Old 03-03-2017, 04:28 AM   #29
tomm.brz
Drives: brz 2017 hksv2
Quick and precise, thank you very much
Old 03-03-2017, 04:31 AM   #30
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
If it doesn't work, skip the locking step. I think that's what I had to do with mine.
Old 03-03-2017, 08:06 AM   #31
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
Can the nannies in pre 17 models be reprogrammed?
geezerbrzeezer is offline   Reply With Quote
Old 03-03-2017, 10:19 AM   #32
Andrew025
Andrew025's Avatar
Doubt it.
Old 03-03-2017, 12:52 PM   #33
FitchAlcyone
FitchAlcyone's Avatar
Drives: 2019 BRZ Series.Gray
Thanks for all of the advice, everyone.
Regarding the door lock process to enable both sides unlocking with the keyless system, has the procedure changed any over the model years? I had a 2013 but will be back with a 2017.
FitchAlcyone is offline   Reply With Quote
Old 03-03-2017, 01:23 PM   #34
Andrew025
Andrew025's Avatar
Same procedure.
The Following User Says Thank You to Andrew025 For This Useful Post:
FitchAlcyone (03-03-2017)
Old 03-03-2017, 03:24 PM   #35
Berzerk
Berzerk's Avatar
Drives: '17 CWP Limited BRZ w/PP
For the gas mileage screen in the Limited '17, does it only track your MPG for the life of your car and not per trip? Even when I change between Trip A, Trip B, and the Odometer, the mpg tracking is the same.
Berzerk is offline   Reply With Quote
Old 03-03-2017, 03:31 PM   #36
Brayden_23
Drives: Asphalt 2015 FRS
If it's the same as the previous models, MPG is tracked for the life of the car. If you want to reset it to analyze your MPG for a trip, you can hold down the display button when MPG is displayed and it will reset.
Brayden_23 is offline   Reply With Quote
The Following User Says Thank You to Brayden_23 For This Useful Post:
Berzerk (03-03-2017)
Old 03-03-2017, 04:37 PM   #37
Berzerk
Berzerk's Avatar
Thank you! I actually just went to my car to try it out because when I reset my Trip A or Trip B, the MPG doesn't reset. I realized that I had to hold the middle button on the right hand controls.
Old 03-04-2017, 06:51 PM   #38
2017-BRZ
Drives: 2017Crystal White Pearl BRZ Limited
I've noticed with uprated tyres and much more grip the car rolls better with traction control full "off".
2017-BRZ is offline   Reply With Quote
Old 03-05-2017, 01:51 PM   #39
tomm.brz
I just think here in Europe, our BRZs don't have this "alarm system"
i tried everything many times but it doesn 't work.. either I do something wrong, or my car doesn't have this alarm
Old 03-05-2017, 02:02 PM   #40
Andrew025
Andrew025's Avatar
Yeah, I think I read in another thread that it's only in the US or something.
Old 06-03-2017, 06:02 PM   #41
Kendal0
Drives: 17 BRZ Series.Yellow / 14 Audi A4
Question about hill holder. In my new Series.Yellow I've turned this on following the instructions and it does work on hills. But, that stupid green car on a hill indicator NEVER turns off and makes me crazy. Is this the normal ways this operates? I can see turning on when it activates, but on all the time is crazy.
Kendal0 is offline   Reply With Quote
Old 06-03-2017, 10:35 PM   #42
spike021
spike021's Avatar
Yeah, it's always on unfortunately.
spike021 is offline   Reply With Quote
DashCommand PRO Clusters MY13&MY17 NEW! Trap63 DIY (Do-It-Yourself) Guides 2 09-02-2016 04:34 PM
Changing FR-S AC controls for BRZ AC controls? Ezedge Cosmetic Modification (Interior/Exterior/Lighting) 10 02-01-2016 11:19 AM
ECUTEK Parameter Defaults crazyfrenchbiker Software Tuning 3 04-13-2015 06:12 PM
OEM AC controls Trashed675 Interior Parts (Incl. Lighting) 2 12-01-2014 10:31 AM
