZ.
People can confirm by entering the signal check mode of the head unit by turning the audio off, then pressing the audio button first then the voice and nav buttons together. REV will be your reverse indicator status and PKB is the parking brake status.
Image:
http://s1273.photobucket.com/user/ru...108c1.jpg.html
Aozora.BRZ is offline   Reply With Quote
Old 03-17-2016, 12:40 PM   #327
B-R-Z
B-R-Z's Avatar
Oh ok, I misunderstood. So it uses one but its existing in a harness and nothing extra is needed.
Old 03-17-2016, 12:58 PM   #328
Chillz
Drives: Asphalt FR-S & S14
Rydeen Duo on BRZ Limited
Thanks for the quick reply guys. I really want to go the simple route without the relay.
I just wanted to check if anyone bought a legit one recently and was able to run it at 6V. Basically, I just want to confirm that the manufacturer hasn't made any changes to the recent batches to cause them to only operate at 9-16V.
Chillz is offline   Reply With Quote
Old 03-17-2016, 01:18 PM   #329
Aozora.BRZ
Aozora.BRZ's Avatar
Well I just installed my new one last week using the 6V port. It had a QC stamp dated Sept 2015. I would say that is the simplest route.
As always suggested on the install, when you get your camera, first test the whole setup plugged to the head unit before mounting the camera and running all the cables.
Old 03-17-2016, 01:24 PM   #330
Chillz
Thanks Aozora.BRZ. That's what I was hoping to hear.
Old 03-18-2016, 01:01 AM   #331
ethan160222
Drives: 2015 BRZ
I bought mine from Al & Ed's Autosound last July and it's been running fine off a 6V source (head unit). I probably could have found one cheaper elsewhere, but didn't want to risk getting a knockoff.
ethan160222 is offline   Reply With Quote
Old 05-14-2016, 07:39 PM   #332
JGalp
i failed to "cut" the wire to delete the camera's guide lines. is this something i can do from the trunk? or does it require me taking everything apart to behind the radio again. i want to get rid of these lines!! and are you able to adjust the camera any on the angle? mines has like 1/3 of it being just my bumper. Thanks!
Old 06-08-2016, 12:26 AM   #333
asnatlas
Drives: 2013 - BRZ - SWP
Good info...
asnatlas is offline   Reply With Quote
Old 03-10-2017, 04:07 AM   #334
norcalpb
norcalpb's Avatar
Installed a rydeen duo with an amazon adapter and everything seems to work OK. However, I connected 2 ground wires and 2 power wires. I must be missing something but I couldn't get the camera to turn on without plugging in a power/ground in the trunk, and a power/ground behind the headunit.
Are only one of these power/ground setups used to power the camera, and if so are they both necessary?
Old 03-10-2017, 08:42 AM   #335
jasonojordan
Drives: 2013 satin white brz limited
You need both with the stock head unit. One is to power the camera. The other set is for the reverse trigger.
jasonojordan is offline   Reply With Quote
Old 03-10-2017, 06:41 PM   #336
norcalpb
norcalpb's Avatar
Thanks! And this is true for the BRZ as well?
DGM BRZ limited on the way? Coheed Member's Car Journals 16 04-11-2013 02:09 AM
My LR BRZ Limited epson1 BRZ Photos, Videos, Wallpapers, Gallery Forum 11 09-08-2012 02:18 PM
BRZ Limited Available JohnATL Southeast 3 08-12-2012 11:32 AM
Want to buy a BRZ Limited AT kgc Northwest 1 06-16-2012 11:45 PM
DGM BRZ Limited (man) available Mitchs_86 BRZ First-Gen (2012+) — General Topics 6 06-14-2012 12:50 PM
