| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 |
Drives: brz 2017 hksv2
Quick and precise, thank you very much
#30 |
Drives: Neptune GR86
If it doesn't work, skip the locking step. I think that's what I had to do with mine.
#31 |
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Can the nannies in pre 17 models be reprogrammed?
#32 |
Doubt it.
#33 |
Drives: 2019 BRZ Series.Gray
Thanks for all of the advice, everyone.
Regarding the door lock process to enable both sides unlocking with the keyless system, has the procedure changed any over the model years? I had a 2013 but will be back with a 2017. |
#34 |
Same procedure.
| The Following User Says Thank You to Andrew025 For This Useful Post: | FitchAlcyone (03-03-2017) |
#35 |
Drives: '17 CWP Limited BRZ w/PP
For the gas mileage screen in the Limited '17, does it only track your MPG for the life of your car and not per trip? Even when I change between Trip A, Trip B, and the Odometer, the mpg tracking is the same.
#36 |
Drives: Asphalt 2015 FRS
If it's the same as the previous models, MPG is tracked for the life of the car. If you want to reset it to analyze your MPG for a trip, you can hold down the display button when MPG is displayed and it will reset.
Build Thread: http://www.ft86club.com/forums/showthread.php?t=101096
| The Following User Says Thank You to Brayden_23 For This Useful Post: | Berzerk (03-03-2017) |
#37 |
Thank you! I actually just went to my car to try it out because when I reset my Trip A or Trip B, the MPG doesn't reset. I realized that I had to hold the middle button on the right hand controls.
#38 |
Drives: 2017Crystal White Pearl BRZ Limited
I've noticed with uprated tyres and much more grip the car rolls better with traction control full "off".
#39 | |
i tried everything many times but it doesn 't work.. either I do something wrong, or my car doesn't have this alarm |
#40 |
Yeah, I think I read in another thread that it's only in the US or something.
#41 |
Drives: 17 BRZ Series.Yellow / 14 Audi A4
Question about hill holder. In my new Series.Yellow I've turned this on following the instructions and it does work on hills. But, that stupid green car on a hill indicator NEVER turns off and makes me crazy. Is this the normal ways this operates? I can see turning on when it activates, but on all the time is crazy.
Sent from my iPad using Tapatalk |
#42 | |
| DashCommand PRO Clusters MY13&MY17 NEW! | Trap63 | DIY (Do-It-Yourself) Guides | 2 | 09-02-2016 04:34 PM |
| Changing FR-S AC controls for BRZ AC controls? | Ezedge | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 02-01-2016 11:19 AM |
| ECUTEK Parameter Defaults | crazyfrenchbiker | Software Tuning | 3 | 04-13-2015 06:12 PM |
| OEM AC controls | Trashed675 | Interior Parts (Incl. Lighting) | 2 | 12-01-2014 10:31 AM |
