| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: Brz WRB - Europe LHD
Hi mate,
now you can download and upload to DashCommand these new dashboards in accordance both with MY2013 Style for GT86/BRZ and MY2017. Each version let you choose if opening with Toyota or Subaru style and 2 clusters data. Some data needs buying of proper DashCommand extended PID's set. You need to activate Persistent PIDs and for Subaru buy ($9.95) the extended PID rights (2013 or 2014 or 2015) about measurement of oil temp and some others of specific like MAP Subaru , MAF....Gear indicator and so on. About "gear " you need to set the ratio of each gear (AT and MT are not equal) in advanced setting with axle ratio . These dashes are metric, nextly on Imperial and support is welcome from US friends On DashXL site you can download MY2013 Style ver 3.5 "Toyota GT86 - MY13 - modificato" http://www.dashxl.net/dashboard.php?dashboard=1500 Here you will find http://dashxl.net/dashboard.php?dashboard=1498 the "Toyota GT86 - MY17 - modded - ver 3.1" (Version 3.1: - new Home to select brand - Dash build with each proper operating PID - deploy on MY13 Ver. 3.5) Please rate dash! Here some MY2017 screenshot capture from my HU running Android 5.1, 7" Flat (Xtrons PF75HGTA FuseROM by Malaysk) These dashes are tested on all iPhone, Android Lollipop and Marshmallow, Samsung S6 Edge+ and S7 Edge. This job was done by Enrico Furiassi, italian enthusiast GT86 owner and senior contributor of GT86 Italy forum. I gave him a little help for Subaru Style... ![]() ![]() ![]() ![]()
![]() Last edited by Trap63; 08-18-2016 at 06:42 AM. |
Time Traveller
Great stuff!
Ver 4.0 RELEASED! now on Imperial!!
Please friends would you download and test in Imperial. History Version 4.0: - Imperial/Metric both 1) Temp unit °F 2) Gasoline - gal 3) D.T.E. - mil 4) Gals - MPG 5) Torque lb/ft 6) Speed - mph (sx cluster in metric too) 7) Power in Hp 8) Baro in kPa 9) MAF in g/s 10) MAP in kPa http://www.dashxl.net/dashboard.php?dashboard=1500
| Dashcommand FRS PID | V_86 | Electronics | Audio | NAV | Infotainment | 1 | 07-06-2015 07:45 AM |
| DashCommand + BT1 adapter | Amadeus | Electronics | Audio | NAV | Infotainment | 5 | 09-09-2014 07:59 AM |
| FR-S/BRZ MY13 vs MY14 | whatsinaname | FR-S / BRZ vs.... | 7 | 09-13-2013 09:29 AM |
| Do you think some of the first production run issues will be fixed as part of MY13? | fiveoneoh | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 07-25-2012 02:08 AM |
| MY13' BRZ | AJ PwR | BRZ Photos, Videos, Wallpapers, Gallery Forum | 10 | 07-20-2012 06:47 AM |
